Review: NANJG 105A 2800mA driver
193 posts / 0 new
sixty545
NANJG 105A 2800mA 4-Group 6 mode Driver
Reviewer's Overall Rating:  ★★★★
NANJG 105A front
Summary:
Voltage: 2.6-4.5V
Regulation
 Linear Regulator
Current: 2800mA
Modes: 6 in 4 groups
Price Paid: $4.70
Kaidomain  1)
1) This one was ordered early dec.2010 and seems to be a successor to the NANJG 105.
Pros:
  • Well regulated and efficient driver
  • Has memory
  • Has a 3-level group with no nonsense and good spacing
  • Has a high PWM frequency giving a steady light at low level
Cons:
  • Change of group only by soldering
  • Memory kicks in 2 secs after switching on (would prefer after switch off)
  • Can only be used with 1 Li-Ion cell
Features / Value: ★★★★
Mode Groups
The groups are as follows:
default: High(100%) - Medium(35%) -Low(4%) - Fast Strobe(14Hz) - SOS(decent speed)
1. High(100%) - Medium2(20%)
2. High(100%) - Medium(35%) -Low(4%)
3. High(100%) - Medium2(20%) - Fast Strobe(14Hz)
The PWM frequency is high at 4.5kHz.
Mode switching
NANJG 105A rear
The NANJG 105A has stars on the bottom side to select group by connecting one of the stars to the outer ring. Select group 1, 2 or 3 by connecting star 1, 2 or 3 (counting from the right) to the outer ring or to star 4 which is connected to the ring.
There are no further groups to choose by combining stars as star 1 takes precedence over 2 and 3 and star 2 take precedence over star 3.
Mode Memory
The mode memory snaps in abour 2 seconds after a mode switch (no indication). I normally prefers memory after switch-off so I do'nt have to tap twice to shift level, but this approach normally needs three more components.
Build Quality:  ★★★★★
NANJG has a fine build quality and can withstand normal soldering with a fine tipped soldering iron.
This one runs with a MCU PIC12F629 instead of the NANJG 105's ATtiny13. This has hardly any influence on quality but NANJG has managed to make it run like it has PWM although the PIC MCU does not include PWM (or am I wrong here?).
Battery Life: ★☆☆
Linear regulators with 7135 devices normally are well regulated and efficient. At lower battery voltages the drive becomes direct with a very little loss. The high current is hard to the battery and demands a quality type battery (low internal resistance).
Light Output:  ★★★★☆
The output current 2.8A is fine to drive XM-L, P7, MC-E LED's. The high current could heat up the light too much but then it is fairly easy to remove one or two of the 7135 on the bottom side (giving 0,35A each) with a heat gun for removing old paint (use a narrow nozzle cone accessory).
The driver has no boost capability so it must be expected that the output falls at lower battery voltages where the drive becomes direct with no regulation.
The driver comes complete with a (rather thin) red and a black lead to connect to the LED.
Summary:  ★★★★
The group no. 2 has a very usable spacing of 100% - 35% - 4% and maintain a constant output as long as the battery voltage is higher than the LEDs forward voltage, all the time with good efficiency. Then there are the possibilities to make just a 2 level light or include the normal blinking stuff with a really irritating strobe and a nicely timed SOS.
Edited by: sb56637 on 08/26/2014 - 17:27
fran82
Last seen: 9 months 2 weeks ago
Incredible review. Thanks for sharing this.
I will purchase it for a future XM-L light
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
brted
brted's picture
Thanks for posting a review on this new driver and AK-47C that you wrote earlier. It's good to have this information available.
sixty545
Thanks and glad you like it. Sometimes something good comes out of an unexpected delivery from the vendors.
Huny74
Huny74's picture
Last seen: 5 years 3 months ago
Thanks for sharing your experience, sixty545!
I was just about to start a thread about this driver when I saw your review because I am thinking about getting one.
May I ask you (and all the other electronics experts here on BLF): On Aqualab's driverlist which I found very helpful and trustworthy in the past the Vin for this driver is listed as 3,3-6,6 V. Now I am wondering: Is it possible to run it safely with 2 x CR123A (primaries)? Is there any alternative that can handle both 1 x Li-Ion and 2 x CR123A that gives >2A and has at leat one low mode and preferably no strobe?
TIA, Huny
brted
brted's picture
Shiningbeam says its drivers can be run on 6V, but not 7.2V. They are NANJG linear regulators too, so I think you can do it, but you will lose a lot of the efficiency because all of the extra voltage will be burned off by the linear regulators. What you are describing is more of a buck driver, but I don't know of any good cheap 3-mode ones. A buck driver would work great on 2 cells and would probably go to direct drive pretty quickly on 1 cell.
sixty545
TIA, Huny
The limiting factor is the MCU (Micro Controller Unit) which is specified running from 2V to 5.5V. Add to this about 0.3V for the schottky diode that feeds the MCU (polarity protection). Then you have the range 2.3V to 5.8V for guarantied running. The absolute maximum voltage is specified to 6.5V, that becomes 6.8V battery voltage. Above that you could destroy the MCU. The low voltage is given by Vf of the LED (plus a small voltage drop, say 0.15V in the 7135's) or about 3V.
Huny74
Huny74's picture
sixty545 wrote:
... Then you have the range 2.3V to 5.8V for guarantied running. The absolute maximum voltage is specified to 6.5V, that becomes 6.8V battery voltage...
So it is possible to run the Nanjg 105A with 2 x CR123A but not very safe/not recommended to do so over any longer period of time, if I understood correctly?
