[♛ FreemeGB] ASTROLUX MF06 CREE High Power Flashlight with Active Cooling - Not Quite there Yet
405 posts / 0 new
JordanZHP
Last seen: 3 hours 5 min ago
Maybe once MF05 starts shipping we will get an update?
Funtastic
Funtastic's picture
Last seen: 31 min 11 sec ago
interested
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
Nine9n1ne
Last seen: 5 months 4 days ago
in
jp9mm
Last seen: 6 months 3 days ago
freeme wrote:
MF04v2 will be known as MF05 model instead.
MF05 preorder will happen end of next month.
Active cooling “mini monster” is in pending state.
Miguel_79 wrote:
freeme wrote:
Haha, definitely not that fast. Maybe Dec if lucky.
Redlyne22 wrote:
September?!?!?!? It will be worth the wait. Im In
Any new news about this project? Or did they finally cancel it?
Is MF04 body not suitable for some reason? will it ever get a new emitter?
Don’t get why MF02 got sbt90 but they had to change body for MF04 to MF05?
JasonWW
JasonWW's picture
Last seen: 1 day 9 hours ago
They didn’t change the body they just changed the name only.
jp9mm
Head and body are completely different… MF04 vs MF05
http://budgetlightforum.com/node/70976
compare to MF04
http://budgetlightforum.com/node/61838
JasonWW
JasonWW's picture
compare to MF04
Oh, you want to know why they went with a bigger head and air cooling for a SBT-90.2 light instead of just putting that led into the existing MF04 body. I got mixed up.
I can only speculate that they wanted to build something better than the GT 90. Something that stood out and got attention.
I suppose a modder could convert an MF04 by swapping the LED in, replacing the driver with a FET unit and converting the carrier to 3 volt.
Yokiamy
Yokiamy's picture
Last seen: 1 day 10 hours ago
My assumptions are that the MF04 cant handle a SBT90.2 very well, where a GT is somewhat over dimensioned.
The MF04 is a lot lighter, which means less material, less thermal mass, less fins, less of everything, check the difference
JasonWW
JasonWW's picture
Your thinking the existing MF04 body could not handle the heat for very long?
Astrolux did make a MF02 version which is smaller. Lumintop even made a single 21700 version of the FW3A Pro light. So Astrolux could certainly put it in the MF04 head and it would work. Maybe they talked about their decision in a MF05 thread. It’s not likely to be mentioned here.
jp9mm
Even FT03 has SBT90 version, MF04 is mentioned in other thread but only response was freeme would like to see it done.
I just ordered the MF04 XHP35 version. Considering the large reflector and more reasonable cost i thought the body would be well on track to getting SBT90
Yokiamy
Yokiamy's picture
You are absolutely right, but do you know how the FT03s behaves?
After 30 seconds, you end up with a meager output of about 1800 Lumens, which is only 70 % less as where you started it with at a cold start.
Not to mention the fact that it plummets even more to an ashtonishing 150 Lumens after a couple of minutes
Please find the review HERE
Even the Amutorch XT45 which is cheaper performs better
Please find that review here
BOMBAY
Last seen: 4 hours 33 min ago
it’s the fault of the software shit and not the fault of the flashlight, you can restore the turbo and it will work at full power and for a longer time
freeme
freeme's picture
Last seen: 9 min 55 sec ago
SBT90.2 is not in their original plan.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
Yokiamy
Yokiamy's picture
Well, it wasn’t for the GT either, but it turned out pretty good.
The GT is just designed very well Wink
