I got some mystery bin “Boost HX” (CULPM1.TG) from aliexpress. The light had a LED4Power 4x 4040 board with Luxeon V in it and Angie optic (same one from Emisar D4S) so I thought it would be smooth sailing; it wasn’t. I kept getting shorts after the reflow. The separation between pads is so small with this board and after more than an hour fooling with just that I gave up. I had one 4XP 33mm Noctigon I use for slicing 4 LEDs at a time (so WELL used) and I figured i’ll give it one shot reflowing them onto the 3535 board. First try was a success! The next problem is that board is 1mm larger than the LED4Power one so I had to cover the LEDs and grind down that huge PCB to fit the spacer. I would have done this first but I had no faith in my ability to reflow the board on the first try and just assumed it wouldn’t work.
” Scallywag ” It burnt up on the first turn on and ramping up to about 50% power, poof. I had just installed ’ Lexels ’ driver. The led was working perfectly normal with the stock Haikelite driver, but I had modded the mcpcb to 12v and probably got some crossover voltage in the mcpcb. I have not had time to address it since then, busy on another build and I just received a few more mcpcb’s to mod to 12v. So new leds are ordered and soon will be back with an update. :+1:
I finally reflowed some new emitters onto my Sofirn IF25 (the one with shifting CCT).
I used 2 x 219b 4500k (SW45k) & 2 x 219b 3000k.
I cant believe i wated this long to do it. The light’s been sitting half undone for months on my shelf, i just hated the stock LEDs ssssooo much that i couldnt imagine it being as good as it is.
The CCTs blend well together. The optic is quite throwy which is a nice change for a R9080. pretty decent mass to the light, USB-C. Im quite happy. If they just fixed the hold off in the UI….
Personally im not overly fond of the SW45k, not that i dont like the rosy tint, but 4500K is just not my thing indoors.
I think i found a way to get close to my favourite 3500k but with more rosy tint
Will give it a decent run over the next few nights before i add it to my standard rotation, but maybe its the perfect light to take away when you only have 1 light. Any indoor CCT i want and USB-C charging!
Welp, my 30Qs arrived today. Threw them in my M6 and… as soon as they connected, it turned on.
I assumed my fix for the reflector shorts broke, so I checked for shorts there… but nothing. Just to be sure, I removed the reflector, and eventually pulled the driver completely out of the light. I double checked all the pinouts for the driver, including probing it out with a DMM, and compared it to the Anduril version I flashed - no issues there. I’m not sure what path current is flowing through. I eliminated the single-7135 channel by removing it. It’s probably the FET, but in my test rig the 15x7135 channel is probably just doing direct drive too, and I’m not sure how to test which gate is being opened with a DMM.
And apparently, all I had to do was give up and post here. I went over every solder joint on the board that I could see… But just now, typing this, I decided I’d double-check that the issue wasn’t somehow with the MCU/firmware (by removing it). I’ve got a silly quick way to do it, by laying the tip of the iron across one set of legs and rocking it up, then doing the same to the other side. But just now I gently applied flux to each quartet of legs. When I first laid the iron across the legs, I noticed how the visible portion of the solder joints got a lot neater… And on a hunch, did the same to the other side. Re-tested and it appears to be giving me the “blink for on”.
I think the most frustrating part of all of this is that the light was working without issues yesterday with the single 30Q out of my FW3A. All it did was sit on the desk, empty (no batteries) since yesterday evening. I’m going to go fully reassemble the light and make sure it still works.
Tested more, seems to be working. Re-assembled… Still working. Definitely the brightest light I own now, though I have no way to actually measure. But ceiling-bounce around the room compared to my L6 definitely gives the M6 a slight edge. It also gets hot way faster on turbo. But the difference between “10K” and “7K” lumens (this is what my M6 and L6 should be doing, but again - I can’t actually measure) isn’t impressive. Probably because the way the eye sees it, it’s less than 20% increased perceived brightness (perceived brightness is doubled when lumens are quadrupled).
I don’t think I need to build any more high-lumen lights, unless I find a way to do about 40k lumens at this point. And, judging by what Acebeam and Imalent are doing, that just means stuffing as many 70.2s as I can in something, which doesn’t really sound any more interesting than my M6.
I found one slip-on clip that worked and was in no danger of coming off the light. But the clip tension wasn’t the greatest and it stuck out from the light more than I liked. I removed it and replaced with a screw-in clip. Fortunately, the wall of the light where I drilled was thick enough that the screws did not penetrate to the inside.
I don’t have any experience or equipment for tapping screw threads. Instead I just drilled a couple small holes with a hand-held pin-vise drill and let the screws tap their own threads.
Playing around with these clips did scuff up the light a bit though. Darn.
Nice perseverance and result! I don’t think I’ve seen an Angie in an X6 mod before. Is it the same height as the CUTE-3 or do you use a different spacer?
It’s a bit of luck the method I used. I could do smooth(ish) even gradient with torch but I wanted these timascus looking lines and spots.
It was lightly heated to bronze gold throughout with only slight color on just the very tip and then dipped in acid etching solution (ferric chloride) and it instantly (re)oxidizes to this gnarly pattern.
I buffed the optics for my KR4 today. I like the extra throw and it doesn’t seem to affect the tint too much for the E21A 4500K emitters. I also like how the aux LEDs are brighter points of light, rather than the fuzzy ring of color.
When I bought this Ti/Cu version, Hank’s site still had the frosted optic listed as an extra part along with the 18350 tube, tritium, etc. Within hours of ordering, he announced the frosted optic will be standard. So I ended up with two frosted optics, one in the light and one in a tiny ziploc bag.
I made a pair of Nichia Optisolis triple S2+s. One is 5000K and the other 6500K. I usually don’t like cool white LEDs, but I thought it would be “cool” to have the highest CRI LEDs currently available. The 6500K has 99 CRI and 99 CRI R9 - it don’t get much better than that!
I got the LEDs from Virence and the triple boards from Adventure Sport Flashlights.. I wanted to limit the current to less than 2.25 amps so I got some 6x7135 drivers from Simon at the Convoy flashlight Store. I also installed lighted tailcaps so I had to add 470 ohm bleeder resistors to the drivers.
When I put everything together, there was some artifacts in the beams, so I sanded the lenses to make them frosted and the beams turned out great. With 10511 Carclo Narrow Spot Optics the flashlights have some throw.
I was expecting some greenish tint due to the positive Duv test results on the Virence website, but I don’t notice any at all. The 6500K certainly appears bluish on a white wall, but both appear to have some rosiness to them. I’m very pleased with the tint and how the flashlights turned out.
