How to removing the coating on the copper Convoy S2?
18 posts / 0 new
Omega_17
Last seen: 1 day 11 hours ago
I tried to rub it with nail polish remover and alcohol but it didn’t work.
Firelight2
Firelight2's picture
Last seen: 6 hours 24 min ago
If they used something like Protectaclear you might try soaking the parts in Xylene.
KyleGates
Last seen: 3 hours 59 min ago
I just used 0000 steel wool on mine. Its easy to see where the coating is and isn’t and it leaves the finish ready for polishing.
kiriba-ru
kiriba-ru's picture
Last seen: 2 days 17 hours ago
I would rather try finest scoth-brite or steel wool than any chemical method. You can be disappointed with uneven surface after etching.
Henk4U2
Henk4U2's picture
Last seen: 7 hours 14 min ago
But in case you decide to use chemicals: strip the light completely. Because those chemicals can wreak havoc on the rest of the light (PCB’s, reflector, lens, and O-rings).
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
LifeXventure
Use a brass brush and some patience. Very nice result though.
Omega_17
I will try this, I don’t want to use dangerous chemicals. Thank you.
Verodin
Old topic, but the title is perfect. Got one of those slightly imperfect copper Convoys Simon offered not too long ago and it turns out they’re coated. It feels weird and I love patina, so the coating has to go! Besides the chemical stuff, has anyone tried washing soda? I read that’s used for removing coating on copper cookingware, so maybe that would work as well. Has anyone tried this?
NeutralFan
NeutralFan's picture
Last seen: 4 hours 54 min ago
I removed the coating on one of mine using gasoline and a steel brush.
I tried a bunch of thinners (paint thinner, lacquer thinner, etc.), and it seemed nail polish remover (acetone) was making the coating sticky, but gasoline actually made it where I could scrape it off.
I soaked the parts (tail, body, head) in gasoline and one at time took the steel brush to them, soaked them again, brushed again. It took many times and hours doing this to remove all the coating.
I removed the coating from the textured (LITNIT) version. I think I’ll keep it on the smooth version, at least for now.
Let the patina begin!
I’d rather use my flashlight around the house than turn on the lights.
NeutralFan
For anyone that’s interested, the patina is looking really nice.
Lojik
Lojik's picture
Last seen: 18 min 51 sec ago
!{width:75%}https://live.staticflickr.com/65535/52218813529_5e1f50197a_b.jpg!
Was it not patina’ing at all with the coating?
nobody
Last seen: 1 week 4 days ago
I have the same light.  Won't the steel brush scratch up the copper?  It looks OK, but did you have to polish it up afterword to remove any scratches?
THanks
NeutralFan
The coating will prevent the copper from getting patina. I haven’t noticed any patina on my smooth version, nor do I expect any to occur.
The coating seems like a varnish that is used to protect wood. It’s a thin clear layer that feels like a hard plastic.
NeutralFan
nobody wrote:
I have the same light.  Won’t the steel brush scratch up the copper?  It looks OK, but did you have to polish it up afterword to remove any scratches?
THanks
I used a soft steel brush and didn’t polish it afterwards. Getting into the end of the tail was the hardest part, and I used some toothpicks there too.
Here’s the brush I used that I got at Harbor Freight. I used the stainless steel one since the brass was too soft.
Neb_77
Last seen: 1 week 1 day ago
I’m going to try a tumbler used to clean brass casings I’ll get back
andrx
andrx's picture
Last seen: 8 hours 22 min ago
Steel wool 0000
NeutralFan
This should be my final update. Smile
The patina seems to be stable now with this look. There’s some neat shiny bluish color in the 3 grooves at the end of the flashlight.
It sure has a lot of character!
Of all the S2+ colors that I have (10 so far), this is now my favorite.
andrx
andrx's picture
!{width:75%}https://live.staticflickr.com/65535/52233776422_6d02719ddf_b.jpg!
Thumbs Up nice
