Driver is heavily glued… a little acetone and pushing the driver radially to sheer the glue worked in minutes… advise not to punch out thru the mcpcb hold downs screw holes…
Signal tube looks to be glued with a slight press fit…
Looks like an attiny44. I see a coil so hopefully this is a buck-boost arrangement. Any closer pics of the driver? Not necessary, I’m just curious about what they have going on here.
Question, will these lights accommodate normal flat top 18650/18350 batteries? The ones provided seem to be much longer with the included USB charging.
These lights were built excellently with great UI, so we may not have a lot of room for improvement and mod.
I would not do much for mine and would not mind if Manker uses glue on these.
However, please Do NOT use LOCTITE or heavy glue.
That being said these glues should be good for us.
Thanks KB. Attiny44 for sure. Can’t quite make out the power ICs, oh well.
Re: glue. It’s just the driver that’s glued in, right? I’m not a fan of glue, but I mean a little glue probably isn’t bad since there’s no retaining ring. I doubt I’ll pull the driver on this one anyhow. I’d rather have a small amount of glue than for the driver to be loose. /shrug
