What type of light would you like the next BLF Special Edition to be? As in developed by us over a year or so from scratch.... like it used to be
You can see the archived poll results on the Wayback Machine:
https://web.archive.org/web/20221220093741/https://budgetlightforum.com/t/-/72888
This is all theoretical of course…. but if there were one. :wink: :stuck_out_tongue:
Haven’t seen much in the way of ‘real’ BLF special editions of late, at least not in the sense / number they were when I first joined. Back then there always seemed to be one on the go so to speak. Kinda miss it, but I know it’s hard work and a tonne of hassle.
Just wondered what you guys would fancy should anyone take up the challenge again…….
I tried to sum up groups as well as I could without having a million choices! there are certainly other types. I know a head torch was being talked about at some point. I have enough throwers I don’t use, and i do love a multi emitter light. I’d like a 21700 pocket rocket with aux leds/ usb charging.
A revamped FW4A would be good, like the next version? If that is possible. With charging unit inside or wireless charging, built-in AUX leds.
I agree with that, but I’d like to step up to 21700 if poss, I like a chunky monkey!
Disappointing that none of the options include a balanced, versatile beam. Just pocket rocket or thrower. Really says a lot about how much this forum values actual utility of a light.
I try my best to encourage manufacturers finally building (more) dual e-switch lights. While Andúril is unfortunately not (yet) compatible with two e-switches, I still think this will mean a major breakthrough in UI experience. Fenix uses this concept already but they still pursue a rather classic interface and light design. Especially, when we start to talk about multiemitter lights with different tints, different emitters, different mode groups, a second switch will be advantageous in many ways. I hope nobody minds if I use my "WK30S" example again, see illustration below.
That being said Anduril does support e-switch + tail switch, and I’d love to see it used that way in a thrower.
Yes, but the tail switch will only benefit from the momentary mode, if I got TK's words right. What I am trying to push is a real new UI, making use of two e-switches that can be independently programmed to carry out different functions.
Take it one step further and go dual e-switch + tail switch :slight_smile: .
I voted for multi-emitter (mixed colours). I think LP’s multi-emitter Flashlight Concept #1 will be great if that comes to life.
Yeah, honestly what I want is basically… Anduril SC64c LE (or SC64w HI). But to wait for the “Anduril 2.0”. I want it to be efficient, Buck/Boost Driver type efficient, with PID for the turbo modes.
Actually, here is what I really want, my “Dream” EDC light…
I want it to be the equivalent of the SC64w HI “CRI” 90+ CRI (like the Bob_McBob custom I have on order), Buck/Boost/PID, with Anduril 2.0.
But ALSO, I want to take the concept of the button AUX lights and repurpose it. I want the Button LEDs to be something like a quad-emitter of the high-cri AUX led on the Nitecore TIKI, to where the side button can be used as a full-flood headlamp. Maybe a quad E17 under the button?. I don’t know if that makes any sense. That way, I always have a full-flood headlamp/90 degree light, AND a throwy high cri EDC.
I may not be explaining this very clearly, but this would be, my ideal EDC. If I this could be had in different materials, such as clear-anodized aluminum, copper, brass, titanium, “natural” hard-anodized like Zebralight does (this would be my choice), etc. Then that would be awesome.
I know… dream big, right?
Edit: Actually, I would take this a step further, and also figure out how to do a boost-driver AAA size version of this, a “mini” perfect EDC, to use as my keychain light.
Nah, I’m good.
All of my wish-list items, I already have something close to it already.
I’d love to have a FW4A in 21700 flavor.
I’m high-en the stakes. Want 3 x XHP 70 and 3x18650. Or one with flat 2x18650 battery case, with 2 or 3 XHP 70 head.
I would like to see a “re-invention” of the human powered flashlight.
Most things I see on the market are low quality, with plastic gears, plastic case, fake emitters etc.
I am wondering what would be possible with modern bearings, brushless dnyamos, good optics efficient LEDs, super-capacitors etc.
How many watts can a human produce with his hand? I don’t know.
Add the Mateminco MT07 and the Emisar D18 and divide by two. Twelve W2 emitters, two 21700 or three 18650. 12,000 lumens, optics configured for a balance between flood and throw, so as to have a beam not too narrow, and throw not too low.
It’s just a rough poll, and having too many choices often waters it down so much the result is pointless. Generally reflectors/beams etc are thrashed out after the form factor is chosen, though I agree a balanced versatile beam is what we all want right? :wink:
I think the next BLF light should be
Whatever someone wants enough to gather support for, organize development for, get an interest list for, and successfully pitch to a manufacturer.
It’s a lot of work. I don’t think the development is going to happen based on poll results or even popularity. It’s going to happen because one person, or a small group of people, get really dedicated to a project and make it happen. Sure, it helps if something can generate a 1000+ name interest list, but it takes more than just that to happen.
I voted for a keychain light.
I'm thinking something similar to what Rovyvon offers, but at a more budget price.
EDIT:
I also like Multi Emitter - Short Range / Pocket Rocket because I cannot have enough of those.
+1
Something true EDC-able. BLF spirit in the pocket.
Let’s see … 23%. We won, poll can be closed :+1:
Single emitter, 16340, Anduril.
Anduril olight s mini / mini emisar
