“REVIEW”: On The Road Z821 - Zoomable – 1x18650 – 940 lumens [Pic Heavy]
59 posts / 0 new
MascaratumB
MascaratumB's picture
Last seen: 1 min 19 sec ago
EDIT on the part OUTPUT AND RUNTIME, added data of tailcap measurement provided by contactcr
Hi BLF!
This is my review of the On The Road Z821 flashlight!
I bought this flashlight in the “package” version in the end of June and it arrived in the end of July. The OTR Z821 is also sold in the “no package” version. Here are the (non affiliated) links for On The Road store at AliExpress:
Package: https://www.aliexpress.com/item/4001177537842.html
No Package: https://www.aliexpress.com/item/4001199114321.html
This flashlight is the updated version of the Z821, which is – apparently – sold in Fasttech (they have no stock, I wonder why Facepalm )
There are no internet reviews so far, as far as I know, and here on BLF the other considerations on this flashlight are on this thread.
So, let’s start this!
GENERAL SPECIFICATIONS
Body Colour: Matte “Chocolate”
Material: Aluminium
Emitter: XML2 U3 1A (Cool White)
Lens: Glass, Optical Aspheric (non AR Coated)
Battery: 1 × 18650
Switch: Reverse Clicky Switch
Reverse Polarity Protection: Yes
Low Voltage Warning: Yes
Max runtime: 160 hours
Max beam distance: 240m
Max output: 940 lumens
Candela: 14500 candela
Waterproofness: IPX6
Impact resistance: 1m
OTHERS:
- Constant Current Drive
NOTE: these are the specs as provided by the manufacturer!
THE PACKAGE, FLASHLIGHT & ACCESSORIES
Like the recently received and reviewed On The Road 311, the On The Road Z821 arrived in a “new package” from OTR, a white box with some information about the flashlight on its sides. Just to inform, the previous ones were square cardboard boxes, also OT branded. This one is nicer for a gift, IMO Wink
Along with it arrived the box for the battery charger, which comes in separate.
The “package” version of this light contains: On The Road Z821 flashlight, OTR branded pouch, OTR branded lanyard, a battery charger, a USB to USB-C charging cable, an unprotected 18650 3100mAh 3.7V 11.5Wh Li-Ion OTR branded battery, User Manual, 2 spare o-rings.
Both the outer and the inner boxes were sealed with an adhesive sticker!
The On The Road Z821 is a zoomable flashlight!
Yeah, I know many people here are not fans of “zoomies”, I also know that many people out there think that zoomies (specially those G700) are the best of the best of the best!
I am somewhere in between: I do like zoomies, I have some, I’ve gifted some, one of the lights that brought me into flashaholism is a zoomie light (Nebo Micro Redline), but I also know that they have many cons, and I admit that.
Despite that, I always wanted to have some nice, compact, push-pull zoomies, capable of fitting into a pocket light a “normal” EDC flashlights.
That is why got the OTR i3 some time ago, and that is why I bought the OTR Z821!
In my opinion, despite the cons that can be pointed out to zoomies, this is a good one!
It has “chocolate tablet” pattern knurling, just as other OTR lights, which is not very common on other brands.
In one side, it has the OTR logo engraved, while on the other it has the model engraved.
While extended / zoomed in, it can be seen a “1.5cm” scale on the battery tube, along with the flashlight serial number.
Unlike the old Z821 model, the head has no engravings, but it has some “teardrop” grooves and also an horizontal groove slightly below the bezel.
The bezel is a shinny one, but I am not completely sure if it is stainless steel. It is a bit “grainy” not completely smooth. It has no grooves (unlike the i3, M1 or M3 Pro).
Looking at the size and weight, well, this is not the lightest flashlight, but it is not heavy. Maybe slightly heavier than a Convoy S2+.
Also, in terms of length, being this an 18650 zoomable flashlight, I believe it is quite “compact” in the Zoomed out form Wink
This is how the flashlight looks like when dismantled. Only the MCPCB/led and the driver weren’t taken out.
