✌ FREEME - Haikelite HK90 3*Luminus SBT90.2 High Lumens 3*21700 Flashlight - ALIVE
Specifications:
Brightness: 18000lm
Throw distance: 2000m
Material: 6063 aluminium alloy barrel with HAIII, stainless steel bezel, ultra-low internal resistance copper alloy silver-plated spring.
Lens: tempered glass lens, anti-reflection purple coating
Color: black/desert fence yellow/ aluminium natural color (optional)
Battery: Three 21700 power batteries (pointed, half-pointed)
Charging: Type-C charging port, 5V/3A fast charging
(when charging-the switch lights up red; charging is complete-the switch lights up
Light blue)
Charging time: approximately 5hrs for three pieces of 4000mAh 21700
Emitter: 3x Luminus-SBT-90
Color temperature: official 5700K (true white)
Light intensity: 75Kcd
Waterproof rating: IPX7
Product size: 200mm (total length) x 100mm (head Part) x 60mm (tail part) x 53mm(barrel)
Product weight: bare barrel 1119g
Packaging weight 1685g
Packing list:
  • HK90 flashlight*1
  • Waterproof O-ring*2
  • Product manual*1
  • Braided hand rope*1
  • Carrying strap*1
  • Gimbal screw*1
  • Type-C USB adapter cable*1
Photo credit: Haikelite
Reserved.
Reserved.
Reserved.
Interested
Interested
Interested
Interested. Wouldn’t 4 X 21700 make more sense? Hopefully it doesn’t have the fake FET.
Can you elaborate?
What FET are you referring to? And how can an FET be fake?
Very interested!
Probably, he was referring to the weak (?) Vishay SIR800 MOSFET that was used in some batches of HaikeLite's MT09R? This FET was reported to burn up in some samples of the MT09R when someone bypassed the springs. However, I bought exactly this MT09R and pentested it with Sony VTC6 and bypassed springs - and nothing went kaputt. Lexel has recommended using the Infineon OptiMOS 5 FET instead, if I recall correctly. Anyway, I would not be too worried at this early stage of this new flashlight.
Interested
Interested !
lets hope their quality has improved.
Interested
In!
Please note that price could be over $200 even with group buy. SBT90.2 LED cost about $40/pc, so do your math.
What is this? If it is what I think it is, it seems like a big mistake. It looks like an appendage at the base, bye bye tail stand. I imagine that this appendix is ​​to attach a hand strap. OMG, they couldn’t pick a worse place to put it.
I hope it is a rear like the one on the MT01, and allows tail stand.
Interested.
Price seems acceptable as I hate too bulky lights but still need to evaluate the specs!
