Promo code Does NOT working. Only take off $0.53
Why only 20% OFF when Wuben once offered 100% OFF? :-D :-D :-D
(yes, this was real, no fake - the "Geschenkgutschein" was a public code from Wu Ben Only, displayed on the product page on Amazon.de)
Does this have a boost driver like the TO50R?
OMG how did I missed that.
Plus, this is $0.5 discount which is 1% discount not 20%. :person_facepalming:
I bought a few TO46R 2 years ago and modded them with the SST-20 emitters. Excellent light. I’m more interested in discounts for the TO50R though because it has a very effiicent boost driver and can also be used as a power bank to charge cell phones.
Oh, God, I made a mistake. Pls try: IJ7U3LY3 ( active after 4 hours from now) for the truly 20% off :)
Humm, that was a celebration activity 2 years ago to feedback WUBEN supporters.
We might run this deal again sometime this year, stay tuned!
The headlamp will be coming soon sooon. Wife will be happy if you can invite her to your flashlight party
Thanks for your support of WUBEN torches. Will keep you updated if we have any TO50R deals.
Dang, IJ7U3LY3 is the code for truly 20% off
I'm afraid the driver of them are quite different. Sinces, TO50R will be used as a power bank while TO46R is just a led flashlight
i guess i came to the party late, the code doesnt work for me.
Dont think it has been 4 hours for the code to update…yet
Not sure. Power button for on of course, memorizes last mode used. mode button for mode changes. Press and hold power for momentary turbo from off, press and hold mode switch for momentary strobe from off. From on press and hold power for constant turbo or press and hold mode button for constant strobe. Press and hold both buttons from off for lockout.
I had one of the originals but couldn’t recall the UI.
The Nichia is definitely worth it. So as long as you can live with mode memory. If it just had a instant shortcut to low it would be 5 stars.
Thanks for the description of the UI, toddcshoe! It is similar to the “regular” TO46R :weary:
I had the “hope” that Wuben had incorporated the TO50R UI in this light as it would be amazing, specially with the Nichia leds. But it seems that it will not be very “possible”. :zipper_mouth_face:
I still have that hope! DO YOU READ ME WUBEN? :innocent:
IMHO, TO46R and TO50R UI are quite similar, pls check details as follows. And which part of the TO50R UI has attracted you most?
Here is the description of TO46R UI:
1. ON/OFF: Single click power switch to turn on or turn of the flashlight
2. output selections: When the light is on, single click on
W switch to cycle through Eco-Low-Mid-High-Turbo.
This light has output memory function, every time it
will be turned on the memorized output level.
3. Instant Turbo: When the light is off, press and hold
power switch to activate Turbo, release to turn it off.
When the light is on, press and hold the power switch to
activate Turbo and constant on, and click to turn it off.
4. Instant Strobe: When the light is off, press and hold
W switch to activate Strobe, release to turn it off. When
the light is on, press and hold o switch to activate
Strobe, and click to return to the previous output level.
5. SOS: When the light is on, press and hold W switch to
activate Strobe and then SOS after 3 seconds, single
Click to return to the previous output level.
6. Lockout and unlock: When the light is off, press and
blink to indicate the lockout, press and hold again until
it blinks again to unlock the light.
TO50R Operation:
ON/OFF
A single click on the Power switch to turn on/off the flashlight -
Instant Moonlight mode: When the light is off, press
and hold the light for 1s to activate Moonlight mode. -
Cycle Mode: Single click on W switch to cycle through Micro-Low-Mid-High-Turbo. -
Instant Turbo:
Press and hold the Power switch to activate Turbo. Press and hold the Power switch again to return to
the previous status. A single click on W switch to return to Low output level.
Press and hold W switch to activate Turbo, release to return to the previous status. -
Flash Mode
ON: Press and hold the Power switch for 2s to activate Strobe. -
Flash mode selections: Single click on W switch to cycle through 4 flash modes (Strobe- Beacon 1s -Beacon 10s - SOS). -
Instant Turbo
When the light is off, press and hold W switch to activate turbo, release to return to the previous status. - Lock and Unlock
Lockout: When the light is off, press and hold the power switch 8s to lock out the flashlight ( it will be turn off after a blink)
Unlock: When the light is off, press and hold the power switch 5s to unlock the flashlight ( it will be turned on low output level)
TO46R lacks a shortcut to the lowest mode (listed as “Instant Moonlight Mode” for TO50R) which to me and many others is basically an essential feature for any EDC light.
5lm is also much too bright for use with dark-adjusted eyes and to preserve night vision. 1lm like on the TO50R or even much lower would be preferable.
That's true. 5LM is too much in a dark situation.
If you have other more suggestions, kindly let me know. WUBNE will keep improving to make a torch that everyone loves
Micro-USB is the deal breaker for me. All phones come with USB Type-C cables. Nobody carries Micro-USB cables with them anymore…
Humm, that's why WUBEN new release products use type C rather than USB charging
