[UPDATED M4D deal] Manker “EDC Muscle Combo – BLF Limited”
That would work! Thanks again Martin!
MC13 tear down pics….for those who dare… :smiley:
Driver is heavily glued… a little acetone and pushing the driver radially to sheer the glue worked in minutes… advise not to punch out thru the mcpcb hold downs screw holes…
Signal tube looks to be glued with a slight press fit…
Looks like a nice big PCB but shelf is anodized and something isn’t flat by the looks of paste.
Can you measure optic width height and led opening?
Woah, stingy on the thermal grease :frowning:
Looks like an attiny44. I see a coil so hopefully this is a buck-boost arrangement. Any closer pics of the driver? Not necessary, I’m just curious about what they have going on here.
Question, will these lights accommodate normal flat top 18650/18350 batteries? The ones provided seem to be much longer with the included USB charging.
Any pics of the internals of the heads and bases?
I’m in for one! Think i’ll get a blue and green head if possible! Thanks Martin!
I’m so glad to hear Vinh thinks this new Manker UI is perfect! Finally those that are sensitive to poor UI no longer have to rule out Manker lights!
Yes,works.
Manker, I hope the shelf will be devoid of anodization?
If lights are going to be made specially for this groupbuy, would it be possible to produce them without glue?
I second to that.
I third that.
I fourth that. :-D
Please dont EVER use glue!
I sixth that!
These lights were built excellently with great UI, so we may not have a lot of room for improvement and mod.
I would not do much for mine and would not mind if Manker uses glue on these.
However, please Do NOT use LOCTITE or heavy glue.
That being said these glues should be good for us.
Shouldn't you fifth that? :-D
I counted SKV89’s post as the fifth :smiley:
Dia. 35mm x Height to leg shoulder 23.4mm x Emitter dia. opening 7.8mm
