Hello everyone,
Are you looking for a nice, versatile AAA penlight?
Do you prefer tailclicky over side switch?
Do you like HighCRI?
Good! Then this could catch your interest...
Wurkkos has relaunched their penlights and now introduces two great new products using Luminus SST-20 LEDs
... available in two tints of 6.500K 70CRI and 4.000K 95CRI (with limited availability for now) ...
... available as WK01 using one AAA battery or as WK02 using two AAA batteries ...
... available in multiple colors (4.000K 95CRI in black and desert tan only) - some colors may not be available in some warehouses ...
Specifications (based upon the 6.500K version):
❖ Emitter: 1x Luminus SST20 4.000K 95CRI (limited) or 6.500K 70CRI with a lifespan of 100.000 hours
❖ Driver: Constant current circuit
❖ Switch: improved tailclicky switch
❖ Reflector: Aluminum alloy smooth reflector
❖ Lens: Toughened mineral glass lens
❖ Operating voltage: WK01: 1.0V – 1.5V / WK02: 1.8V – 3.0V
❖ Battery options: WK01: 1x AAA Alkaline 1.5V or 1x AAA NiMH/NiCd 1.2V / WK02: 2x AAA Alkaline 1.5V or 2x AAA NiMH/NiCd 1.2V
❖ Dimensions: WK01: 84mm (length) x 14mm (head diameter) / WK02: 128mm (length) x 14mm (head diameter)
❖ Weight (w/o battery): WK01: 16 grams / WK02: 20 grams
❖ Flashlight body: Aerospace grade 6061 grade aluminum alloy, CNC manufactured to hard-anodized to military grade specification type III, anti-abrasive finish to get solid built body, anticrash geometry and better heat exchange
❖ Reverse polarity protection to protect against improper battery installation
❖ Water resistance i.a.w. IP68 (underwater 2m)
❖ Comes in black, red or desert tan (brown)
As of 06/2021:
If you have any questions or comments, no matter if commercial or technical, please contact Wurkkos directly. Thank you for your understanding.
https://budgetlightforum.com/user/32168
https://budgetlightforum.com/user/38972