Huny74
Huny74's picture
brted wrote:
...What you are describing is more of a buck driver, but I don't know of any good cheap 3-mode ones...
Haven't found one either. Well, with all the XM-L lights flooding the market let's hope that more different drivers will follow.
Thanks for the replies, brted & sixty545!
[note to myself: find out how to quote multiple persons in one post]
Budgeteer
Budgeteer's picture
Last seen: 7 years 11 months ago
sixty545 if you can be bothered to do current draw for hi med lo at tailcap that would be sweet.
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
Nautic
Nautic's picture
Last seen: 2 years 3 months ago
Spendid review. 4.70$ of mine are on their way to HK.
I first considered this as it works fine with my MC-E:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220692100654#ht_2729wt_1139
Cheap quality is good - Expensive crap isn´t
sixty545
I will be happy to measure the current draw, but am not able to do it yet. Thanks to our dear government I could not buy a drop-in with XM-L which costs way over our import limit, so I had to make two orders of one XM-L star each at DX. That happened dec.23 and I have heard nothing from them since. I have a Skyray P60 host and reflector with pill ready to assemble my first XM-L light.
The percentage numbers in my review are from oscilloscope measurements of pulse width's.
sixty545
I think it will be safe (but expensive) to use 2 x CR123A 3V primaries if you only look at voltages. But there will be generated lots of heat. The two extra Volts dropped in the regulator at 2.8 Amp will generate 2 x 2.8 = 5.6 Watt on top of the 10-11 Watt with a single Li-Ion cell. That must be a no-go.
FlashPilot
FlashPilot's picture
Last seen: 1 hour 5 min ago
Thanks for a great review. I especially like being able to eliminate the irritating strobe and SOS modes.
Nautic
Nautic's picture
Yeasterday I got this http://www.kaidomain.com/ProductDetails.aspx?ProductID=11130 XM-L from KD
I put it in a P60 with this driver http://www.kaidomain.com/ProductDetails.aspx?ProductID=1845
I put 4 volts direct to the led and measured 3.4 amps on my lab power supply.
With 4 volts through the driver I measured 2.7 amps. Installed in the light I measured 2.4 amps
Very happy with the lightoutput - amazing. The led was ordered from KD the 23rd and arrived on the 8th.
KD has improved a lot lately!
Budgeteer
Budgeteer's picture
At how much is your import limited to? Mine is 22€ which is 29,xx USD atm acording to google.
Don
Don's picture
Last seen: 11 months 15 hours ago
I think the free of duty limit is set by the EU. The UK version is £18 which is roughly the same amount. But our Post Office doesn't seem to care much about stuff from China. Up until now, I have never had any order queried or opened. And I doubt Customs here are all that bothered.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
FlashPilot
Looks like a good driver. Was that measured at the LED or tailcap?
Budgeteer
Budgeteer's picture
He is from Denmark and he has troubles getting a dropin which is roughly 17usd... that picked my interest.
Oldienea
Oldienea's picture
Last seen: 6 years 4 months ago
Since the values on the packages are all incorrect, what our customs know, they check them from time to time. Sure they are unable to estimate the real value either way. But when they open one and they feel like asking for a proof, they usually charge 11 euros for the procedure, regardless if the receipt shows, it was less than 22 euros or not. When I order goods from a store, where I have to pay the shippment I don't split the orders. Usually, three out of four of them go through anyway without to get checked. So finally, when I count all together I still win.
Nautic
Nautic's picture
The limit is 10€ (incl postage!). Over this: 25% wat and 22 € handlingfee to postalservice for collecting this for the customs.
sixty545
The limit where you have to pay 25% VAT is 80 Danish Crowns and has NOT been changed in 15 years!. That limit is equal to about $13.80 but the PO add another $28 fee to do you the favour. That way an order of $14 becomes $45 Cry. In the Christmas razzia I got confiscated 3 lights costing around $16 each. I will not throw good money after bad ones so I just cry a little and wait for another opportunity to re-order. The PO returns the goods to HK I think.
We only have to pay toll on orders bigger than about $198 and normally this is only 6%.
Don
Don's picture
Ouch! That is low. The USA the last time I looked allowed $100.
The UK limit is also including postage, but I thought all of the EU now had the same Customs regulations.
Nautic
Nautic's picture
I measured it by connecting the possive to the +spring up through the light
and the negative to the threads at the tailcapend of the tube.
I have now tried to put the + to the +spring as last time, but now put the negative
to the spring in the tailcap and this to the threads on the tube. Now I measure 2.2 amps.
A small loss in the switch apparently.
Nautic
Nautic's picture
Træls!
Nautic
Nautic's picture
Here it functions this way: If the EU regulations are to the benefit of the population or customers,
its the national rules that apply. If EU rules benefits the State the national rules dont apply!!
sixty545
Nautic wrote:
Træls!
Go-daw do!
Budgeteer
Budgeteer's picture
For what reason?
sixty545
Budgeteer]</p><p>[quote=sixty545]</p><p>[quote=Nautic wrote:
For what reason?
For what reason? -which of the statements do you mean?
Budgeteer
Budgeteer's picture
I wondered why did you get your flashlights confiscated for?
sixty545
OK, they were not literally taken from me, but I refused to receive them and pay the additional $32 for each $16 light. It feels like "confiscation" of my Aurora 34. Good knows if I ever can lay my hands on that model. The two others were WF-502B. I hastely bought two empty bodies, two neutral XP-G's and some reflectors and builded two better lights. The 3 x 16$ is probably lost but that's life.
