You’re looking for the BLF Q8. Maybe something a bit smaller can sustain more lumens if you’re using 50.2s or 70.2s but that’s roughly the kind of size and mass you need.
Thank you, I’ve seen that light around but have never given it a serious look. I don’t know any specs. I’ll research it, must be a video of it online, thanks again,
Design 2 can be used as a headlamp and as a normal flashlight. I like the idea of having throw and flood in the same flashlight. USB Type-C port would be also nice to have.
Awesome, thanks! I checked it out, sounds pretty sweet. Of course I’m leaning toward the SP36 even though I’m sure it doesn’t dissipate heat as well as the Q8.
Side note- I voted for multi emitter thrower. Reason- I just received the Haikelite HK04 SST40 and it’s awesome. Spill and flood due to 4 nice strong emitters. I would love to see some more solid options like this especially from this forum. I know the q8 is similar but the throw on my hk04 due to the deep reflectors is amazing. Makes it’s a great all around light with great battery life.
Also - I vote for 3 18650’s not 4, seems nicer on the hand. Ideally though (2 or 3) 21700. I was really against 21700 at first bc it was just another size battery to buy but now that I’ve beeen using them theyve grown on me.
Yea, I didn’t doubt you. It’s a good point, so I guess it’s all the same unless there is only a 2 x 21700 made (maybe weird in parallel). Although couldn’t 3 x 21700 have more mah’s than 4 x 18650? Approx 15000mah vs 12000mah (considering amperage of both is similar meaning 4 x 18650 could be 14400 mah but with lower amperage then the 21700 @ 15000mah). I don’t know, maybe that’s not ever true.
I agree. Tail clicky is necessary for carrying clipped to inside pocket. Also deep carry clip is preferable. Not that many lights with these physical characteristics to choose from, then UI and LED offerings limit the choices even more.
