There’s also the Jetbeam RRT01, which I like more. It has only a control ring, no tail switch. So, no need to flip it around during use to access two different controls.
The Nitecore SRT series may be of interest too. Or the HDS Rotary.
Lights with a single e-switch are popular because they’re relatively easy to make, facilitate full-featured interfaces, and can run existing firmware.
Having a more-physical interface is nice, but significantly harder and more expensive to make, and usually have fewer features.
There’s a similar dichotomy for musical synthesizers. The most powerful ones also tend to have the lowest price, because they are basically just fancy software running on a computer. However, these are not very playable as an instrument, because half the point of an instrument is that it has a physical form. So people buy synthesizers which are more expensive and less powerful, because they have the benefit of being hands-on. The most popular (and most expensive) ones tend to be “knob per function” designs where every parameter has its own physical control. These often have only a small fraction as many features, but every feature is fully exposed in hardware… which is a huge benefit for anyone actually performing music on it. No menus, no modes, just grab a knob or slider and adjust it.
Neither style is bad… it’s just a matter of tradeoffs.
Something with an interface like the Jetbeam RRT-01 (and other related flashlights) would be pretty difficult. Do I think it’s beyond the collective ability of BLF’s members? Absolutely not. Would it happen? It’s unlikely. It’s a pretty challenging task, especially to do well. And to be worth doing, it would have to be better than RRT-01. More power? Smaller? Better heat handling? Something. And we’d have to try to maintain water resistance and hope there’s no patents we’re unaware of.
Yes, smaller. We have currently a lot of votes for a small light and a head lamp. I know the CRX magic, have one of his lights. Not sure this can be done in mass-production. The V11R head is already very small, so this is a proof it can be done.
Yes, an updated A6, with USB charging, decent heat sinking (unlike the FW series), range of tints, and user interface with momentary, last mode memory (and preferably variable strobe frequency) would make me happy.
Reflector, TIR, aspheric (maybe even fixed aspheric)?
Single-emitter or multi?
Almost certainly e-switch, but what UI? (I love Anduril on a headlamp but not everyone does)
But is the switch on the top or on an end?
I’d say emitter choice but Simon and Hank offer just about anything in just about anything these days.
If you want to get even crazier, we could talk about remote battery packs. 2x18650 on the back of the head! One 18650 on the neck to keep it warm!
Maybe the best thing we could do is get something close to the D25S, but designed to fit the really common TIR optics for singles and triples, and sell a spacer for the triple builds (or make it fit the S2+ spacers out there already), and a 17mm driver so everyone can pick their favorite driver for it.
What about something the size of the Ft03 with interchangeable heads……one with a dedicated thrower led and the other with multiple leds for flood purposes.
If it is a headlamp there should be UI to fit most. Say one multi-click, multi everything mode for guys who like to play with their flashlights and a simple click-on/off, hold to cycle mode for the rest of us. Call it advanced/simple or nerd/muggle
For a headlamp, I’d love to see something almost tube-shaped. Battery inside, driver and e-switch on one end, tailcap on the other end… and 2 to 8 small LEDs in a straight line along the side in very shallow reflectors. Perhaps E17A or E21A emitters. Floody, high-CRI, and a driver regulated to a moderate power level.
It’d probably be 18650, though 14500 might be feasible if the parts can fit on a smaller driver. Ideally it’d be designed to be pretty lightweight, and would come with a head strap which uses loops to fit two grooves near the ends of the light.
If there’s room for 4 / 6 / 8 LEDs, it could use two color temperatures and do tint ramping between.
Possibly also a T-shaped model with a throwy LED and larger reflector in the center, between two floody LEDs in shallow reflectors. Ramp between flood and throw in a manner similar to tint ramping.
I would like to see a 26650 foldable worklight like the ones with COB but with Nichia optisolis, in aluminum for durability (no fear of bumps in a toolbox). Strong magnet (removable), tint ramping. USB charging with a port that could be used to power the worklight without battery.
I was worried about my Boruit D10, which has a a reflector, though smaller than what you’d find on something like a Convoy S2. Between using an XM-L2 and just how small the reflector is, it’s a pretty good beam for anything but the closest work - and that could be solved with a pebbled TIR. I’m worried about swapping to XP-sized emitter, but I’m after some CRI.
I’m sorely tempted to get a D25S and mod it as well, and maybe try to tint-mix the two emitters. So, four or six emitters sounds nice - I think by the time we get to 8, it’s probably pretty pure flood, like some of the COB headlamps. My biggest concern with going floody on a headlamp is keeping it useful for walking on a trail at night. But, I’m sure BLF would find a nice balance.
Uh, so anyway, the point I was getting at before I started rambling was, that sounds closely in line with what I want out of a headlamp.
I’d like to see a 21700/SBT-90.2 pocket rocket. But done on a system like the MEOTE FM1 up sized to 21700 with SST20/XPL-HI/SST40 quad heads and XHP50.2/SBT90.2 single LED heads.
Option 1: I am for a head tourch as well. Pure flood for close up work, maybe with a”turbo” option for a bit of wall of light. Singld cell - 18650. Since its for close up work, something with high CRI and good realistic colors. Multi emitter with high CRI. Either with no reflector, or one that shapes the beem to like 90° +/-. No intense spot. ToyKeeper mentioned E21A emitters. I heard those have good colors.
Option 2: Similar headtorch as one, but with some form of focusable reflector/lense setup. Maybe some form of zoomie. Or some new interedting form. Something good for close pure flood work, that can be switched and turned into focuse beam. Maybe a magnetic snap on attachment that turns the flood torch into a more focused one? Maybe there could be interchangable reflectors and filters for multi purpose head tourch
