Yup, you are correct, the one on the right side is a Lumintop Tool TI (AAA/10440, modded by CRX)!
The line is (left to right):
1- Nitefox ES10K (Stainless Steel, AA/14500)
2- hc-lights SS AAA (Stainless Steel, AAA/10440, similar to the BLF 348)
3- Amutorch S3 (Stainless Steel, AA/14500)
4- FireFlies SS AA
5- DQG AA Slim Ti (Titanium alloy, AA/14500)
6- Lumintop Tool Ti (Titanium, AAA/10440, modded by CRX)
Just wanted to report that my Enogear AA Stainless Steel just went dead one day (been like it since February 2020). It was mainly a shelf queen with very little to no usage and a Eneloop 2000 mAh. Turned it on and no light⊠checked battery with charger and battery was at 1.33 volts. Tried loosening and re-tightening tailswitch but no avail⊠if it did come on, it was intermittent and did not cycle between levels⊠nice looking âpoor manâsâ Haiku but sucks in reliability department. And no, I have not inserted 14500 into at all⊠Iâll have to place a tag with âAll Show, No Goâ on the clip.
I have some issues with my latest one as well, only inserted a new Duracell alkaleak.
It sometimes works as intended, but sometimes it just steps down to a (lower than low) level and i cannot increase the brightness again.
Sometimes loosening and tightening the head works, but the last time (when i needed it) it didnât and it stayed dim.
I ended up putting a FET driver in mine and SST-20 3500K but I am second guessing this decision since SS and tiny pill is not ideal for this. I turned the 219B in it originally blue instantly.
~400lm
In case it helps anyone here is the driver they are using as of this latest batch:
I tightened the retaining ring on the driver, unfortunately it made no difference.
I tightened the retaining ring on the switch assembly, which did make a difference, it seems to be working fine now!
I noticed that when completely disassembling mine to see how it worked. To fully tighten the tail retainer it ends up being just below the 2 cutouts for the lanyard and itâs not simple to fully tighten cause I think there is an O ring there for good measure.
