[UPDATED M4D deal] Manker “EDC Muscle Combo – BLF Limited”
I third that.
I fourth that. :-D
Please dont EVER use glue!
I sixth that!
These lights were built excellently with great UI, so we may not have a lot of room for improvement and mod.
I would not do much for mine and would not mind if Manker uses glue on these.
However, please Do NOT use LOCTITE or heavy glue.
That being said these glues should be good for us.
Shouldn't you fifth that? :-D
I counted SKV89’s post as the fifth :smiley:
Dia. 35mm x Height to leg shoulder 23.4mm x Emitter dia. opening 7.8mm
Thanks KB. Attiny44 for sure. Can’t quite make out the power ICs, oh well.
Re: glue. It’s just the driver that’s glued in, right? I’m not a fan of glue, but I mean a little glue probably isn’t bad since there’s no retaining ring. I doubt I’ll pull the driver on this one anyhow. I’d rather have a small amount of glue than for the driver to be loose. /shrug
Manker can you tighten up the 3 Optic receiver (leg) holes in the MCPCB it would do well to tighten the Hot Spot up. Mine has the hot spot oblong and off center to the emitter, the optic can shift linearly to the mcpcb throwing it off to the emitter…. not really awful bad, but to me, it is sloppy… it could be improved upon…
Slight burrs on the punch thru holes…
Chamfered and a couple drags across a piece of Glassed 1000grt… cleans up well…
Just the driver is glued… acetone or a strong lacquer thinner will do the trick… wet to saturate, let it set a spell, move driver radially back and forth to shear the glue…
Vinh just uploaded a video comparing the L16, E10 and MC13. The manker looks very impressive assuming it’s using a 18350, can’t wait for this GB to go live.
Im in :+1:
Signed up! What an awesome set! :+1:
I’ll probably jump in. Really want to see the high runtime graph for both lights first though.
Does an unprotected 18350, like the keeppower UH1835P work in the 18350 tube?
Edit: oops nevermind, accidentally skipped a page and now see that Manker answered this question.
You will not see one anytime soon if ever. The GB closes on August 20. Maybe one out of the 75 or so orders from this GB might spend the time to do a run time curve but then you won’t be paying this price.
You can watch Vinh’s videos of these lights to give you an idea
Review is in progress on 1lumen:
So I’m hoping the review is almost done.
If the runtime graph looks like the FC11 it’s instant no go for me.
Is there any reason why it should? I’m not familiar with the runtime graph of the FC11 but they don’t seem to be similar or related lights in any way.