So:
- bezel
- o-ring around the bezel
- glass aspherical optic
- thick “broken-on-purpose” o-ring
- smooth ”reflector”
- brass pill with an o-ring around it,
- 16mm x 1m aluminium PCB with XML2 U3-1A Cool White Led
- white plastic 5050 gasket
- driver with small flexible spring, pressed fit into a brass ring, which is fit into the pill’s bottom
- ”head” structure
- thin o-ring (that sits between the head and the tube and helps: a) sliding the head, b) “water proofing” (?) )
- batery tube with an o-ring (and with square or trapezoidal threads)
- brass retaining/housing structure/ring
- reverse clicky switch mounted on an OTR branded PCB with a thin but strong spring
- aluminium spacer (above the switch)
- rubber tailcap
- “tail” structure, with 2 lanyard holes
I’m tired Tired Big Smile
Looking to the head.
The bezel can be removed easily by pressing the light against your hand (with gloves, preferently).
The *”reflector”*…this was a difficult one! I scratched it a little bit. I advise to use thin tip pliers and not pointy tweezers to unscrew it, in case you wanna reach the led. Also, in case you wanna mod the light and use a ticker MCPCB, remember those “waves” on the bottom of the reflector, as they may cause short circuits !!
The optic of the Z821 aspherical. Below it sits a thick “broken-on-purpose” o ring that I believe it acts as a cushion for the optic an also to allow air movement (through it’s gap). But maybe I am wrong in this assumption…
As said, the Led PCB is 16mm x 1mm aluminium. A larger one can be used in case you wanna mod it!
As for the driver, it is a 17mm driver, that brings OTR newest configurable firmware !!!
The spring is thin but strong, as the inner space needs to be able to take longer and shorter batteries (which it takes).
There is a discussion on this thread (start reading here) about the advantages or not of using brass pills vs aluminium, in case you wanna look.
Be sure to be careful with this thin o-ring between the head and tube. It is very important to keep it lubed for a good sliding and water/dustproofing.
Also, it can be a PITA to put it back in place once it is taken out Facepalm
The tube inner threads, where the brass pill screws in may be a bit harsh in case you take it out often. Be sure to add some lub to make it less grainy.
Going towards the tail…
As mentioned above,a rubber tailcap and 2 lanyard holes, in which you can also put a screw-in pocket clip.
The threads are well cut, trapezoidal I guess, and arrived well lubricated as the o-ring* on this tip.
As for the rest of the structure, I had to use some thin point pliers, putting the tips into the PCB holes to make the structure unscrew. Nothing is glued, but it was really tightened!!
Advancing to the accessories, let’s start by the battery charger.
It is called UC3-PRO, it is supposed to do “smart charge” (whatever that means), and in the back there is an OTR logo in haut-relief.
The source can feed the charger through an included USB to USB-C cable. I don’t know of it can use USB-C to USB-C connection.
Input: DC5V 0.5-3A
Output: 4.2+- 0.05 1A
Operating temperature: 0-40ºC
It can charge batteries from 16340/RCR123 batteries up to 18650s. Everything in between in terms of length (not diameter!!! ) can be accepted/charged..
BUT, long-protected-button-top 18650s (like the Wuben red battery below) do not fit!
The charger has red led to indicate charge in process and a blue led to indicate charging complete!!
Being so light and capable to charge 16340s, 18350s, 14500s,10440s and 18650s, this is a good travel charger Wink
As for the battery included in this package, it is the unprotected flat top ORB1831 / INR18650 / 3100mAh / 3.7V / 11.5Wh / Li-Ion / OTR branded battery in a yellow wrap! I am not sure what can be the original battery below the wrap, but I know it is not a Sony VTC6 Silly Maybe it is an LG… !
This is how it fits on the flashlight!
Well, I don’t have much to say about the menu. It is written in Chinese, and I can only get some numbers from there.
As this light was only recently put for sale on AliExpress, being the Chinese market OTR primordial market, I believe they were not looking to make it in English. I hope they will do it soon Thumbs Up
As the other lights I have, this one came with a nice protective pouch to carry the flashlight. I like it Wink
USER INTERFACE
Although it is not stated in the products page, the box has some information about the UI being configurable.
It is the new OTR configurable firmware which is also present on the OTR 311 flashlight.
