Hey fnksb, any way to check into my order? I never received the Unicorn it’s been 3 months, I also didn’t get an email with a track code.
It does show “shipped” on ylplight.com, I sent an inquiry directly through the website too.
Thanks fnksb great price.
Ordered the Gryphon G180 (I think ) invoice email from ylp arrived in rubles with no payment method- perhaps a further invoice will arrive later? I have queried it with them.
Thank you, fnksb, for the notification about the discount! Not really interested in that light, though. Waiting for the release of the Gekko 1.0 – I hope Inferion finishes the firmware quickly and the production starts early so that I can use it already this season (is October or early November feasible?).
This Gekko headlamp looks great, looks compact and light, very Zebralight like.
I welcome the Unicorn UI, but they need to have a lower low, the 3 lumen minimum on the Unicorn is too high, and this is even more important for a headlamp, I hope they can add a sublumen moonlight.
As far as I have understood the new driver for the Gekko allows very low output with “0.000… lm”. It will also have a slightly more advanced UI with more features and adjustments. And it will be compatible with the Unicorn (but I don’t think they’ll sell them separately and it is not simple to swap the driver).
Do you mean Gekko? Yep, linear driver without PWM is one of the best solutions for this type of lights (the ones which use a 3V-LED and a 18650 battery) :+1:
Linear drivers aren’t that bad in terms of efficiency. Depends a lot on power and battery voltage. 3V LED would require a complex buck-boost driver. Or a different LED with higher Vf and only a boost driver.
