I will try but from my experience with other leds kinda don’t like that method much, I was never too happy with my results so I focused on dedoming but this led, generally XHP series doesnt like chemical deoming so slicing it is then.
I also have some of those Osram white flat leds with rectangle die, more powerful version of NM2, might try that as well!
The first (“Mastergrip”) was part of a 3-pack from long ago, when I was a child. My dad got the 3-pack, gave me one, kept one, and gave his father the last. I can’t find any current listings for it.
The blue/black is “from Lowe’s store-brand ”Kobalt”“:https://www.lowes.com/pd/Kobalt-2-Piece-Household-Tool-Set/50029434
I decided I have too many black lights. In addition, my Sofirn SP70 is too similar to my Convoy L6 - and they’re both black.
So, I figured I’d bake the SP70. I had to disassemble it some for the driver swap I’m doing soon (MTNE order shipped today!). I was going to pull the tail switch for a bypass (and maybe Blue springs, too) as well. So really the only additional step I took was picking off the O-rings and stripping the lube off the threads.
Prep:
You may notice something I forgot: The head is assembled from two pieces. (I tried later and can’t separate them anyway, but some sort of residue bubbled out from the crack a bit during baking).
After the first round, which was a while at 550F on the “bake” setting on my oven.
I decided I wasn’t happy with how dark the tube stayed. Unless a flashlight with HCRI was shining right on it, it was hard to tell the difference even side-by-side with a black flashlight.
So I baked it again - this time I put it in the oven before preheating, and set it to 550F on convection bake.
It came out nicer, and I couldn’t be more pleased:
Finished product under 4000K SST20 (plus cat tax):
I was expecting the whole thing to turn somewhere in the brown to sand color range, but I really like the green, too. (Looks a lot like Sofirn’s green mentioned in freeme’s EC03 group buy thread ). It’s also just that much better that the colors happened to alternate.
Oh, you monster. I didn’t have to know there were purple and pink versions up there… My wallet really didn’t need to know.
P.S. I’m trying to get better at remembering to take pics of my mods, so hopefully some recent posts have been more fun to see than my typical walls of text.
Got my first pair of UCLp from flashlightlens.com today. After struggling to unwrap the first lens while leaving my nitrile gloves on, I discovered it to be an invisible circle!
Put it on my modded Supfire M6, and I’m feeling better that I may not be losing 1000 lumens to a cheap, non-A/R glass lens.
Oh, also, the UCLp was 2.2mm thick, and the original glass 2.5. Worked out great, as it nearly perfectly offset the slight gap I’d created at the bezel with thicker LED MCPCBs.
Package from Simon came today as well. Four blue lighted switches (odd, would’ve sworn I only ordered two…).
Installed one in my Jaxman M8 and my purple S2+. Also decided to rehab my Thorfire VG10S. It now has a Luxeon V (V2 maybe?), a basic three-mode Convoy driver of some sort that I found lying around, and a blue light in the tail. (Previously it had the Luxeon, the original dead driver, and I stole and promptly destroyed the tail switch from it.)
And, package from Hank. A pair of XM-L2 for my Olights. I’m a bit intimidated to open them - for the S15 Ti, I’m concerned about the switch, and for the S1 I’ve never had it open.
Edit: A couple hours later now. I got the S1 open with only one tiny nick on the head at the head/bezel interface. I started with a razer blade, then a small knife blade, then an iSesamo - which eventually sent the bezel and optic flying, when things finally let go. From there it was pretty straightforward. My 16mm Noctigons weren’t gonna fit, and rather than file I pulled out the hotplate to reflow. I don’t know what solder Olight uses but it didn’t melt until past 220C - Hank’s Noctigons had already let go before 180C. I also accidentally made a very special emitter - I dedomed one of the “old” XM-L2s. I checked it with my DMM, and it still works - the last XM-L2 I accidentally “dedomed” took the bond wires with it.
On to the S15 Ti, I once again had issues re-assembling it. Again, the reflector was shorting out to one of the MCPCB leads. It took me I think 5 re-tries with the leads to get it working. The ends of the leads have gotten gnarly at this point, and I really didn’t want to pop the driver out and run fresh leads, so try, try again I did.
I also gave everything optic-related a wipe with some disposable lens cleaning wipes I’ve got: S15 Ti reflector and lens, and the TIR holder and TIR for the S1. The reflector does have some scratches on it, but it can’t be seen in the beam - only when looking straight down the barrel on moonlight.
Some pics:
(I cannot overstate how difficult it was to take the above picture.)
Sorry everyone, I did want to see if people could guess breifly, but then I feel asleep for the night.
The 100% correct answers were basically offered, but not by one person.
SST-20 3500k GB4, shaved as low as humanly possible. The special sauce was Lee Zircon 804 (804 I think, I have a pile precut and mix them up) In a triple within a Wuben TO46r using a 10507 optic. Power level 4 of 5.
I think I could get –0.0011 with an overdriven single without the minus green and I will build something else to try that.
I was playing with the zircon and the spectrometer to see where it would sit on the bbl, the epic cri numbers were quite a surprise actually. I had the light built for a few weeks and everything was perfect except a small shade of green I couldn’t get rid of.
I have a 4000k FW3A with an eliptical carclo and a Lee -green (not sure which) as a bicycle light and I gotta say it’s very pleasing to the eye. Very balanced colors and good saturation.
I never intended to add a filter, it was just a test. I don’t like using them, but sometimes they just fix a green problem and make something perfect.
It could even be an 805 which is minor.
Shaving and filters are very different things. Filters have MUCH less effect and most importantly, take 10 seconds to install or remove by hand.
Without the dome the difference in throw is quite amazing, not to mention the cct and tint changes. Throw changes make it more like a Osram flat white than say a Nichia.
There is an output drop for sure so a multi is nice.
I don’t have a lumen tube but I might be able to do some lux measurements when I do the single 3500k.
The purpose of this light was a high cri throwy triple with usb charging.
Its proven quite a fun light to walk around the house at night lighting up coloured things with an explosion of saturation
More of the emitters finally arrived so I’ve got more things to do. I want something with a much higher drive and no filter ideally, hopefully a multi.
Probably also a fw3a with the new lume1 buck/boost driver to improve efficiency.
I’d never thought about that.
Out of interest, what do you see in cct changes? Surely 6500k and 2700k still look very different to you thought right? Do you not see tint at all?