It has 3 group modes. Using the brand’s “naming”:
A – Ultra Low > Low > Medium > High + Strobe or SOS or Beacon
B – High > Medium > Low + Strobe or SOS or Beacon [default group mode]
C – High + Strobe or SOS or Beacon
BLINKING MODES always flash/blink in the highest output
STROBE: single frequency
BEACON: flashes maybe each 1.2 seconds
SOS: is quite fast, and then has a 5s pause to restart the new blinking
OPERATION:
1 – Turn ON / OFF : full click the tailswitch
2 – Change output levels in any group mode: while ON, tap the tailswitch
3 – Engage/Disengage Strobe: while ON, quick double tap to activate Strobe, and a single goes back to the regular level
3 – Engage/Disengage Beacon: while ON, quick triple tap to activate Beacon, and a single goes back to the regular level
3 – Engage/Disengage SOS: while ON, quick quad tap to activate SOS, and a single goes back to the regular level
The flashlight has memory for the last used mode, except the blinking modes.
However, on Group modes A and B, a quick turn OFF > turn ON (within 3 seconds) will advance to the next level. If the flashlight is OFF for more than 3 seconds, the last used mode will be memorized.
NOTE: really quick full clicks (OFF-ON-OFF-ON…) can activate Strobe, Beacon or SOS.
Perhaps the most “complex” part of this flashlight is on “how to alternate between the group modes A, B and C”.
After contacting the store, here is the answer:
1 – Turn the flashlight ON in HIGH level (in any group mode)
2 – Enter STROBE for 5 seconds or more
3 – Tap to go back to HIGH (1st)
4 – Enter STROBE again (doesn’t matter the time)
5 – Tap to go back to HIGH (2nd)
6 – Enter STROBE again (doesn’t matter the time)
7 – Tap to go back to HIGH (3rd)
8 – Enter STROBE again (doesn’t matter the time)
9 – Tap to go back to HIGH (4th)
10 – Enter STROBE for 5 seconds or more
11 – Turn the flashlight OFF
NOTES:
1 – During this operation, never turn the flashlight OFF or it will “cut” the configuration process.
2 – The initial and final STROBES must really be ON for 5 or more seconds, otherwise the configuration will fail.
3 – The changing between the group modes will start from the default group mode (B), then C, then A, then B… .
4- As pointed out above, and just to be clear, group mode A advances from the lowest to the highest level, while group mode B advances from the highest to the lowest level
OUTPUT AND RUNTIME
As I can’t accurately measure these, I will rely on manufacturer’s information (using their 3100mAh battery and a XML2 U3 led). This will change with different leds and batteries, of course.
UltraLow Low Medium High
OUTPUT 4 lm 150lm 390 lm 940 lm
RUNTIME 160h 11h 4h 1h40m
NOTES:
Assuming that this driver works as the one in the OTR 311:
- the light will flash if the battery is below 5% (I didn’t test this yet. I normally charge the batteries when I feel the light is more dim than usual).
- fast charging is possible, reaching 90% capacity in 140 minutes. Full charging cycle is around 4hours. (NOT SURE IF THIS IS TRUE, I CAN’T READ CHINESE Facepalm )
*EDIT*(16th August)
Tailcap measurements
Data provided by contactcr
Quote:
Bypassed tail measurements:
Sanyo NCR18650GA 3500mAh
UL = 13mA
L = 265mA
M = 732mA
H = 2.60A
So…let’s go for a flashlight comparison.
Vs FW3A & Convoy S2+ Desert Tan
Vs some of my zoomies collection Big Smile
Vs Livarnolux 314951 & Livarnolux 314791 (2xAA zoomable flashlights from Lidl)
Vs RovyVon Aurora A23 & RovyVon Angel Eyes E200u (they all arrived at the same time Silly )
Vs my “Lego” of OTR M1 (down tube/tail) and OTR i3 (upper tube/head), a thin 16650 zoomie flashlight Grad
Vs the OTR family: M1, 311, Z821, M3 Pro, i3
No PWM on the 4 regular levels.
And let’s take a look at the beam pattern and level’s progression!
This was made at 1m from the luxmeter (set on Lux), just for exemplification purposes!
