thank you
I have not checked the tint, but knowing Cree it is a middle of the road 70CRI cool white. I did make a photo of the beam from a 40mm smooth reflector to check the Cree tint rainbow, and although it is there a bit, it is not half as bad as what we became used to in the last years with the newest Cree models. Here is the beam, the hotspot a bit overexposed to show the corona, not as nice as a XM-L2 or SST-40 beam, but as said not too bad either :
Thanks for the test Djozz. I like this one (if it isn’t green).
[Clemence]
Many thanks for the SST40 and XML3 test. It really does seem like the only new thing about the XML3 is the phosphor application, likely a more efficient/cheaper process for Cree. Since it is not a flip chip maybe there is not a lot of light escaping out the sides to excite the side phosphor, thereby avoiding the offensive tint shift in recent Cree LEDs.
Sort of what I expected. Glad the bond wires can survive max output, at least. Curious how they will do sliced and diced and if/when other CCT/CRI options show up… Honestly though I have nearly no real desire for these as is but still very thankful for your testing.
Thanks for the testing mate.
At higher outputs the SST-40 is at a lower voltage. In a light the SST-40 should out perform the XML3?
Yes, in direct drive it is easier to get maximum performance from the SST-40 than from the XM-L3, for the XM-L3 you have to take extra care to keep the resistances low in your flashlight build, even with struggle you achieve 7A max is what the numbers suggest. But then, 7A is a fine current IMO.
I hope it becomes available in warmer CCTs than the SST-40.
But even then what will be the gain over the currently available XM-L2’s?
Thanks for coming out of retirement to do these tests djozz. As usual your work is invaluable (I know you dont agree) in selecting leds.
Thanks Steve, I guess you are right that I’m sort of retired from led testing, the procedure has become a bit boring and I’m not as curious as I was before. And there are not as many really exciting new leds as there were a few years ago it seems, progress is slowing down.
But if a really promising new led appears I will probably test it again, i.e. I’m looking forward to DIY LEP components becoming available
Like, 200 lumens with FET, looks like. Maybe this one will come in 4000K 90+ CRI…
Oh wait, it’s Cree. Nevermind. Luminus will probably do HCRI SST-40 in warm bins first.
Thanks for the review. At last, proof that the single-die 5050 hasn’t evolved much in 6 years. I wouldn’t exactly call it an upgrade from the sst40. I think the 4040 would be of interest for innovation. Luxeon has three market cornered for that with the V, but Osram’s Boost HX is a very interesting emitter indeed.
I wonder why. The conclusions I’ve seen for 3535 footprint seem to indicate the footprint can only handle so many watts before all the emitters peak. But 5050 I’d expect to see a lot more from. Certainly the XHP50.2 3V has proven how much heat it can handle. But even the SST-40 doesn’t really do anything different than Luxeon V at 4040.
An explanation for that could be that the heat in the led itself does not spread sideways well and does not reach the edges of its thermal pad as easy as the middle. So if there is a good heatsink under the led the thermal handling is more determined by the die size than the package size.
Thanks taking the time to test these LEDs and share the results djozz. Being relatively new to the flashlight hobby just about the first thing I do when I encounter an unfamiliar LED is check your tests - they’re a fantastic resource.
Mouser has some U4 5700K's in stock: https://www.mouser.com/ProductDetail/Cree-Inc/XMLDWT-00-0000-0000U40E2?qs=%2Fha2pyFaduiteuA67J2OdsXxK1prd%252BHc7s8LT7qmCbfZ%252BOvlG%252BRwzoCzfBtgIwnn
U4 5000K's are expected in November: https://www.mouser.com/ProductDetail/Cree-Inc/XMLDWT-00-0000-0000U40E2?qs=%2Fha2pyFaduiteuA67J2OdsXxK1prd%252BHc7s8LT7qmCbfZ%252BOvlG%252BRwzoCzfBtgIwnn
Mouser has some U4 5700K’s in stock: https://www.mouser.com/ProductDetail/Cree-Inc/XMLDWT-00-0000-0000U40E2?qs=%2Fha2pyFaduiteuA67J2OdsXxK1prd%252BHc7s8LT7qmCbfZ%252BOvlG%252BRwzoCzfBtgIwnn
U4 5000K’s are expected in November: https://www.mouser.com/ProductDetail/Cree-Inc/XMLDWT-00-0000-0000U40E2?qs=%2Fha2pyFaduiteuA67J2OdsXxK1prd%252BHc7s8LT7qmCbfZ%252BOvlG%252BRwzoCzfBtgIwnn
your second link is to 5700k not 5k, dont expect 5k from Cree in XML-3
Ooops, yep. This is the full Mouser listing of XM-L3's: https://www.mouser.com/new/cree/cree-xlamp-xml3-leds/
But looks like the 5700K's which were in stock are out of stock now
Do you have them, or are looking to stock them at Cutter? It's an interesting LED coming from CREE, but compared to the 5000k SST-40, it's not quite there yet.
That Mouser page has part #'s down to 4000K, though not real yet.
Thanks. Good info. Just as suspected.
