What blade did you EDC today?
3920 posts / 0 new
Blackbeard
Blackbeard's picture
Last seen: 6 hours 23 min ago
Is it possible to paint on Rit dye instead of dipping the scales in it? I was thinking of using frog tape, possibly cutting it into a pattern, tiger stripes or lines that get smaller as you go down the scale, just unsure if it would bleed past the tape or work at all once you dip brush in the hot mix…even a splotchy multicolor Jackson Pollock type application might be cool….er I have to many knifes that are black, one colorful wont kill me
Adahn
Adahn's picture
Last seen: 6 hours 10 min ago
Chronovore wrote:
Adahn wrote:
I’m sliqutly wondering how the carbon fiber/fiberglass compound material on my Kershaw Chill and my diamond file would take the dye…
Was this a sprint run? I’ve never seen a Chill with scales like that. Is it still 8Cr13Mov?
There was never a Chill in a better steel afaik. I’d like one in Sandvik 14c28n for example, still budget but much better than 8Cr13/14MoV or D2, especially with Kershaw’s beloved bead blasting which even makes 8Cr rusty.
So no sprint run, just scales made by myself 4 1/2 years ago (as the timestamp says)
Excellent flipper on bronze washers, my slim Boker Urban Trapper would be more stable on bigger bronze washers as well.
Chronovore
Last seen: 4 hours 59 min ago
Adahn wrote:
… Excellent flipper on bronze washers, my slim Boker Urban Trapper would be more stable on bigger bronze washers as well.
Nice job!
Now you’ve got me thinking. Is there a good source for appropriate washers of various sizes?
Lightbringer
Lightbringer's picture
Last seen: 4 hours 21 min ago
Hey, black knives matter!
Adahn
Adahn's picture
Adahn
Adahn's picture
Chronovore wrote:
Nice job!
Thank you. Well, I don’t know, especially due to the fact that the Boker UT hruns on ball bearings and would need some fitting washers to fill that gap first.
It doesn’t matter enough to me to search for bronze washers.
I’d look for them on ebay – phosphor(ous) bronze washers or at shops like usaknifemaker.com
Swabs
Swabs's picture
Last seen: 2 days 14 hours ago
Today it’s an Artisan Cutlery Virginia. She’s a big one. 3.94” D2 blade.
My Future's So Bright...well, my flashlights are anyways.
raccoon city
raccoon city's picture
Last seen: 8 hours 37 min ago
Swabs wrote:
Nice looking knife, except for the pivot screw swastika!  :P
Thro
Thro's picture
Last seen: 1 day 9 hours ago
I think they meen for it to look like the Artisan Cutlery logo LOL
Nice knife Thumbs Up
sparkyDK
Last seen: 2 days 11 hours ago
As much as possible we should forget those guys that misused a Asian sign for the sun and prosperity and good luck.
+ a slew of other meanings depending on the cloture you focus in on, but those Germans once misusing it we should for get about, and only pull them out of the history books when someone need a scare.
isti242
isti242's picture
Last seen: 6 hours 20 min ago
Petrified Fish PF929 “Harlequin” Cool
Swabs
Swabs's picture
Great looking knives those PF’s.
Chronovore
Nice! I ordered one with a fully coated blade on day one. I’ve just been playing the waiting game. I’m glad to see you got one.
isti242
isti242's picture
Swabs , Chronovore: Thank you! I was having a hard time choosing between the full black washed and the dual tone version. Aesthetics won over practicality.
Fortunately this harlequin version solved my “which handle color should I go for?” problem. Big Smile
scalpel_ninja
Last seen: 5 hours 52 min ago
Benchmade 555-1 with AWT scales.
Current Collection:
Inova X5 | Maratac Titanium Inspection AAAx2 XPL-G2 swapped to Nichia 219B sw45K | Wowtac A2S NW | Noctigon KR4 Ti/Cu E21A 4500K + 18350 tube | Thrunite Ti3 NW | Wurkkos FC11 x2 swapped to Nichia 219B 3500K | FW3 CuTi XPL-HI 5000K + 18350 tube | Olight I1R EOS (de-anodized) | Convoy S2+ 7135x8 T6-3B | SkyLumen LEPvn | Nitecore D10 Custom with Anduril | Jetbeam RRT01vn 3000K | Thrunite T10 Ti | HDS Rotary Nichia 219B 4000K
Adahn
Adahn's picture
Practiality? Seriously? You own like how many knives? Maybe not a Great Gross, but definitely a Small Gross.