This is a comparison between the OTR Z821 (left, XML2 U3-1A) and the OTR i3 (right, with Samsung LH351D 5000K 90 CRI). Please note that the i3 is already modded, both the driver (MTN 15mm DD with Crescendo FW), the led, and also the reflector and lens (blackened to avoid artifacts).
Some outdoor beamshots now!
This light, stock, can reach around 200m. I wasn’t able to test it in “pitch black” conditions, but I can assure that it reaches those distances.
The beam, while zoomed in, has some artifacts, namely rings, and the shape or the led is “visible”, which means it is focused to the point (wether it is good or not!).
While zoomed out, the artifacts are less, but there is still one outer ring, almost imperceptible, maybe due to the reflection on the bezel. This can be reduced with some blackening on the reflector, lens, and bezel.
On max, zoomed in:
40m
180m (farthest field)
220m (top house)
210m (house/street light)
That ring I told about when zoomed out.
Direct comparison: Zoomed out > Zoomed in
Close distance:
16m:
45m (trees):
Close range (Z-OUT) vs 100m Distance, farthest tree (Z-IN)
OVERALL APPRECIATION
I bought this light because I wanted to have a compact 18650 zoomable light! And it was what I got!
The flashlight has modding potential, but it can already be “ready-to-use”, in case you want to.
What I like:
- Overall quality, in particular anodizing and machining!
- Shape, size and compactness, and I’d say elegance, for a 18650 zoomie!
- Accessories included, as you get all you need and more! Well, except the User Manual…
- Configurable User Interface, because it offers more options of usability.
What may bother me:
- Memory mode, for the group modes with more than 1 level
- Possibility to accidentally activate Strobe when tapping faster to change modes (Beacon and SOS are “more hidden”)
- Long process to alternate between the group modes
- Some artifacts on the beams (nothing that other lights, zoomable or not, don’t have)
Modding plans?
- led4power driver 4A-6A
- Osram White flat (not sure if W1 or W2) + appropriate gasket
- blackening reflector and part of the optic
- Eventually: forward clicky switch
- Eventually: screw-in pocket clip
Thanks On The Road store at AliExpress for putting this light on sale Wink I wish people would chose better zoomies as this one instead of those cheapo bulky ones, but…to each its own… Silly
Keep up the good work! Beer
If you folks have any question or comment, let them come Thumbs Up
Edited by: MascaratumB on 08/16/2020 - 10:11
MRsDNF
MRsDNF's picture
Thanks for the terrific review MascaratumB. Beer
NeutralFan
NeutralFan's picture
Last seen: 2 days 9 hours ago
Great and very thorough review! The On The Road Z821 is a good looking flashlight.
I’d rather use my flashlight around the house than turn on the lights.
hank
hank's picture
Last seen: 1 week 5 days ago
So it’s not meant to operate below zero C — which is 32 Fahrenheit, freezing temperature? That sounds pretty strange.
And it’s good up to 40C, which is 104 fahrenheit. Hmmm.
MascaratumB
Thanks for your words MRsDNF Wink
Thank you Neutral Fan Wink
Yes, it is indeed a good looking and nice hand fitting flashlight!
Thanks for looking Wink
Well, as far as specs concerns, it is that way Wink
Maybe it is due to any component inside or something. I will not opent the charger as it is glued/press, no screws. Otherwise I would show how it looks to see if it is anything physical that “hinders” that Thumbs Up
Anthony Nguyenn
Anthony Nguyenn's picture
Last seen: 9 months 2 weeks ago
Great review as usual MascaratumB. I am usually not into Zoomies but this seems like a decent one.
I just dont understand the thought behind that not include pocket clip. Even worse, I do not see where to mount one if I want to. Poor design choice I guess.
Dont get me wrong, the including pouch is nice but it wont get much use if I cant carry in my pocket when I need it.
