basic sounds good to me. no clue on programming,...
for housing, working on it:
1x 3up
2x 3up
going to be DIY KIT , including, cable, remote switch, and mount.
the 1x3up going to be round, for the 2x3up, thinking square .
preferable, the housing, should only need 1 screwdriver /hex to assemble.
excellent job, I especiallylike those "easy toaccess" programming pads, veryconvenient, this can easilybe madein 5-pin connector
although over my pay grade (fully assembled module is about 1/3 of average monthlysalary overhere) I thinkthat the prices areveryfair, I look forward tosee how will a professionally soldered module look like (clean and neat job) :d
I'm wondering the same. Normally I try to find a driver/emitter for a specific host, but this time I will find a host just so I can run one of these :)
Not yet, I've actually ordered a number of hosts that I think might be a good fit - Most of them, unfortunately, are shipping from china and as such won't be here for a month or so..
Once I have them, I'll test fit the module into them and let everyone know the results.
At first I thought I should add some phrases concerning a good heatsink, maybe modding the upper part of the host and so on.. then I noticed that the posters name was scaru. :D
The full mechanical specifications can be found in the original post, but the height is 15.4mm. I always assume a little slop due to manufacturing tolerances and leave 16mm of clearance.
PPtk
Edit: Without optics, the tallest thing on the circuit board is the Inductor. Without optic the total height is 0.4mm (circuit board) + 5mm (Inductor) = 5.4mm.
The XM-L emitters are 3.02mm tall, so the height of the emitters is 0.4mm + 3.02mm = 3.42mm
Those numbers are a LITTLE low since there is some solder between the inductor/emitters and the circuit board, but at most the solder accounts for an additional 0.127mm (5 mil solder stencil).
