Wow !! That Moore CNC is a very precision and expensive lathe. I did not know cnc’s could finish machine optical quality and not need a coating to boot !! Thanks for sharing :sunglasses:
Thanks “MascaratumB”.
This is just the body and mirror after paint. More work than it looks. The hope was long range but we are not there just yet. I am still trying to tune the beam, right now it’s more of a flooder, but I hope to tighten it up more. :+1:
When corona is over there’ll be a get together at your house right….?? We can enjoy the beautiful view, feast and then shoot down aliens when it gets dark :laughing:
Here we will finish the first build with 1 x XHP70.2 @ 10A 6V.
Battery box from .125 plexyglass.
Bending the plastic was tricky, many mistakes were made and the lessons learned were helpful on the second box.
Mounting bracket.
Forming the driver cooling tube with a heat gun.
The driver is mounted in the handle.
Here is the test at full power at 10 amps 6v. Unfortunately I thought I took some beam pics but not.
This is the end of the first build. After this test it was clear more light was needed.
Sorry guys, grin, MRsDNF , I thought I took some before I tore it down to mod it. But the beam was not very good. However after modding it improved significantly. I will get some beam shots tonight and post them.
Yes, that is where its at now “tuning”. I have another reflector on order to try improving the beam. The one in it now has been chopped up and a polished Stainless Steel straight .750 long extension added to the end, it gets very hot very quickly. The reflector part stays cool because it reflects the light but the ss extension absorbs some light and gets hot.
LOL, Yes, sorry for not clarifying that. The 2 x 30Q’s are wired to only power the led. The 2 x 18650 EBL’s power only the water pump. And the small single 18500 EBL powers the fan for the driver. I fixed this on the mod, wait till you see it !!
Ok here is the final control box mod for this light. I will finish up tomorrow with beam shots and led mounting.
NOTE: more specs were edited into the 1st post.
After finishing it originally, there were significant improvements that I could not resist doing , so we ordered parts and ripped it up. Sorry about some of the picture quality, we just purchased a new camera and still learning how to use it.
Here are 2 power supplies, power moniter, shunt, driver, mcpcb and batteries. Working on positioning everything.
After struggling with bending the plastic on the first battery box, it was time to get control of it, LOL.
It came with a protective paper covering that was peeled off later.
A little JBweld in the corners.
Mounting the fans and switches.
Mounting and testing the 2 power supplies. Left one is for the water pump 8v, right is for the 2 fans 5v ea.
The left one is set to monitor input voltage for the 4 x 18650 red EBL batteries.
MT09R driver from Lexel in a copper mount.
Wiring it up.
Glueing the hinge in place, painters tape is your friend !
Finished with the control box. The 4 x 30Q’s will power the 4 x XHP70.2 leds
Powered up.
Tomorrow I will finish it up with beam shots and the led copper head.
that’s some great “sheetmetal” work with the plastic for the control box, very professional looking like it was store-bought. Can’t wait to see the final assembly and beamers.