Lumintop Tool AA 2.0 Nichia + CW| Lumintop Tool AAA | Lumintop EDC 18 6500k| Lumintop EDC 01| Convoy S2+ 7135*8 5000k | Convoy S2 UV Nichia |Massdrop Vega AA NW |BLF A6 NW | Nitecore Tube 2.0 | Sofirn SD 05 | Sofirn 01S 4000k| Klaurus G15 | Klarus HR1 Pro | Thrunite T10T v2 NW| Thrunite T1 Black + OD Green | Thrunite Ti3 CW+ NW| |Rovyvon A3x Nichia | Rovyvon A5x Cree | Rovyvon A23 Nichia | Wuben E19 Nichia | MecArmy SGN 6 | Wowtac BSS V4 | Wowtac W1 | Wowtac H01 | Ultratac A3N Nichia | Wurkkos FC11 |  Wurkkos WK30
Thrunite T2 |
MascaratumB
Anthony Nguyenn wrote:
Great review as usual MascaratumB. I am usually not into Zoomies but this seems like a decent one. I just dont understand the thought behind that not include pocket clip. Even worse, I do not see where to mount one if I want to. Poor design choice I guess. Dont get me wrong, the including pouch is nice but it wont get much use if I cant carry in my pocket when I need it.
Thanks for reading and for your words Anthony Nguyenn Thumbs Up
About the pockect clip, I will install mine in the lanyard holes , just like a if it was a Convoy S2/S2+. The holes distances are relatively similar to an S2/S2+ . The screw-in clips sold in Convoy Store (and many other online stores), will fit nicely, I confirmed th distances.
OTR normally includes clips on their lights, but I actually like that this one doesn’t have a groove for the clip, it makes the light more “clean”, if you know what I mean.
The pouch is sweet, but I agree it is not for a quick flashlight draw.
MascaratumB
@ Anthony Nguyenn
In the name of flashlight science Glasses Grad
The example I gave:
Thumbs Up
contactcr
Last seen: 14 hours 38 min ago
Mine came with group A default (4 L-H modes w/ hidden strobe, memory enabled)
UL = 13mA
L = 265mA
M = 732mA
H = 2.60A
Feel free to add to review if you want.
My initial impressions with just a few minutes of handling:
The size is awesome, nice and compact!
Anodizing and machining very good.
Focus appears to be good.
Host warms up quick which tells me thermal path between pill and body is good.
The packaging is very good and everything is sealed as if this light is sold in retail stores. (maybe some Chinese REI type place?)
Given how compact the host is I will have to temper how far I will hot rod this light. I dont think it’s suitable for maxing out a 2mm2 white flat but maybe ~5A is good enough. The springs will have to go when it’s modded, they are quite thin.
Assuming mods go as planned this appears to be a very good 18650 zoom light. Granted it’s a huge leap in price from typical shit zoomies it seems to at least be a huge leap in quality above them too.
Shipping time to US: ordered, 30 June, arrived 15 Aug. I guess Singapore > US transit still a bit slow.
contactcr
I’m not proud of this soldering and it’s only temporary until I change the driver but I wanted to see what i’m in for. They barely left enough LED wire to even account for the extra 0.5mm MCPCB thickness Facepalm
It goes from about ~15kcd to ~39kcd keeping stock driver and putting 3030 2mm^2 white flat (CSLPM1). I used a 3030 gasket I think I got from intl-outdoor long ago and it’s a perfect fit.
To be continued
MascaratumB
contactcr thank you very much for your input on the tail current measurements! I am on the phone, so it will be easier for me to edit post#1 in the computer!
Also, thanks for showing your mod-in-progress! That leap on candela is quite wow, just with the stock driver. I assume a different one will make it rise even more, be it at 5A or more!
BTW, did you have and issue with the MCPCB height vs the “reflector” and the contacts with the solder, or do they stay out of contact?
Also, unless your driver is different from mine, the UI should have Strobe / Beacon / SOS as special modes with 2, 3 or 4 multiple clicks from ON. I wish memory could be configured to stay off… Tired
Again, thank you very much for sharing your words, mods and measurements Wink Smile Thumbs Up
And show us the rest meanwhile Wink
contactcr
I’m using a plastic centering ring so its probably half or 1 thread less screwed on but still putting pressure on whole pcb by way of that gasket. Not sure how close it is but I had no problems. For the final assembly I may use kapton tape or may not..
Mine has strobe via double click but came default as the 4 normal modes.
