Yes, but not on 3030, he uses 3535 and the copper boards aren’t dtp
BurningPlayd0h, according to my wisdom a bigger footprint equals lower thermal resistance; or it should.
Kaidomain has both 3030 and 4040 DTP boards for sale, check here:
http://kaidomain.com/Flashlight-DIY-and-Tools/led-pcbs-or-mcpcbs?limit=100
In the absence of led4power (hope they're back sometime), some way or the other we now have access to all 4 White Flats. The thread should now be renamed to
OSRAM CSLNM1.TG 1mm², CSLPM1.TG 2mm², CULNM1.TG 1mm², CULPM1.TG 2mm²
or maybe to
OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
Hope Mr luminarium iaculator notices. Is someone going to test the Boost HX? The 2mm² WF is more surface to power constrained, this means the Boost HX should obtain a higher gain than the HL. Sent a PM to djozz…
In the absence of led4power (hope they’re back sometime), some way or the other we now have access to all 4 White Flats. The thread should now be renamed to
or maybe to
I did seen and changed… :+1:
I still can’t remember those Osram emitters… It is to complicated to me. Letter and number dizziness :weary:
P.S.
First post of this thread requires re-editing with all relevant data. Thread is hard to follow and maybe it is better to read it backward > forward direction.
Can someone please check my below list for white, red, blue, and green to see if it’s correct or missing any
Trying to tell Simon what I need
This is the reply I received from Simon when I asked for confirmation that he had CSLPM1.TG, not CSLNM1.TG
i got some CSLPM1.TG ,these should be green light LED,i will test it
i think you need CULPM1.TG,right?
I’m really not a fan of the way Osram has assigned their part numbers
List I have
White - KW CSLNM1.TG - 3030 (1mm²)
White - KW CSLPM1.TG - 3030 (2mm²)
White - KW CULNM1.TG - 4040 (1mm²)
White - KW CULPM1.TG - 4040 (2mm²)
Red - KR CSLNM1.23 - 3030 (1mm²)
Blue - KB CSLNM1.14 - 3030 (1mm²)
Green - KP CSLNM1.F1 - 3030 (1mm²)
Green - KP CSLPM1.F1 - 3030 (2mm²)
I just want to send this to Simon
By the way, djozz told me he'll be reviewing the Boost HX for sale @ Shenzhen silver ingot Technology Co., Ltd.
We'll see. djozz told me he received a Boost HX sample way back from Hank, and it performed even worse than the 5P bin CSLPM1.TG he reviewed from Neven (led4power) back then (1480 versus 1530 djozz lumen), despite reaching a higher maximum current at 9A as expected. This means that CULPM1.TG probably was some ugly duckling pre-production sample or God knows what.
Hope those CULPM1.TG emitters are some decent bin, 5P minimum.
One question, how to tell which way I reflow these leds for their polarity? Twice now I’ve got it wrong.
Reply from Simon
White – KW CSLNM1.TG – 3030 (1mm²) in stock
White – KW CSLPM1.TG – 3030 (2mm²) Not purchasedWhite – KW CULNM1.TG – 4040 (1mm²) Not purchased
White – KW CULPM1.TG – 4040 (2mm²) It has been purchased and the goods are in transit.Red – KR CSLNM1.23 – 3030 (1mm²) 7L-2-0 200pcs in stock
Blue – KB CSLNM1.14 – 3030 (1mm²) Not purchased
Green – KP CSLNM1.F1 – 3030 (1mm²) 8P-A-0 167pcs in stock
Green – KP CSLPM1.F1 – 3030 (2mm²) 6P-A-0 200pcs in stockYellow - KY CSLNM1.FY – 3030 (1mm²) Not purchased
Just thought I’d share in case anyone wants some Red or Green from Convoy since it’s not listed on the store
I hope this could help.
Appreciate the help.
I thought I did follow the diagram with the indent but must have rotated it last minute
Cree also uses an indent in the thermal pad often, facing to the anode.
In the case of these Osram emitters, their thermal pad indent faces to the cathode.
This is the reason of your problem, I'd say. I've reflown many types and brands of emitters, and this is what happens with presumptions.
Lol you are absolutely correct!
“Something, something bigger number better” was basically my thought process :person_facepalming:
Reply from Simon
I hope, if he is going to stock the CULPM1.TG (“Boost HX”), that he will also start stocking 4040-footprint centering rings. Would be awesome for my Luxeon V emitters…
1mm2 underwater test
Compared with XM-L2 and later with XHP35HI (70mm reflector)
That is something new
I am not diving and I think you are very brave. Hope that some manufacturers will have zoom underwater light cause it would be far better than reflector based lights for diving. On video when you have to inspect something up close on 1-2meters from your diving mask beam of reflector light is just to intense. Wide flood mode of zoomie light would be perfect for such situations…
Mieciu:1mm2 underwater test
Compared with XM-L2 and later with XHP35HI (70mm reflector)That is something new
Zooming in a waterproof dive light would be… difficult at best.
Anyone know how hard the green boost version can be pushed? I can’t find a thread on it
Is this dtp or not? This is what’s sent from the AliExpress store above
