WTB: Jetbeam RRT01 – Any place to buy it?! + [RRT01 2019 discussion]
Time to drool
I have several of these - you can still manage to use trits like this
or on the EYE 10
Not at all bad!!!
That is one way to do it, for sure.
My solution to the issue:
Trits to be populated soon.
Really nice
Very nice. Would really like to get one of those.
Custom made by a British machinist, to my specs. You may not want to get them once you hear the price. And he may not want to do them again :slight_smile:
Hand made by the way, not on CNC. Perfect precision and tolerances. The trits fit quite snuggly, they don’t swim around and need to be centred like commercial trit buttons.
Wow! :beer:
So, Multicolour or Blue? Vote!
Keep in mind that I will never actually be able to see both the Timasus pattern and the tritium colours at the same time, as it requires both natural an UV light at the same time to take these pictures, so it will be timascus with white vials in the light and glowing vials in the dark.
Blue!!
Blue
That looks BlueTiFull!
if without discs, I also like these options:
and
The post can be useful, with the addition of a small jump ring, to consolidate key items:
the small ring folds away to allow tailstanding
Thank you jon_slider.
I do not agree with the use of tritium vials outside specially designed grooves, as I consider it unsafe. They are too fragile and the tritium is harmful if inhaled. Granted, in this case the recess at the back of the TC-R1 is probably protective enough, but still not as much as with the disks.
The vote is in and blue won by far. So, here you go...
Pretty sweet Pol77. :+1:
If I would have been on earlier, I would have voted blue also.
Thanks guys.
I fancy some fancy screws for the clip. Does anyone know the size Jetbeam uses so I can find option online?
Also, Anyone using a different / better clip?
Wow :open_mouth: super nice trit tails :heart_eyes:
My low budget solution.
Oveready:
some other clip pics here
maybe copy McGizmo:
BlueTiFull :beer:
I kind of doubt that Jetbeam used at US standard size screw.
Not saying it’s impossible, just not very likely.
I might see if I can ID the screw size.
Any luck with IDing the jetbeam screw size?
Also, does anyone know the size of the metal ball in the TC-R1? I guess it should be the same with the RRT-01, all models.