Hard to tell if the .5mm from pcb effects focus or not. It’s pretty defined but this LED has very even die so you can’t look for dots or bond wires to be sure
contactcr
For me, it’s not really modding unless you break something, so here is tonight’s sacrifice:
I thought I could pry the board out first. Nope (well yes, but not recommended) it’s soldered on the other side of the press fit ring.
Oh well, I took apart a perfectly good modded S2+ to gut the driver and MCPCB. I planned to do it anyways but still I hate taking working lights apart cause more than once I just end up with two not functioning lights. Desperate times since LED4Power is on hiatus.
Filed down and pressed into ring, lightly soldered. Ring then pressed into pill, no solder:
Might as well get that tail spring too:
Gotta have that temp sensor. Sad part is I re-flowed the LED cause I feel more confident doing that (on a 3535 board no less) than transferring the NTC from board to board.
Gasket with side clipped, pretty sure from intl-outdoor. It’s probably not ideal cause the “reflector” (MascaratumB’s word) only screws down about half way. Ideally it would be sanded down some.
Tail wont go on, springs are too long, ugh. Button maybe?
Nope, not enough. Tail has to change too:
It turns out this tail is partly why the light is so compact. The tail legos with an S2+ and if you hold them side by side you can see a few mm difference. This light will likely never fit anything but flat tops. It also explains why I initially thought the original springs were so thin and cheap because they have to fully compress to fit a normal battery.
End result:
I set the driver to around 5.3A and measured 63.4kcd
If OTR is lisenting: add another ~1.5 – 2.0mm to the tail cap and get better springs on both ends.
luminarium iaculator
luminarium iaculator's picture
Last seen: 40 min 34 sec ago
MascaratumB & Contactcr
Very thorough review and nice mod Thumbs Up
So 63 kcd means that it should be close or hit 100 kcd with WF1… That is good result for such light. It could be better(up to 20%) though if they will ever redesign aspheric lens (larger aspherical surface and smaller lens edge, and current is small aspherical surface and too much of “edge” on aspheric glass) .
Yes this is very rare China light that is usable out of a box(nothing special) but it demands modding for wow effect.
It is bit to expensive IMHO for factory version. But if they will ever learn to properly make the light(not just OTR, most China manufacturers) and that means if you are saving on emitter at least put freaking DTP board into the pill!(why they want to save 0,5$ on DTP board?)
This light should be ofered as a host, and it should not cost more than 15$(even that would be bit to much).
MascaratumB
@ contactcr
Thanks again for your input on the modding process Wink
About the centering ring, that also happens with me on the i3, the “reflector” (IDK how its is called, sorry) doesn’t screw all the way down Oops I didn’t have capton, I used electrical tape, even if nor ideal.
On the mod, did you took the retaining ring of the driver out? It seems that it can be taken out of the pill throught those small holes in the side. I’d like to “maintain” the integrity of the original driver, it can be worth to make another mod Wink
Normally I don’r solder any temp sensor wire to the led MCPCB Big Smile Am I doing it wrong? Party
Or does it have to do with the type of driver you have?
I’ll put a L4P driver as well, but normally I don’t add those special temp things (I don’t actually know how to work with that Silly ), hence my question.
Quite an improvement since the original measurements. A W1 would probably get some more intensity, but the W2 also seems to project the light far away Wink
Well done Wink
And BTW, you did a pretty clean job in the mod, I am very messy with this stuff Facepalm
I may need to start thinking about a new spring for the spring, maybe the original is too thin afterall Tired
@ luminarium iaculator
Thanks for your words! And I hope you are enjoying your light as well.
BTW, did you see the YAGE zoomie light that is pretty similar (although bigger) than this light on AliExpress? It is sold, the complete light for around 7€. It probably has aluminium pill and acrylic lens, and despite being bigger, it still seems a compact zoomie at a nice price Wink
MascaratumB
BTW, this is that YAGE I mentioned above.
(which is more similar to the old Z821)
https://www.aliexpress.com/item/32706398683.html
contactcr
I did take the ring out eventually. I think using heat/cool and something small and stiff (stainless something) you can pry ring gradually from either side. If I had to do it again I would do it that way and try to push driver out of ring while it’s on hot plate or something.
