Sofirn SC31 PRO, New Anduril Flashlight
Also thanks for the description of beam comparison with Convoy S2+ SST40 version.
I’m also ordering Convoy S2+ SST40 (5000K).
It’ll be interesting to compare them.
Not only SC31 Pro.
C01S has similar situation. There are two “versions” of C01S, with identical specs (both have Low-High modes, not High-Low) , with very slight difference in price. I ended up ordered two pieces, one of each “version”/listing , with different colors, I’m really curious to find the actual difference between the two, if any (aside from the colors) .
SC31 Pro now also available/can be ordered with 5000K SST40.
Glad I could be helpful :+1:
I DO wonder how hot these new SC31 Pro are going to be though. I didn’t think the USB charging would be such a game changer for me too- but I find myself using my USB charge strip daily (especially with my headlights I’ve been using out in the garden at night- pickin’ squash bugs :wink: I’m looking forward to the 5k!
What are the dimensions of the optics that you’ve installed?
And the tint does not look that cold. It looks a bit yellowish on the picture.
Do you think this light can fully replace the SP31 V2.0? It is shorter (by 1.5 cm), lighter (by 12 g), much brighter (2000 instead of 1200 lm) and includes USB-C-charging, for the same price.
The picture with the TIR is in moonlight mode. It’s definitely 6500K in real life.
I have more pictures in this album.
The optic is the ubiquitous 20mm optic used for Convoy S2+ and alike.
Stock lens, reflector, gasket.
Pebbled TIR optic.
WARNING!!! Try this at your own risk. My led died. I think we can safely assume I did it while screwing around. Maybe the optic, maybe something else. I’ve since replaced the led with a 5000K sst40 and put the reflector back in. Everything seems fine now.
I’m in same situation. I might’ve even given in to the tint if it the Sofirn UI wasn’t HOLD-FOR-OFF. But Anduril might make this good enough for a inexpensive light.
Yeah, ditto what BFL-L mentioned. I like your notes on your experience with the IF25A. I got the 4k tint, but after reading your comments, I kinda wish I got the 6k tint for the lumens. They don’t list the lumens for the 4k tint, so I’m wondering if it’s anywhere close to 3800 lumens? Mine is still in the mail - I didn’t know how long Sofirn online store takes to ship these, seems like ships from China.
Probably stupid question but does this light have moonlight mode. A quick scan of the Anduril manual did not make that obvious to me. Does anyone know how low this light will go? Is the only way to access that level to ramp to it?
Thanks
Anduril has hold to moonlight shortcut.
Hold from off. It’s the ramp floor and it’s configurable :slight_smile:
what is your order number ?will check with our store house send out or not, if not it is no problem to change to 5000K tint
You have arranged it very well, thanks Jackie
:+1:
Quote from your thread :
What are some of the current recommended 18350 and 18650 batteries that are good enough for this light?
I use a Vapecell 1100mAHfor my 18350 SP32v2. There has been some controversy about whether these have changed recently. I think you will get quite a few recommendations for 18650 although most seem to like the Samsung 30q. Sofirn has reasonably good batteries for good prices.
SC31 pro $24.99 at sofirnlight.com 5000k version is available.
Lots. 30Q would be std/stock but VTC6, VTC5D (hot), 25S (hot), or if you want a little less lumens, less heat, better runtime: 35E, 36, GA, etc.
Basically any decent cell, non-protected, no button top needed.
SC31 Pro 5000k SC31 Pro 6000k deal price till 28th, Aug t$21.77
I am a bit confused about the different SC31 Pro versions. Is this SC31 Pro 6000K the same as the 6500K
