These are normal blue 450nm based white leds so they have their 450nm spike which is needed as part of the visible spectrum to form the CCT/CRI, nothing extraordinary here compared to other leds, that is simply how they work. A few manufacturers recently came with new types of leds with 420nm base leds or with double dies, reducing the blue peak and filling in the cyan gap, but those are far from mainstream yet and none of the regular leds used by BLF have that.
So what? It is the base led, the phosfor converts almost all of it to make the rest of the spectrum. Look at the spectrum of these leds and you see that the remaining small 420nm peak is hardly higher than the 420nm level of any incandescent or day light of the same colour temperature. Which implies that you are afraid of most natural light sources too (excluding maybe camp fire light) which is not very practical in life unless you are dedicated to spend your life inside under a edison bulb at 2500K.
I wish you will test one day these 420NM Leds
from unknown brand,so we’ll know if they’re safe.
Afraid? I already take enough natural daylight,don’t need more UV-A on night
*UVA is the least harmful type of UV
*420nm is not even UVA
*the 420nm region is a small part of these led’s spectra
*people who are frightened of blue peaks should have a look at light levels before getting afraid of a certain light source.
Quick calculation: the 5mm leds at discussion here at 20mA produce about 50 lux at 0.5M distance, which is shining a flashlight at yourself at an arm’s length. Let us assume that it is just as harmful as daylight (which is not true, it is much less harmful because it contains 0% UV, but ok) and you expose yourself directly to this flashlight for two scorching hours That is equivalent to an exposure of about 3 seconds of sunlight (130 klux).
I liked when swiched on ,CFL bulb increased bright gradually was pleasant near bed
but they took too long time to arrive at max.
Does there are a sort of fast auto dimmer (1-2sec.) on modern Led bulbs
Or similar to put on wall box for inca. lights?
There is a thread dedicated to the blue light topic that would be a better place for a detailed continuation of this tangent.
As a couple brief comments, though: I second djozz’s observation that the spike shown is very typical. For example, in the top part of image here is a spectrum of a 4500K Nichia 219B (from Maukka’s Fireflies ROT66 review) of the same color temperature. It’s very similar in the location and relative scale of the peaks and valleys:
I’ll leave off my other thoughts on the topic, and simply note that based on the research I’ve read: if in doubt, there’s certainly no harm in erring towards lower light levels as the first priority, lower color temperatures as the next priority, and high CRI as a final priority to reduce blue light exposure. However, I have not seen research that indicates the typical narrow spike is worse than the more spectrally distributed but similar total energy of blue emission in an idealized black body.
Posted this on reddit a week ago or two, but here's what's in my collection. In the case you're wondering about it, yes, all the emitters in the picture here are at least R9050/R9080.
LiFePo cells start off at 3.6V fully charged, that will push enough current through these leds to kill them (see the current/output/voltage graph in the OP)
Could I put a resistor in series with the battery to bring down the current? My shaky understanding of Ohm’s Law is thinking that about 150ohms would be about right?
22 Ohms would do just fine. With fresh cell, it will drive the emitter at 45mA and less as the battery are being used up. Still, if you can afford to do it, a buck converter or at least a linear regulator is recommended to keep the LED drive current constant.