It’s not necessary to function. L4P driver has temp sensor on driver and also this NTC connection for supported PCB. The MCPCB temp steps down at 115C or something while driver temp steps down sooner, 65C or whatever custom setting. I think it’s a more accurate way to do step down based on MCPCB temp though.
As for how “clean” everything is here is my tip: old toothbrush + alcohol and just dip toothbrush and scrub anything and everything.
MascaratumB
Thanks for both replies contactcr Thumbs Up
I guess taking out the ring will be better then. I know thus is their normal setting , so it will be better than pushing the driver from the top.
Also, thanks for the info on the driver/MCPCB temp sensor. All the lights I have with L4P driver don’t have that wire, it is always based on the driver itself. Maybe I’ll give it a try this time Wink
Quote:
As for how “clean” everything is here is my tip: old toothbrush + alcohol and just dip and scrub anything and everything.
Ahah, best tip Wink
But I was also complimenting your solder skills. My wire soldering to the MCPCB, driver and spring can become quite nasty, that not even a toothbrush can clean it well Silly
Thanks again for sharing this!
contactcr
If you try temp sensor make sure mcpcb is populated with that tiny resistor at bottom or else it won’t work
MascaratumB
Sure, I will ask led4power to send it with the resistor when he opens the store again Wink
!{width:70%}https://ae01.alicdn.com/kf/HTB1.FxqeDqWBKNjSZFAq6ynSpXao.jpg!
You mean on Hawkeye Focusing Fighting tactics light LOL They do exaggerate in description and I can bet they have hollow aluminium pill ass seen on plenty of models plus clasicc non anodized threads with crappy no name press fit switch (you know those white plastic switches with brass cover for spring?)
But maybe I am wrong…
No matter for pros and cons OTR Z821 is one of the best commercial available 1×18650 zoomie in a world. But still can’t you tell to OTR that it would would be quite fair that they put Osram White Flat inside with DTP board? That way 30$ price would be approved.
Lead group buy for OTR Z821 with mentioned ingredients and I am sure you’ll collect 500+ buyers in no time…
MascaratumB
Hum, I’d be very surprised if you weren’t wrong about that Big Smile That is one of the reasons why this OTR stands out, even in “comparable” flashlights Silly It is not funny to mod one of those press fit switches Oops
Nor to add a shelf to the hollow pill Big Smile
No matter for pros and cons OTR Z821 is one of the best commercial available 1×18650 zoomie in a world. But still can’t you tell to OTR that it would would be quite fair that they put Osram White Flat inside with DTP board? That way 30$ price would be approved. Lead group buy for OTR Z821 with mentioned ingredients and I am sure you’ll collect 500+ buyers in no time…
I guess I’ve said in the Zooming Model list thread why I will not run a GB !
Please don’t get me wrong, but I guess that till now we’ve seen that OTR has a specific market (China), and normally they have very “specific choices” in what concerns leds. XML2 / XP-G2 has been their longtime preference.
The change in user interface, adding configurability, may be an opening in perspectives, but I am not sure how open they would be to invest in new Leds. Maybe I’m wrong this time.
Also, communication is sometimes not as “fast and clear” as needed to do a GB.
More than that, I know that besides that led, people would start begging for “this and that”, with W1 or W2, package or no package, and… I honestly don’t have the time or patience to negotiate endlessly. I do appreciate the work, time and effort that people running GBs and BLF projects have to make things “real”!
BTW, this is the only “pseudo-GB” that I ever ran here on BLF. It is sure that other things got in the way by that time, but I’m not tailored for that kind of organization.
OK… But for that price it should at least have DTP MCPCB Facepalm
UL = 13mA
L = 265mA
M = 732mA
H = 2.60A
Yes I had such results so in fact that is moonlight, ultra low, low and high… Middle mode is missing as I said in mine small review about month ago here. It should have middle mode at 1.8A current draw.
MascaratumB
I will ask them if there is any possibility to have some of the changes suggested, be it the DTP or even the Osram Wink But, I wouldn’t count with too much opening for that on their side.
