One of my favorite flashlights is the recently discontinued L11C. I have a 3-mode neutral white with Nichia 219 and a modded 2700K with SST-20. They are fantastic pocket lights.
One of my favourites also. I have the 4-mode 219C. It’s so slim and has perfect mode spacing. I don’t use it as much as I should due to all the reported durability/reliability issues (might only be for the L10/L10C but can’t remember).
I just noticed there is a new update (it may or may not be new...) for the Convoy T2 -- I ordered the Nichia 219C 4000k & 5700k to check (previous Convoy T2 only use XP-G2).
Whereas:
previous T2
- only supported AA officially (14500 not officially)
- uses slow PWM (likely visible to people sensitive to PWM) on non-max brightness levels
I notice the new T2 now:
- doesn't have PWM in all brightness levels when using AA batteries,
- it uses "fast PWM" (likely not visible) when on lower modes while using 14500 battery (max brightness has NoPWM).
This is a tail-clicky AA/14500 flashlight and the Nichia 219C (at least the sample I got looks good tint -- not as good as my rosy 219B, but appears better than some 'greenish' 219C I've previously experienced from some Convoy flashlights).
I think Sofirn has not used Nichia LEDs yet on any of their flashlights (instead going for LH351D and SST20 for their high-CRI series)... although there is talk about the C01S or is it the SP10 series to use Nichia EA-series LEDs for good high-CRI?
I'm happy to see so much response on the idea of a Sofirn AA headlamp. It seems Sofirn is also interested. I quickly drew a design how it could look like in my imagination. As always, any feedback is highly appreciated. :-)
There are plenty of possibilities, like using a dual-optic design or a single-optic design (with a multi-emitter setup underneath like Armytek's Wizard WR). Since 300lm should be fine for a AA-sized and driven headlamp, maybe Nichia's E21A 98CRI could be a viable option (provided that Sofirn can get ahold of this LED). The driver should support a constant current regulation where both red and white light is fully regulated throughout the entire battery runtime. The USB-C port is probably disputable as these rubber boots get lost too easily. OTOH, I don't think magnetic charging (like Armytek/Olight) or a port inside the threads will be better options.
I am definitely interested if the finished product is similar to the sketch here. However, if it is not as light or lighter than my SKILHUNT H04 (46 g excluding battery) then there’s not much point for me; and Sofirn hasn’t really made any truly small lights. Most of their lights seem to be a tiny bit larger than most of their competitors.
That’s likely a manual process, also error-prone (slicing crooked, taking part of the phosphor with it, killing the LED itself, etc.), so I’d seriously doubt it.
Slicing is a manual process, but not necessarily error-prone. It should be fairly straightforward with the right tools and a bit of practice.
Many of us care more about tint than output, offering sliced LH351D could be an easy and inexpensive way for Sofirn to make their flashlights more desirable.
This would be great with the dual emitters. The E21A would be fantastic, and the 660nm deep red would be the best. Fixed modes are good for this on the initial UI, that way we have a means to guess runtime. I like ramping, but it does not give you a good idea of runtime for the level you are on. I know TK is working on the UI improvements, so this is something to think about during this process.
If the emitters are simply not able to be done in a dual format, then I hope the price is right so we can get both color emitters! Thanks on this LP!
Does anyone know what LED(s) Armytek uses for their Wizard WR? It seems to be an emitter with four dies, where two are used for red light and two for white light.
I’m not sure since I’m not Sofirn, but I wouldn’t be surprised if we see more lights with Anduril. I’ve got Anduril 2 virtually complete, and mostly just need to finish making documentation for it… so it should be a lot easier for new users soon.
I very interested in a AA/14500 right angle/headlamps with Anduril, but personnaly I’d want it to be as small and lightweight as possible, like a Zebralight AA. Integrated charging would make it significantly bigger, as well as multi optics/LED channels designs, and I’m not sure feature creeping helps the realisation of a project.
That said I doubt they could achieve Zebralight size/weight, Sofirn don’t seem to make very small lights, their AA are on the larger side, and ZL put the LED and driver on the same PCB for space saving.
E21a could be nice yes, but I imagine would complicate design and manufacturing, with the 300lm figure you gave and 4500K 9080 it would mean ~1.2A drive current, which I think at this current would requires a good performing MCPCB with very low dielectric thermal resistance. 3535 design is simple and also modable.
There is the Manker E03h II that released recently, but it has a 10lm ”moonlight” with li-ion which is pretty bad, and the UI while improved doesn’t allow to cycle from ”moonlight” to low-mid etc, probably don’t have PID regulation either, I sure would prefer Anduril. Most of the other available AA/14500 headlamps are heavier and larger, there is Zebralight of course but they don’t support li-ion, which is a shame because the 14500 li-ion cells have significantly more energy.
Merci pour tes suggestions, thefreeman. I'm mostly d'accord with your feedback. The integrated charging circuit is a disputable feature for sure. Actually, I do not want any feature creep here but a very simple UI that can handle both red + white light modes. Consequently, this rules out using Andúril as it is too complex and it would require significant changes in its source code to work with dual emitters, working independently. There were some discussions among the LT1 team incl. ToyKeeper using a red light mode in the next evolution of Sofirn's LT1 and maybe it can be done with Andúril 2.0 by tweaking the tint ramping feature. But again, for now I doubt this will be the best idea for a small headlamp.
Comparing Sofirn's headlamps with Zebralight's headlamps is in my humble opinion a bit difficult. For one, because Zebralight is known for squeezing high-end technology into supersmall lights, e.g. SC64 with a fantastic boost circuit and stable output above 900lm. Their drivers are highly integrated and customized to the corresponding host design, using glue and potting. For second, also because Zebralight is quite a different pricing level, about 3-4x as much as Sofirn's (discounted) prices. If we aim for an AA lamp as small as Zebralight's H502pr there would be two scenarios in my lay imagination...
a) we should try to invite Zebralight to BLF with an educated proof of concept (and expect a sales price around $ 100.00)
b) we need Sofirn to divide their business into a 'budget line' and a 'premium line', where the latter one uses highly sophisticated drivers, hand-picked emitters, ultra-precise CNC machining and tooling etc.. - effectively with a smaller lot size and significantly higher prices, too
Sofirn has difficulties sourcing Nichia LEDs, so I am open for any recommendations that offer a great color rendition. SST20 4.000K 95CRI could be a nice alternative as it does not create as much tint shift as E21A. I wonder if Cree has anything to offer since they also sell HighCRI versions of their LEDs. I still try to find out what LED layout Armytek is using underneath the TIR optic of the Wizard WR. It seems they placed both XQE and XD16 in a two-by-two quad array, like Cree's XM-L color emitter. Maybe this would work nicely for this AA headlamp concept, too.