Do you ever make your knives dirty or even scratch them?
In the beginning I liked stonewashed/blackwashed blades until I learned that on a user some battle scars make it look ‘real’.
And honestly, a well made satin grind isso much nicer to look at, not to speak about the fact that if a blade is available in satin/stonewashed the tumbled ones are usually the ‘B’ grade blades. Coating and tumbling is very good to hide imperfect grinds, I’ve seen that the best on my Kershaw/Emerson CQC-5K.
What cheap piece o’crap, I’m glad I got it in exchange for material instead for real money (except shipping).
But I admit, it’s looking great with leather handles.
isti242
isti242's picture
I’m still curious whether a black acid washed finish gives any rust protection to D2. Smile
Adahn
Adahn's picture
I’d say best for rust prevention would be a polished blade like they do it with carbon steel since ages, second best a very fine satin grind.
Stonewashing would be good to hide rust spots that already appeared, just like on Kershaw’s bead blasted ‘stainless’ blades.
So that’s the only complaint on my Green Thon Mouse3 that it’s only available with a blasted D2 blade instead of a simple satin one.
It’s a work knife so when I see spots I’ll maybe stonewash it.
A blackwash (a stonewashed black coated blade) could be good against rust but it could still rust on the rubbed off areas.
If I can choose between 14C28N and D2 I’d always go for the Sandvik if it’s for food prep or stays pretty much unused in my pant’s pockets.
For a real user I don’t mind D2, my TwoSun TS51 shows some spots, too, though, I didn’t clean it well under the scale enough close to the pivot.
Is it smart to use a semi-stainless steel knife as a travel knife instead of say, a fixed knife?
Maybe not, but it’s so much fun how the thick and scary sharp blade flies open and nearly cuts my finger when I close it.
I’d almost wish for washers instead of ball bearings. Almost. If it wasn’t so much fn the way it is Wink
BrightKen
Last seen: 1 day 8 hours ago
Damascus or brushed satin blade today?
isti242
isti242's picture
The damascus one looks pretty good! Smile
Boker Plus Federal for me:
Adahn
Adahn's picture
sparkyDK
I seem to have misplaced my trusty pocket pal this weekend, and i do not like that so i have just done something about that Big Smile
Nothing big in size or prize, at least the price part i can not carry these days, the budget just took a major dive off a cliff into a puddle of acid rain.
There is a reason a pair of pants have 2 pockets at least, one pocket for the keys and one pocket for a knife.
xevious
xevious's picture
Last seen: 3 months 4 weeks ago
I almost bought one when they had it on sale… but the clip issue kind of lost it for me. Still, quite a handsome knife & the clip design is an interesting novel idea (that I think they could’ve done better).
isti242
isti242's picture
Yes, the idea was good but it didn’t work in practice that’s why I bought a belt sheath for it.
xevious
xevious's picture
Smart move. It’s slender enough to work well in a sheath.
Been carrying a Boker multi-tool I got from County Comm. It has the taupe colored scales. Nice deep carry. Gorgeous hollow grind polished blade.
Swabs
Swabs's picture
Nice Boker multi-tool! I like hallow grinds, and Boker did an amazing job on that one. Beautiful.
Adahn
Adahn's picture
Actually Sanrenmu did that great job, like on their self-branded SRM WA721-A1
Too bad they only give the tip-up carry option on the Boker version.
fcalt
Last seen: 6 months 3 weeks ago
I carry a Victorinox Huntsman on a daily basis. It’s awesome.
sparkyDK
The replacement for my Ganzo automatic that was lost,,,,,, and found again last night.
Anyways a man cant have too many knives,,,,right Cool
Item in question Boker Plus lateralus Steel.
It feel quite nice, and the edge on it from the factory are not bad, but i personally prefer a bit more shine ( polished ) edge.
So this new “toy” will get a spin in my pocket in the weeks to come, and the Ganzo get a well earned rest again.
Roryhawke
My 20 year old Buck Lightning
