imo yes
the link in post #1 says redosing was done daily:
“for three minutes a day for two weeks.”
I found it suprising that the benefit is only for people over 40.
imo yes
Effects from 2-3 mins lasts about 3 days. No point in saying this to some people as they forget which day they used it - so say daily as there is no harm in it.
Green does not work - mitochondria do not absorb green light. A company has incorporated green into one device to make it more complex and protect their patent.
Longer wavelength penetrate deeper in tissue - so labs doing this in brain use 810nm or longer, which is beyond the human visual range.
No point in trying to work out wavelengths with your eye. You need a spectrometer
Best
Glen
thank you
I suppose green light speeds wound healing by a different mechanism than energizing mitochondria
Green light emitting diodes accelerate wound healing
“(LEDs) … have photobiostimulative effects on tissue repair.
we investigated the effects of … green (518 nm) LEDs on wound healing.
wound sizes in the skin of … mice were significantly decreased on day 7 following exposure to green LEDs
In conclusion, we demonstrate that green LEDs promote wound healing”
I’m unsure of this. Not everything published is correct, particularly if there is a commercial interest behind it. But as you say it could be simply by another mechanism e.g. all light carries energy which can improve circulation, which in turn will likely improve wound healing
How big is the effect in practice? I understand statistical significance, but I realize that could mean an effect that’s reliably detectable but trivial for actual daily life purposes.
Reasonable point. Most people don’t detect anything obvious, although a couple of subjects did pass comment on colour perception changing. However the effect is robust when tested. One subject had a 20% improvement in colour contrast, which is not only significant but will impact on daily life.
Many things happen to your visual system that you do not detect. Glaucoma is a good example. There is significant slow peripheral visual loss that is often not detected directly until people start bumping into things that they walk by. The visual system slowly corrects for problems, it re-sets the gain control gradually, but over years things are lost. By the time you are 70 you have lost 30% of your central photoreceptors, but it’s a slow change and you only notice it when forced to make a visual judgement. People certainly notice loss of sensitivity in reduced lighting when they have to dark adapt and we have been working hard on that. We measure how long it takes them to adapt and show them the times and they are surprised how long it has taken. We show then show the times again after 670nm exposure and its obvious there is an improvement.
Our improvements will likely make a difference when you have to make a visual decision e.g. can you see something in the dark, can you detect a subtle colour shift. Its all about paying visual attention, which we often fail to do.
Sorry if the is a bit of a ramble but your point is important because people don’t know about how subtle visual decline is until a critical decision is needed. I think that is where it is obvious.
Thank you! This is really helpful. Please ramble as much as you like.
I had early cataracts (in my late 30s) abd one intraocular lens [IOL] replacement surgery, and when I asked the eye surgeon what other kind of changes I might expect with age, he just shook his head and said “You don’t want to know.”
But ya know, I really do want to know what to expect. Past age 70, one cataract IOL later, and eyedrops for glaucoma in that eye, and my vision is still my favorite sense. Much appreciate your participation here.
It’s become apparent that the yellowing of the lens affects us flashlight users, as people’s perception of color varies quite a lot.
PS, I got one of the last IOLs that don’t block ultraviolet, which means I can see further into the UV range in that eye than in normal eyes. Like this guy, who documents the UV vision effect:
That is interesting - when/if I get around to needing my lenses changed I was going to see if I can have UV permissive ones. I have less concerns than others about UV. The cornea still blocks a lot.
Humans/primates are one of the few mammals that actively block UV: See :https://royalsocietypublishing.org/doi/full/10.1098/rspb.2013.2995
And many actively use UV: Reindeer use UV light to survive in the wild | UCL News - UCL – University College London
Interesting discussion between Dileep George and Lex Fridman about vision and visual cortex in the brain.
Short summary:
“The eye sees only what the mind is prepared to comprehend.”
I could not see any datasheet to show a clear 670nm as a dominant wavelength for a red LED, while most they do have a bit of 670nm or they can be specified as range rather than a dominant they are only residual at 670nm and 660nm is the dominant wavelength anyway.
Would you share some of these dominant 670nm red LEDs datasheets that you have tested?
Since I see a massive emphasis on 670nm like it would be a standard red LED and it is not, or what exactly is the point of using this exact number of 670nm unless we can actually have one to buy.
Research in the field that was started>15 years ago used 670nm. Partly this was due to a device that I think is not longer on the marked called a Warp that most labs used. There was no general interest in the public having access to 670nm as all of the research was animal based with only about 20 labs working on it. Since then it has expanded with a demand for 670nm LEDS - Try Epigap they normally stock them
https://www.epigap-optronic.de/en/led.html
All LEDs will have a dominant wavelength and a normally distributed wavelength spread. As long as 670nm is within the half power bandwidth it will probably have some effect. Sorry I’ve not retained data sheets. We check and throw out what is incorrect. This varies with batches even from the same supplier.
