BLF triple 21700?
63 posts / 0 new
texas shooter
Last seen: 2 hours 53 min ago
BLF triple 21700?
I’m just throwing this out there. Is it time for a Sofirn SP36 BLF style in 21700? 4-7 LED’s maybe more? Cree XHP50.2, SST-40?
MoreLumens
MoreLumens's picture
Last seen: 1 hour 9 min ago
Interested. Deep cooling fins, aux-lights, usb-c + other necessary stuff like a massive amount of lumens and some special body color. What’s not to like?
amplificus
amplificus's picture
It’s been a while since I’ve been on this forum, but this looks like a great one to follow. Definitely interested in a couple with aux-lights and usb-c charging.
jeff51
jeff51's picture
Last seen: 1 day 20 hours ago
A great idea. Keep it to three cells or it will get too fat.
Multi 21700 lights are going to be a thing. Once someone brakes the ice so to speak. Others will follow.
Also scallop out the metal in between the batteries. Sort of like a revolver cylinder.
Make it much lighter and unique looking.
All the Best,
Jeff
Itsme
sounds like something that I would be interested in. If we could get the 21700’s included that would be even better because in the Canadian city where I live, Samsung 40T’s are 25.00 each and 30T’s are 22.00 each
peg matite
peg matite's picture
Last seen: 1 week 1 day ago
Jeff
Yes agreed. This is why I kept my 4 cell Q8 and ditched my 4 cell mini TN30. It makes a big difference if you don’t have big hands. 3×21700 sounds great. About 25% more capacity than 4×18650.
AguassissiM
AguassissiM's picture
Last seen: 1 day 7 hours ago
Have a look here for better price : 18650canada.com
***Rofis MR70*TurnRaise*Catapult V6*BLF Q8*BLF Mini*BLF Micro*Haikelite MT09R* Convoy C8*BLF D80v2 SST40*MatemincoX6S*AstroluxFT03-xhp50.2*AstroluxFT03-sst40*BLF-LT1*AstroluxFT03S-SBT90.2***
texas shooter
I brought up the idea because shortly a manufacturer is releasing a triple 21700 with 6 XHP70.2’s claiming 25000 lumens for $200. Being BudgetLightForum I figured it could be done here cheaper and with Andúril.
Itsme
Thanks so much for that link! The prices in Calgary are so much more than from that shop in Red Deer. I will be ordering from them very soon. Thanks again
blueb8llz
Last seen: 11 hours 20 min ago
Great idea. I’d take at least one
Lightbringer
Lightbringer's picture
Last seen: 22 min 27 sec ago
Unno, Sofirn could pretty easily grow a SP36 a few mm around, no?
Zappaman
Zappaman's picture
I like the idea of keeping it VERY efficient, AND with (regulated) higher sustainable output Vs. a million lumens for 5 seconds on Turbo… then 500 lumens 5 minutes later Flat Stare
Kinda like the Sofirn SP33 V2. If that light had ramping, I’d call it near perfect for a 26650 single cell/emitter light as it can sustain good output for a good while. Or the LT1 (which does have a great regulated 600 lumens for hours of run time) could be another design to draw from.
But YES… keep it three cells MAX as we don’t need a Q10 Silly I’d even be happy with a thinner, lighter tube to keep it hand-hold’able and lighter weight to boot.
I’ve been using my headlamps picking squash bugs out of the garden almost nightly. I am constantly having to click up a level every 20 minutes (after the first hour of run time). No big deal, they work GREAT as-is. But it would be cool to just get the 700 lumens (or whatever) rock steady FOR 100 MINUTES .
I am not sure about the efficiency delta between regulated and non-regulated drivers, but I’d LOVE a light that could SUSTAIN a steady 3500 lumens? (or whatever three 50G 21700s could do at 5000mAhs each and 10 amps continuous each = 30 amps) for over an hour… “continuous” Beer
ZappaMan
Tubercle
Last seen: 1 day 1 hour ago
Too thick to hold, and if not too thick, essentially has the same efficiency and capacity as 4× 18650 which are common.
MoreLumens
Thats why I would love to see deep cooling fins just like with GT4 which is kinda pioneer light on massive passive cooling. Also like you said good regulation and for a bonus some awesome turbolevel which also can be pretty sustainable with good passive cooling. I also hope we see a lot more that “revolutionary” passive cooling design in other lights too.
