I love Anduril and would happily have it on all my torches but I do agree that it’s probably not the best firmware for non-enthusiasts. Unfortunately, I’ve found Sofirn’s in-house firmware to be pretty bad - I don’t mind a simple UI, and I’ve even learned to live with hold-for-off, but the inconsistencies are infuriating.
I know it’s unlikely, but does anyone know whether the IF25 uses an ATtiny MCU so there’s some possibility of it running Anduril?
I hope the LT1 Mini runs Anduril (I haven’t kept up with the thread) so it’s UI is constant with the LT1, and there’s a possibility of using the driver in the IF25.
Do you work for them? There are some real things, which looks like the quirks in best case, and fails in real meaning.
The real visible pwm, the low real output against declared, some awfull greenish tints in all light modes with cold leds, unknown reason of only one mode while charging (not even two - moonlight and one middle). Different UI in ramping mode and stepped mode. No diffuser from factory (diffuser for edc18, as example, could be bought separatly in ali for 2.5buks). No modern modes like candle.
But changeable color temp is extremely close for such usings…
They could made this fl more usable in any way, even for this money (as example, i bought edc18 on ali simply for 26buks), but you simply answer
“Nice fl,i like it, if you d’t like some issues - just shut up and go away”
Говоря по русски, у вас поведение “ссы в глаза - божья роса”.
And the last - if sofirn could produce ltmini which would use samsung led, anduril and could be used like hand flashlight, that means they simply cheating with if25 - all this words about awfull beamshots with samsung hicri leds.
I just recently came back to use the IF25 and have started to love it a bit more (probably just like how people get use to things over time). But I missed the floodiness of Lumintop FW series. Yeah, like D’AVerk previously mentioned that the EDC18 was even more floody, which I found suiting me more for my use. Is there any ways to make the beam more floody? I’m thinking of changing the lens but I have not a clue if there is any compatible lenses.
Infinitely variable ramping UI is nice, but not as well done as Anduril. Still quite usable though.
Infinitely variable color-temperature ramping is exceptionally well-done. The LEDs chosen are very good, without much green. The beam is beautiful.
The overall light feels good in the hand, but I would have preferred something a bit narrower. The light is a bit big for pocket EDC.
The light feels solid and well-built with good tint. However, apart the tint-ramping nothing about the light really stands out. Some things that could be improved:
Sometimes when using turbo the light forgets last used non-turbo mode and turns on in turbo.
A “max turbo” option to enable full power on all 4 LEDs would be nice.
After reading this tread about about month ago I ordered the IF25 because I don’t mod lights and this one looked pretty fascinating to me. I’m not usually bothered much by tint and usually stay in the Cree 3D, SST-20 5000k range when I buy something so I wanted to see what this was like.
But I’m really liking the low end 2700k indoors on the IF25 and since I’m in and out a lot at night it’s really great to be able to use the tint ramp outside to go up to the 6500k range. I’m not noticing much green at all when in the 6500k range. I compared to other SST-20’s I have and this IF25 actually looks about the most white without much yellow or green.
For the price, about $30 delivered, I’m pretty happy with it. UI works well enough for me. The only thing I wish it had was a way to keep the blue switch light on as a locator when the light is turned off. The blue light is only on when the light is on (except moonlight) and used as battery indicator. It will be interesting to see if this tint ramping will become a thing with the Emisar lights.
Fairly well done UI with both output and tint ramping. Shortcut to moonlight, on-off and turbo.
Excellent choice of emitters
Feels good in-hand.
Excellent price given how unique the features are.
However, it is a bit bigger than I’d like. I’d love it if Emisar came out with a tint-ramping D4v3 with the same emitter setup and using a modified version of Anduril with the same controls as the IF25 for tint ramping (click + click-hold). And with the option to blast all 4 LEDs at max power.
Thank you very much for the test, the freeman. I sold my IF25 because it was terribly green at high CCTs and at that time I still didn’t know how reflow an led. Please post the measurements if you swap for other leds
After I learnt how to reflow leds, I had a thought of getting LH351D for popping in IF25, but staff from Sofirn told me that the dome of LH351D is too big for the optic.
The sliced leds must have work great. Tints are so rosy. This is probably going to be one of my favourite light.
Has anyone tried swapping SST20 for domed LH351D? I’ve been thinking of popping in the 5700k and 2700k but still doubt if the led really won’t fit the optic as I was told.
The LH351D dome fits but there is barely any play, in practice since the four LEDs wont be perfectly placed I doubt it will fit. Maybe if the LEDs could be perfectly placed by reflowing with the optics on them, but will it survive the heat ?
Nice! Do you have any tips for reflowing a multi-emitter board like this?
I’m thinking I only want to swap out only the CW SST-20s in my IF25 for LH351Ds…though I feel like mixing beam patterns may not look so good.
