True, although considering the cost saved by NOT making it user serviceable for battery replacement makes it a good bit cheaper. So inexpensive for them to make that they can periodically offer them for free as an Olight “product marketing” tool.
It is a Luxeon TX, right? That LED has a thermal pad.
Edit: On the original i1R, it looks like you’d need to rip off gasket and polarity protection, then reflow over a candle. Optimal position can be found with a scratch MCPCB and an IR-meter. Was easier with the i3E since it had a button contact. But if that assembly is press fit, all hope is lost for me. I’d need two lights to do such a mod. One to drill out the driver, keeping the shell intact, and one to nibble away the shell, having an intact driver.
Are you referring to the version 2 or version 1? Your Luxeon TX comment refers to V1 because V2 is definitely not a TX and it’s head is assembled differently. If it is V2 you are referring to did you unscrew or pull?
I used Easy Off oven cleaner. I carefully sprayed some into a disposable plastic container. Then I removed the O-ring and used a small paintbrush to apply it, being careful not to get it into the charging port or charge indicator. Let it sit for 10 minutes, then wipe with a damp paper towel. I did the back half first, then the LED end. When finished, I wiped it again with a damp cloth towel. I installed the O-ring and twisted it closed and rinsed it in the sink to get any residual chemical off.
It was a bit splotchy, so I used a Dremel with buffing wheel and polish to finish.