Best
Glen
Hank Wang from https://intl-outdoor.com/ just told me that his SST-20-DR leds are 670nm for now. I don’t know if that number was measured or if it is the manufacturer bin.
SST-20-DR is advertised as a 660nm led, but according to the data sheet it has 6 chromaticity bins, between 640nm and 670nm.
https://download.luminus.com/datasheets/PDS-003040-Rev-04-SST-20-DR.pdf
You can order a custom Emisar or Noctigon flashlight from him with SST-20-DR leds if you email him. Emisar D4V2 and Emisar D4SV2 can both be made with these leds. You can find his email on the website. I purchased both and I like the larger D4SV2 more, because it has a more throwy beam.
EDIT: I updated this post because those SST-20-DR leds were actually D5 chromaticity bin, 660nm-665nm.
I’ve had severe myalgic encephalitis for the last 10 years and a couple of years ago my mitochondrial function was measured to be well below normal which, as you can imagine, causes a myriad of issues.
My knowledge is a mix of scientific fact and non-scientific self-observation so difficult to quantify, but before i knew about the mitochondrial dysfunction i looked at infra-red light to see it’s effect on certain issues and discovered that looking at an infra-red heater panel for a few minutes ‘relaxed’ my eyes and benefited my eyesight and light sensitivity. (Caveat: I was far enough away from the panel to not feel any change in temperature on my eyes, don’t want to burn them!)
Obviously the research stated in this thread could go some way to explaining that but the reason i’m saying this is because although this is a torch… ok, flashlight forum an infrared panel might be more conducive to this health application given that it is a far less focused source of light.
Although sticking a DR/IR LED in a suitable host is far more in keeping with the nature of this forum
It is also worth me stating that the light from the 660nm XP-E2 in the C01R relaxes my eyes whereas the 620nm XP-E and XM-L colour that i also have fatigue them, i actually prefer white LEDs to 620nm LEDs.
And, if it is of benefit to Glen i have a new C01R i can send which is already in England.
I tend to agree with you re the panel particularly for systemic mitochondrial disease. This is a bit off fields for me, but its where some good researchers are going who are working on Parkinson’s etc, which has a mitochondrial basis. The other bit that adds to the potential strength of the approach is that we know mitochondria in different parts of the body talk to one another and can communicate about health status and shift as a consequence. After all, mitochondria regulate ageing and generally the organs in our bodies age at similar rates, although the retina leads.
However, for many of us it has been a long journey to get people/scientific community to believe in what we are doing. To then go and tell them to direct the light on a part of the body that is not the focus of pathology is problematic. But there is a very solid scientist in the USA who has improved retinal function in rodents by focusing light on the back of the animal. Not quite as good as focusing on the retina, but impressive.
It’s a fast moving field and while I can put my hand on my heart and say this is all working and showing improvements, I and others are very aware that there is a lot we do not know.
Best
Glen
Science!
I wanted to try this “method”,so I searched around the Internet and fount some multi led deep red lights on Amazon,named ABI deep red grow lights,with different power.They say that they are of 660nm.
Being in a hurry,as a friend was to come in Athens,I told her to buy two of them,one with 12W power,and the other with 24W,as I didn’t know exactly the details.She gave me these today,and I tried one at a time.
The result is that the big one,is way strong,so it is not possible to look at this,even from a far distance.The 12W one,is more tolerable,but not very.I tried from about 1.5m far,but the light is very strong.So,I will try this from a 3m distance and will see.If I have a result,I right about.
These lights have a fan inside,because of the heat which the leds produce.
for those interested in red LEDs to install themselves
Cree-XP-E2-Photo-Red-660nm
A host I like:
Tool AAA
for those that just want to pay and play,
here is a Photo Red in a twisty host
Way too much power! and you need to use a diffuser such as a piece of waxed paper or optical film. Don’t look at a bare LED.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result.
Thank you very much,appreciate.
… but the light is very strong.So,I will try this from a 3m distance and will see.If I have a result,I right about.
Well, you bought a mortar and a howitzer to kill flies. :-D
A very small amount of light is enough! You should be able to look directly at the light source without discomfort. This means the light source's emission power needs to be tuned to obtain a certain amount of power density per surface area. Read this comment of Glen Jeffery, even 40mW/cm² is way more than really needed. A proper optic or filter to evenly distribute the light is also quite advisable.
Now that I think of it, 40mW/cm² sounds like a lot. Let me also say that an aspheric/plano-convex lens just atop of the emitter is, in my opinion, suitable for this ensuring a superbly uniform blanket of irradiance from the emitter, i.e. a close to constant power per surface area cone of radiant flux.
