I just bought the original, and I have a 21700 cell that does something like this.
I put my cell in slot #4, charged it at 1000mAh… and it would charge up to what it claimed was 4.20V, but my meter always read 4.07V.
So, just for laughs, I took that cell, put it in Slot #1 and set it to 1500mAh. Oddly, it seemed to realize it wasn’t full. Screen displayed 4.20V, 99% the whole time. I terminated the charge early after 25mins…. was too worried the cell would grenade.
Off the charge… with my meter it now states 4.11V
Not sure if it’s a slot, or charging current issue (on my part). I’ll have to try it again in slot #4 at 1500mAh next time.
Is the S4+ meant to be able to automatically select 250mA when charging 10440 cells?
I noticed the S4+ charging my Vapcell INR10440 cell at 500mA in auto Charge mode. It was around 4.07V. I quickly took the cell out and switched the S4+ to manual mode and charged the cell at 250mA until full.
To see whether it would automatically select 250mA to charge 10440 cells, I discharged two Vapcell INR10440 cells to around 3.96V (measured with DMM). I then put them in slot 1 and 4 using auto Charge mode. They started charging at 1000mA.
It seems like 230-270mA is selected automatically when the 10440 cell is near 4.20V in auto Charge mode. But a higher current is used if the cell voltage is less than or near 4.00V. The current is reduced when the cell is nearly full.
Per my observation, the S4+ uses the battery resistance measurement to determine charge current when set to Auto mode.
This would mean a low-resistance small battery may be charged at possibly too high current… although I’m not sure how this would look like in actual (eg. what are the cut-off resistance values versus the automatic charge current applied.)
I bought this a few months ago and I generally like it. I noticed that it will charge smaller batteries like a 10440 at a higher charge rate than expected in auto. It also displays voltage at 4.20 when the battery is at 90% and charging. It would nice if the firmware could be updated somehow.
does anybody know if vapcell updated the firmware version to fix this issue reported by contactcr? and also is there a way we can check firmware versions?
Does anybody know if this will fit a Fenix ARB-L21-5000U with USB-C port without stressing anything?
the cell is about 77mm long
I know that HKJ measured 76.9mm, and I just want to hear from somebody with experience that this battery will fit normally without stressing, bending or anything.
76.9 is charger length, according to Lygate information.
The cell is 76mm, according to Fenix website info. You should have almost one mm spare in the length department.
I was so happy that the Vapcell S4 Plus charger fits my 21700 protected, usb chargeable Imalent and Nitecore cells, that I bought four of them.
For me, its multiple flashlights per room, and multiple fully extra long 21700 chargers per room, too. But no S4 Plus chargers in the kitchen or bathroom, yet.
Vapcell S4 Plus can only fit 2x 26650s on the outer bays (bay 1 & bay 4).
Some chargers that can fit 4x 26650:
Liitokala Lii-600
SkyRC MC3000 (can fit 2x 32650 on the 2 outside bays)
Xtar VP4 Dragon (can fit 4x 32650 or 4x “D”-size batteries) = this is the widest 4-bay charger I’ve seen yet.
In post # 45 Tatasol Confirms it can take 4 X 21700? Is this true? HKJ sent.me pictures disputing this.Maybe that was version 1?
I can deal without 4 X 26650.If it can not do 4 X 21700 this is a No go.
It is shame my version 2 of Folomov A4 had 2 failures due to Display completely malfunctioning.That version 2 could accommodate 4 X 26650 and 4 X 21700.
