Would it be possible to get a set of thru-holes drilled in the S21A Triple Aluminum spacer to match up with the tapped screw holes in the pill? I’d like to be able to use a long set of screws to clamp everything in place…
I need to think if it is possible or not. But only Cu S21 spacers are available atm.
And zhey are great! I wish i purchased more pills :(
No, this is not possible. There is no place for screw heads.
I had to delay S21a spacers for several month because I had no solution how to center spacer on flat pill. One of interim versions had holes in the spacer, with M1.6 threads. With din912 socket head screws installed from the bottom, they match wire holes in the pill. Once I tried it, I have realized that such option is too complicated, also not each stock pill have holes in exact same place.
Since you need a central hole in the pill, (and pills are made from copper) you have another option. First of all, you can drill central hole in the pill when both pill and the spacer are installed in the host. After hole is ready, you can remove parts, add a little chamfer, clean them and put together with some solder paste between the pill and the spacer. Then you can put a drill shank in the center hole and use torch or hotplate to solder parts together. This method is not super precise, but in most cases the pill and the spacer can be aligned well enough.
For super fine centering 20mm triple optics in S21A host, another part that centers optics itself is needed. I don’t think machining this part (lets call it liner) is worth it, it should be probably made by 3d printer.
D’oh!
Forgot that the Triple MCPCBs don’t have screw holes. Was interested in aluminum to keep the weight down, but looks like that won’t work here. Copper spacer and solder is definitely the simplest solution…
BTW, the new style triple optics in the FW lights are a perfect fit for the S21A. No additional centering pieces/sleeves needed. Of course these don’t suit everyone’s taste, but should be noted
Just received my C8TT head and copper S2+ triple spacer. They look perfect, good threads, everything is smoothly finished, clean, the machining is high quality, copper is shiny, no burs or dirty looking work at all. They arrived well-packaged and wrapped individually in bags in side of bubble-wrap, and exceeded my expectations.
Included o-rings, lens, lubed threads, everything as described or better. Kiriba-ru was nice enough to do some additional machining work to my C8TT head for a custom idea for a small fee, and it turned out great. Excellent service, product, communication from seller. Shipping was faster than I expected. Just about as fast as any Sofirn store or Aliexpress wait-time to the CONUS right now given the conditions. Ordered/shipped July 21st and received yesterday from Russia to Louisiana, US. Thanks! will be ordering again. Pics to come once I get time to build them.
Hoping to make a triple S2+ with sst-20-dr red, and maybe a red triple C8TT if I can make the C8F reflector work with the screw that protrudes from the bottom of it, or a single-led C8TT, depending on finding the right reflector/parts that match the additional machining work. We’ll see. Either way, I’d order both of these again.
Crazy idea bump:
Make this and SKV and I will buy it. I mean I didnt ask him but he’s a sucker for this stuff
Same style as S11 quad but have it replace Ledil ANGIE optic with 12x XP mule MCPCB.
33mm on the bottom to match Noctigon 4XP 33mm, whatever size at top you wish that will fit above mule board height would be ~10mm and make o-ring groove like above. You could even countersink small hole in bottom to align with one of screw holes on Noctigon 4XP 33mm to prevent rotation (optional I guess). Suggest making it in copper so board can be soldered to spacer.
You would not want the wall of spacer to be against pcb so we dont block as much light from mule
Yep. I confuse you sometimes, you usually think in one direction.
I have thought about spacers for the mule config since Hank made such pcbs. I wanted to try a smaller board in S21A but realized that bezel opening is not big enough and too much light will be waisted.
It will be hard to fit o-ring like I did it in S11. Convoy lights are “meaty”, there is enough room in all directions. Noctigons (emisar) are tiny, thin and lightweight. I have never made anything for f3a or d4 or other well designed tiny lights - they are already piece of art, they are hard to improve.
P.S. I have not read much about new leds for few years. I am right if I suppose that your request comes from the fact that there are various of great leds in 3535 case, while all multi-led arrays like xhp70 still have ugly tint and not many cct options?
You can always FET+1 the XHP70.2. The 7135s aren’t technically rated for more than 6V but my L6 driver is doing fine so far.
It will be hard to fit o-ring like I did it in S11. Convoy lights are “meaty”, there is enough room in all directions. Noctigons (emisar) are tiny, thin and lightweight. I have never made anything for f3a or d4 or other well designed tiny lights - they are already piece of art, they are hard to improve.P.S. I have not read much about new leds for few years. I am right if I suppose that your request comes from the fact that there are various of great leds in 3535 case, while all multi-led arrays like xhp70 still have ugly tint and not many cct options?
Noctigons are tiny indeed but it is the reason I chose this combo. We need some space between LED and bezel and D4S (or even X6 w/ “Angie” spacer) is actually too big since Angie optic is ~35mm and mule MCPCB is only 24mm so we have plenty of space on sides. Height will be slim compared to some spacers but I dont see problem. Maybe you cant countersink a anti-rotation hole but everything else seems ok
Yes and xhp70 .2
Also xhp50.2, xp-l2, xp-g3, probably xm-l3 (it’s new led) too. They all have a terrible tint.
Hi, any chance you could make a Convoy C8 copper pill?
No, all Convoy C8s made last 5 years do not have pill.
I got mine this week as well, really good quality spacers! The craftmanship on them is incredible for the price, and they fit perfectly without any modifications in my S2+ triple. The thermal contact is really good as well when using quality thermal pastes, having no problem with overheating. I can only recommend them, and will probably buy more if needed.
Any idea if the triple spacers will fit the newer copper host I think it has slightly different threading
Dont see any reasons why they should not fit.
Any idea if the triple spacers will fit the "newer copper host. I think it has slightly different threading
I have new copper host and “old” spacer. Working great :)
I ordered some parts a while back. They took a long time to arrive due to customs. Parts arrived well, wrapped individually and thoroughly. The manufacturing is clearly at a high level. Thanks a lot!
I would like to order 3x L21A spacers. What’s the thickness on these? 5mm?
L21A? Sorry, don’t have any spacers for this model.
