What I always didn’t like: from off, 2C brings you to max ramp. No direct shortcut to turbo. From on, 2C goes into turbo. No shortcut to max ramp. In my builds I have changed this so that 2C always goes to max ramp (without memory) and 3C to turbo (moved every other mapping one up).
Another change I’ve been considering… this one is simple, but potentially a bad idea. I want to know what people think:
Swap battcheck and lockout, so 3C = lockout and 4C = battcheck.
I wanted to do it this way originally, but instead I used the same mapping as NarsilM to be more consistent across projects. But now I’m thinking about going back to what I wanted before.
The benefits would be:
Lockout is faster to enter / exit… which matters, since lockout gets used a lot.
Batt check and other blinky-group modes aren’t used as much, so they don’t really need such a fast shortcut.
But there’s also a big drawback:
Would be a pain for anyone who has spent a lot of time with Anduril 1 or NarsilM.
I could go either way. I probably use lockout more often so having it be 3C would be advantageous but as you say… I’m so used to 3C being batt check.
Side note, and sorry if this has been talked about before, but what about a user-enabled option for auto lockout after a set time period? Edit: catching up on the thread now and reading up on previous conversations.
Also considering some other remappings… but also not sure, because it breaks compatibility again and that might be annoying.
Before:
Ramp 4C -> Config
Ramp 5C -> Manual memory on
Ramp 5H -> Manual memory off
After:
Ramp 4C -> Manual memory on
Ramp 4H -> Manual memory off
Ramp 5C -> Momentary
Ramp 5H -> Sunset timer +5m
This would make manual memory easier to access, and improve consistency because 5C would then go to momentary mode from Off, Ramp, and Strobe… and the sunset timer’s time unit (5m) matches the number of clicks (5H).
However, it again has the potential to cause confusion for people who used older versions, or who use both old and new lights. I don’t want it to be annoying to switch back and forth between old models and new models.
If light auto locked immediately, and 2c was unlock which turns on to memorized ramp, 1 click could be batt check. In other words 1 click wont turn on the light but will give 1 cycle of blinks indicating batt volt status. 1H could still be momentary bottom of stepped ramp.
Double click to unlock is super nice. Not too cumbersome, but still has reliable lockout.
RE: backwards compatibility, this is an issue but maybe not as bad as people think, we can flash the new version (if compatible) or adapt - and those that would really struggle with it would arguably be in muggle mode or buying different lights anyway?
[quote=lazerEagle]
[/quote]
I think the biggest problem I would have would be when I'm switching between my old Anduril lights and my new "Anduril 2" lights.
I still think Glamdring would be a good name for it.
The new Simple UI does that. In that mode, all configuration is locked. Nothing can be changed without switching to the advanced UI with a 10H action (click 10 times, but hold the final press).
Even in the advanced mode though, the config menus are harder to reach by accident. It requires more clicks, and there are no other actions nearby so it doesn’t happen if the user’s count isn’t quite right.
Toy Keeper, is there any config being included to switch off thermal regulation?
It would stop issues arising on different models that behave strangely or they simply don’t need it.
For myself I sell some models mounted to a gun and would love to disable it, if using normally again have the ability to switch it on with the previously saved temp config
NarsilM had this and it was really useful for certain situations
I think everyone will have something which they don’t like or would like added, but it can’t do everything. If you want max power momentary you’d normally be aiming for a tactical model with dual switches. Anduril is usually used on a single side switch.
My customers have said that NarsilM Ramping is the best and simplest UI they’ve ever used.
As a seller I’m happy to just have the Simple UI that’s been mentioned.
Turbo in momentary could be difficult when turbo is only accessible via a shortcut if you don’t want to config max ramp. Could require messing around a lot with a code that had a lot already written.
I’ve mentioned thermal step down to be disabled since in the past it hasn’t worked properly causing many issues. As a flashlight seller it becomes super frustrating to bring in 30pcs of a model that has thermal issues and then have to try sell them.
I was told by Tom E that disabling it wouldn’t require much?
If it’s a big issue then I’m not going to worry but it’s nice when I’m buying to sell, not like others who only have to deal with a single bad purchase
I would talk it over with your legal team. A full FET flashlight without thermal throttling could injure someone or cause property damage. As retailer you will surely be the main target of any lawsuit, particularly if the manufacture has no legal presence in your country.
