WTB: Custom P60 brightest single mode possible. And solarforce pressure switch
As per topic, I am looking for the brightest single mode drop in for my solarforce. I don’t need it to run more than 5min. It’ll bes used mostly as a flasher. To alert pedestrians and motorists. Preferably NW or WW.
Together with it, am also looking for a pressure switch for the light. I have an L2T.
Thank you
Must it be custom?
Because I saw a listing from aliexpress for a P60 XHP50.2 3V version and they come with single mode
https://www.aliexpress.com/item/33018362830.html
Though it’s a regulated 2.8A but if you get to swap to some direct drive drivers it’ll burn
Yeah, I’ve seen it but output seems to be not at max brightness. 5A would be nice. It’s gonna be used mostly as a high beam function on the roads/streets.
bump
I actually bought two of those dropin’s when they showed up last year. Nice but weak, I added 4 7138 chips to one of them and 4.3 amps starts to bring it out nicely. Does need wrapping, I used a thick soda can.
Are they available to be sold? :stuck_out_tongue:
Google 7135 and 7138 current control chips, lots sold. solder them onto the existing chips piggy back style.