Zappaman
Zappaman's picture
Tubercle, you have a good point Thumbs Up
4 30Qs can deliver 12000 mAhs of capacity and double the current as three decent, higher capacity 21700s.
So it would be the opposite of what I am thinking and they’d have to go for a big-ass pocket rocket with three Molicel or T40 21700s kicking out 90 amps continuous into whatever the highest lumen config is that it would drive. As you said, about the same capacity, but with a little more current… probably not enough to justify it.
Still, in time it will be done as the 21700 format slowly takes over the 18650 market.
ZappaMan
Zappaman
Zappaman's picture
Morelumens that is ALSO a great point. I’ve seen many lights that could have deeper heat sinks cut in. I guess they worry about the lightweight “el cheap” factor and the light sinks “bending” if you use it to jack up your truck. !!! I get mass helps too, and cost is due to having to mill more material (and start with a larger chunk).
I need to check out that GT4… sounds ahead of its time.
ZappaMan
Di_Joker
Di_Joker's picture
Last seen: 4 hours 14 min ago
Yes! I love the Cree XHP50.2 and Cree XHP70.2, they don’t get that much hot.
Sorry for my poor english.
texas shooter
3-21700’s vs 4-18650’s about the same, but I’m leaning to the newer 21700 format. Maybe 6 XHP50.2 giving up some lumens for throw and less heat. So maybe 15,000 lumens instead of 25,000 but more throw and a lot less heat. Or SST-70 for more throw over the XHP50.2’s. Or 7 SST-40’s. Just something a bit well thought out and a step up from the Sofirn SP36 BLF.
peg matite
I guess 3 5000 mah 21700s wouldn’t deliver same punch but still some more capacity over 30Qs anyway. I guess going with 4 3400 cells makes it a wash again though.
nydude
Last seen: 1 day 13 hours ago
yes. yes, scalloped is good. hi CRI. charging.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 4 hours 37 min ago
Good idea! Thumbs Up
Actually, I was thinking about this idea, too (at that time with only one emitter) to benefit from the latest high drain 21700 batteries for Luminus's SBT90.2.
http://budgetlightforum.com/node/69868
Using a multiemitter optic with a design like LEDiL's TAMPA NIS83-MX-7-W, see below, of course bigger, wider to make use of the increased tube diameter. Something like Hank's D18 but less floody, more throwy.
Zia
Last seen: 4 months 20 hours ago
3*21700 sound very intresting
Zee
Lightbringer
Within a coupla mm, it’s the same exact diameter as 4×18650. <yawn/>
Caleb
Caleb's picture
Last seen: 3 days 21 hours ago
As others have already stated, 3×21700 and 4×18650 are very close in size, capacity, and amperage (depending on which cells are selected.
Also, multi-emitter lights have become commonplace.
So what will make this hypothetical light a standout worthy of a BLF logo?
texas shooter
Because we don’t have one yet. Fenix did LR35R 2×21700 with 6xSST40’s. Imalent did MS06 3×21700 with 6xXHP70.2’s. So I thought some thing practical and in the middle. 3×21700’s driving; 4-7 SST40’s on the throw side or 4-7 XHP50.2’s on the flood side. Since I have zero build ability, I thought I’d just through the idea out and see if it sticks.
Caleb
Caleb's picture
Upon further consideration and some VERY LOOSE extrapolating of 4×18650 vs 3×21700 performance (using HKJ battery comparator), I think 3×21700 has the advantage… not only in capacity, but especially in maintaining a given current. I mostly used 40T in comparison to various 18650s.
Of course, I could be reading the graphs incorrectly. Innocent
Yokiamy
Yokiamy's picture
Last seen: 5 hours 43 min ago
Simon is releasing a triple 21700 soon
Rahelming
Last seen: 7 months 2 days ago
It would be nice if it had a 1/4-20 tripod hole and onboard charging. just something like a cross between sp36 and q8
mortuus
mortuus's picture
Last seen: 2 hours 45 min ago
with ramping ui ?
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
wle
wle's picture
Last seen: 15 hours 31 min ago
not interested in 21700 format
18650 is small enough, with enough power/energy, for pocket edc
anything bigger, may as well be 26650
and not intended for pocket
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
mortuus
mortuus's picture
wle
well not true, 21700 can hold almost the capacity as 26650 but alot smaller. and 21700 is the future where 26650 is not, most flashlight makers will not use 26650 in their lights today and only focus 21700. so a light with 21700 compared to 26650 feels lighter and not as bulky…
              つ ◕_◕ ༽つ
