I hope, if he is going to stock the CULPM1.TG (“Boost HX”), that he will also start stocking 4040-footprint centering rings. Would be awesome for my Luxeon V emitters…
I am not diving and I think you are very brave. Hope that some manufacturers will have zoom underwater light cause it would be far better than reflector based lights for diving. On video when you have to inspect something up close on 1-2meters from your diving mask beam of reflector light is just to intense. Wide flood mode of zoomie light would be perfect for such situations…
From Shenzhen silver ingot Technology Co., Ltd.? Looks like it, the island around the thermal pad just encloses it give or take. When not DTP its surface is a lot larger, to better spread heat.
Yes, that’s the store. I thought they weren’t since I asked if the boards were dtp and they had no idea what dtp was, they said just copper.
For measuring continuity I’ve never done it before. When taking the reading it shows around 1.1-0.8 and slowly drops to zero, sometimes 0.6. Why doesn’t it show a constant reading? Probably should just watch a YouTube vid
Continuity is just the beep setting when you put the probes together. Doesn’t matter voltage or anything else. If it beeps between those points its dtp
Well, because the reading isn't constant. You are wiggling the multimeter probes, and namely moving the contact plugs and all of that. So, the resistance along the probes changes.
This remembered me of another time when I did research chemical drugs from time to time, and I always had a milligram precision balance at home. I found them faulty. Faulty because commercial balances tend to 0 when they are close to 0, which in my opinion is not very right. But alas! Device flaws like that are caused by a combination of product designer and customer ignorance, although maybe I am just asking too much from an inexpensive device. Should get another sometime, they're useful and now there are quite nice models.
And why are the boards from Hank, MTN or whatever the best? A higher price does not make something better. Price is a trait whose value grows in an inversely proportional way. This is not meant to say that paying more for something is necessarily bad, but it needs to have a good reason, a reason of service to one and all.
I am pretty sure that any properly designed and decent quality DTP board will perform within error marging of the above. Kaidomain sells great boards (3030 and 4040 MCPCBs available), for example. And if you don't need a rare size or something fancy, there are even cheaper options and many of these could serve you (some board models are not DTP or lack thermoelectric separation -as they call it-, but it can be easily discerned if you know what to look for -and they are cheap anyway-).
So what is the best whatever? One whose value and quality to cost ratio excels. Any money you save can then be used to help you, those around you, and etc.