About the data, sorry, I forgot you had measured it before Facepalm
I linked your post above on the review, but I didn’t pay attention to the measurements.
Well, with the numbers, it becomes more obvious that the distance between medium and high is less “visible” than at sight (eyes, in this case). I believe they don’t want to push it “too much” to allow better runtimes, but it sacrifices some output Oops
BTW, yesterday I modded the Z821.
Like contactcr, I dismantled my Convoy S2 that had a led4power 4A-6A driver and Osram White 2 and put it in the Z821 Party
Whaaaat?!! I couldn’t wait till led4power reopens the store Silly Big Smile
I also replaced the tailswitch, for a forward clicky switch. I used the PCB & spring of the OTR M1 and soldered a FC switch bought from Simon. Tailcap is orange and fits better in colour.
I also added a screw-in pocket clip, that I “torched” a little bit to be more suitable in colour Wink
On the head, I blackened the “reflector”, and as I didn’t have any suitable gasket, I added electrical tape and also GITD tape around the led to avoid contact between the solder and reflector, and also to avoid a ring around the led (every gasket I had was creating that).
Still, despite this, there are still artifacts
I must warn that: I like the throw and output with the W2, but I guess I will replace it for a W1 later, because the rectangular shaped beam seems a bit awkward, at least indoor.
Also, I had to change the driver to CC instead of DD (even at 4A) because with a full battery the highest level was turning into BLUE Shocked CC solved the issue, so beware of the configuration you use in this light!
Some photos below.
contactcr
Hmm yours is turning blue with constant current set to >4A?
MascaratumB
It was, on Direct Drive and fully charged battery (literally taken out of the charger).
Can it be some problem with my setting?
contactcr
Oh with direct drive I am not surprised. I misread your post as anything above 4A turns blue.
Did you take any measurement of throw or try higher CC setting like 5A?
MascaratumB
Well, funny thing is, I had it on the Convoy S2 with DD configured and it never happened Oops
It was turning blue even at 4A with DD. With CC it is normal Wink
I can’t make measurements, I don’t have a clamp meter and my DMM can’t read too (no fuse Facepalm ).
But I have it now configured to 5.5A, CC and so far no problem.
Also, when it was on DD, it got HOT in seconds (with full battery of course), and with CC it doesn’t heat that fast Wink
contactcr
“turning blue even at 4A with DD”
If enabled, DD is not limited by your settings in the driver config. It replaces the highest mode and acts like FET driver on turbo.
For testing I mean just lux meter test at like 5-10 meters. Clamp meter kind of pointless with CC driver Smile
MascaratumB
Stupid me Facepalm I read it on l4p thread some days ago and completely forgot it Tired
That’s the reason why it was turning blue… Facepalm
Ahh, lux readings! well, I don’t have many conditions in my house, but later tonight I will try to measure it at least at 5m. I will post what I have then Smile
The clamp could be good to check if it was in FET, with the OTR battery (to compare with other battery) Wink
Yes it could turn blue because when DD it will draw around 14A of current!
Thanks to L4P I was probably first person in a world to test this White Flat 2 emitter with my redneck test(battery, lux meter, clamp meter tail readings) which is not so accurate as pro equipment but it is telling certain values:
http://budgetlightforum.com/node/63255
Samsung INR 30Q FET Driver:
4.2V, 13.4A, 930 FC
4.0V, 12.5A, 950 FC
3.9V, 11.4A,1050 FC
3.8V, 10A, 1250 FC
3.7V, 9.20A, 1200 FC
3.6V, 8.20A, 1150 FC
3.4V, 7A , 1100 FC
It really is beautiful emitter but it will never go to mine single 18650 configurations because for best performance it should be hard driven.
And when driven on 4.5A old dedomed XPG2 will be better performer.
WF1 is different story… Only flaw is that it is very small emitter for larger aspherics but it should work more than fine in this OTR.
And man you gotta get yourself lux meter and clamp meter (30$ of investment).
Oh forget about that now I see that you have lux meter Beer
BTW I have same light meter as you. Try to switch to FC mode. That way it reads much more accurate and it is very easy to convert FC to lux online.
5m measurements and convert…
