Interested in 1, thanx.
Interested in one thanks.
Interested! I have been using my LT1 almost everyday, great light.
Definitely interested
Interested in 2 please
I am interested in 1 please.
Interested in 1 please
Additions to the interest list since post number 673:
Post# / Added / User Name
675 / 08/16/2020 / maniakman
676 / 08/17/2020 / Mraz
677 / 08/17/2020 / Jalben
678 / 08/17/2020 / jzyg
679 / 08/18/2020 / Denis O
680 / 08/18/2020 / Aardvark
681 / 08/18/2020 / BatteryPowered
682 / 08/21/2020 / shutterboy
683 / 08/23/2020 / MKayze
684 / 08/23/2020 / F.i.l.a.s
685 / 08/23/2020 / LumenLucas
Been awhile since I’ve heard any type of progress update. Any new info?
Two please.
SIGShooter: California_Prepper:Been awhile since I’ve heard any type of progress update. Any new info?
This is the last message from DBSAR. Hopefully things are getting better for him.
You are wrong! His last message is from yesterday! https://budgetlightforum.com/t/-/55894/1246
I think SIG was referring to his last message regarding this project. I hope his recovery is going well!
RugaL: SIGShooter: California_Prepper:Been awhile since I’ve heard any type of progress update. Any new info?
Yes that correct; I know that DBSAR has posted in other threads but I was only concerned about postings in this one
Additions to the interest list since post number 685:
689 / 08/23/2020 / weklund
This has probably been discussed multiple times, but would it make any sense to have red emitters? So ramp from red to white.
Interested in 2.
Interested in 1
I apologize if this has already been discussed, but I just watched the video and it looks like the top, lantern portion either is or easily could be threaded on to the flashlight portion, such that it could be easily removed. And the remainder of the flashlight still has an optic and everything so that it could be used like a normal flashlight with the lantern portion removed. If possible, that dual functionality would certainly make it a more appealing option for backpacking purposes. And I think it’d also be a great selling point for those who might not see themselves using a dedicated lantern that often but would appreciate getting a solid light that also offers lantern functionality should it be needed. Everything could still be optimized for lantern purposes while leaving a solid flashlight, right? Is that or could it be part of the plan?
To take that idea a step further, maybe the stability plate for the bottom could have a slightly raised area to center the light that the lantern portion could also screw into, so they could be easily stored together when the light is being used as a flashlight. It looks like the lantern portion goes around, rather than inside the bezel, so the inner diameter of the raised area could match the diameter of the bottom of the flashlight, while the outer matches the bezel and has a couple threads for the lantern. But it could potentially also work with the inside being threaded if the lantern portion attaches inside the bezel. This would also help prevent any gunk from getting into the lantern portion while it is removed.
I came here to suggest this, I would appreciate a lamp that can do both, flashlight and lantern, especially since the original IF25 doesn’t have Anduril and I’m sure that some people would be interested In a Anduril flashlight with tint ramping, personnaly I modded one with LH351D, it’s quite nice but would be even better with Anduril.
@ thefreeman, that would be nice. A light that has it all. Lantern and a light in one.
