Pretty sure they sell the complete flashlight garanteeing IP protection, not the host which you (as you did) could screw up. Then again, I’m pretty sure they thought about that… isn’t there some sort of gasket to put in between? When I took apart mine (sp31) I remember there was something stopping water ingress.
If they had to be prepared for everything they couldn’t sell the host at all. The buyer is expected to have the nessasary tools and skills to assemble it… that’s the point of buying a host to play around with. Selling one to a person that, for example, can’t solder would be a waste of time.
Then again, It is good to know that it would be easier to have that part preassembled. But it’s kind of annoying if you list them as PROBLEMS when some are obviously to be expected (the driver thickness).
For the price of that host… Can’t really complain. $5.49…
Reminds me a lot of the old Thorfire I got “free for review” that I couldn’t stand. That entire style of switch is a hard pass for me. Completely destroys the ability to mod. Wouldn’t want to assemble, either, for reasons it seems you discovered…
Yeh, gone are the good ol’ days of removable pills, simple tailswitches, interchangeable parts, and easy modding. I still got an assload of drivers, LEDs, etc., for modding the old-timers, but newer lights are nigh impossible to mod simply. Gotta drill this, grind that, epoxy-fill something else… nah.
I switched from even buying C8s, S2+es, etc., just to mod, to just getting off-the-rack lights and leaving them bone-stock. Also cut down my expenses from buying “host” lights on a whim, to only those that I can live with unmodded.
Any chance you did a write up? I’m assuming the aux led was able to be controlled by Anduril?
I guess the sp10s Anduril is taking so long, this was next best upgrade.
Actually, I wonder if anyone would fancy a light-weight 14500/AA headlamp. Vapcell offered some high capacity 14500 cells, if I recall correctly. Certainly, this would not be a high performance headlamp but something with around 300 lumens. Sofirn's SP31 V2.0 uses a rather good CC driver but it may not work with AA batteries. I am just thinking/dreaming...
AA/14500 tube
as lightweight as possible (see Skilhunt/Zebralight headlamps for reference)
as short as possible, using pogo pins instead of springs
well-regulated boostdriver
Andúril UI (once the SP10S Andúril driver gets finished)
clear narrow beam TIR optic (SST20 4.000K 95CRI) + detachable diffusor lens to place in front of the TIR optic (see Skilhunt H03F for reference below)
AUX LED (SST20-DR or XP-E2 R/DR)
excellent maching / knurling (hommage to Charles BridgTec) ;-)
Headlamps should be super basic in operation. Sofirn need to target a larger audience than just us lot to make it worth while.
I sell to the average consumer in New Zealand and they hate Anduril as there’s way too much features and muggle mode has limited brightness which makes it useless to most who buy the headlamp/flashlight for the advertised lumens
I'm torn if I should fully agree or disagree with you. Yes, a super-simple UI would fit best to an AA/14500 headlamp. One of these UIs that one can operate even under distress. One of these UIs that can still be used with closed eyes, with the headlamp mounted to your forehead. I talked to Barry (Sofirn) some minutes ago. He's totally in for an AA/14500 headlamp, using a simple UI.
Now, then there are those flash-o-maniacs here, the ones who really want to "fully loaded" version with all the nice benefits that Andúril can provide. Again, I agree that Andúril might be overstraining some customers, leading to a higher return rate for vendors, leading to many questions from customers and so on and so on... But still, there's a market (niche) for lights with a complex UI. Having the best of both worlds is hard to achieve. AFAIK, TK is about to unlock some features of the Muggle mode in Andúril 2.0, so maybe there's some silver lining on the horizon.
Not sure if/where I posted it, but I can't upload pics right now - PhotoBucket trashed my account or something. Ever since their recent update, my uploading has been flaky at best.
It was a simple driver swap mod, using a DEL 85 FET+1 driver running Anduril with AUX LED support for the switch LED.
The code is already working. Mostly just doing more testing and documentation now.
It uses a simple UI by default, but the extra features can be unlocked by people who want them. So, straight out of the box, it gives people access to on/off, up/down, lockout, battery check, and factory reset. If they want more, there’s a way to unlock it for full access to all the extra modes and features.
Honestly agree to this. I wouldn’t mind a UI similar to the old Nitecore Tube
Single click to medium. Double to max
Hold from off to ramp to desired brightness (always start from low/firefly) no memory
I agree that Anduril2’s “simple UI” would probably be good for a headlamp. I’ve got RampingIOS / D4 V2 UI running on my main headlamp and I think brings some good advantages: lowest-possible low mode (for the host), smooth ramping, shortcuts to low & turbo, lockout, and temperature control. I feel like all of those are very beneficial in a headlamp without getting overly complicated. If Anduril2 can bring similar simple functionality yet offer the advance UI for enthusiasts… win win.
Some things require going into advanced mode, of course… like, if the user wants to change the thermal limit, or if they want to enable full power turbo in the simple UI, the config settings are only available in advanced mode.
As for what power levels the simple UI will allow, that depends on the specific light. The default limits are set based on what makes sense for each host. The user can change it though, if they’re willing to go into advanced mode to access the config menus.
Usually the default floor starts a little higher than moon, so people won’t think the light is dead if they turn it on in a bright room and don’t see anything coming out. At the high end, the ceiling is generally set slightly higher than what the light can thermally sustain while tail-standing with a mild breeze. So, if the host is designed to sustain full power, they can use full power. If the host is a massively overpowered hot rod, the simple UI ceiling will be quite a bit lower than full power.
Shortcuts to floor and ceiling are included in the simple UI too, though I didn’t mention it earlier. However, turbo is blocked. Instead, double-click goes to the ceiling level.
