I don’t have a M150 V1 to compare with. But I have the M150 V2.
M150 V1 UI:
M150 V2 UI:
Enter and exit Lock-out mode:
From off:
Hold for 3 seconds until you see 3 fast flashes. Release.
Switch between Mode Group A and Mode Group B:
From off:
Hold for 5 seconds until you see 3 fast flashes followed by 3 slow flashes. Release.
Which mode is the flashlight in?
From off:
Single click on. The flashlight should be on. If the flashlight turned on momentarily and then off when you released, then you’re in Lock-out mode (exit lock-out mode!).
Single click again. If the flashlight turned off, then you’re in Mode Group B.
Mode Group A
There are more details on:
Mode Group B
From on, you can hold to ramp up between the enabled steps. Each step can be toggled off and on. The order from lowest to highest is L2, L1, M2, M1, H2, H1, T2.
M150 V1 UI ramps up from Low to Turbo and down to Low?
From off:
Single click to turn on. This enters the last memorised step.
Hold for a few seconds to enter L2 (or the lowest step).
Double click to enter Turbo.
From on:
Hold to ramp up between the enabled steps.
Triple click to Edit Mode Group B steps.
Edit Mode Group B Steps:
From on:
By default 4 of 7 steps are enabled (L2, M2, H2, T2). The flashlight will cycle through from lowest to highest: L2, L1, M2, M1, H2, H1, T2 while editing. A red light will appear if that step is enabled.
Click once to toggle a step on or off. The red light will turn on or off.
Hold for one second to save your preferred steps. You should see 3 fast flashes and the flashlight will remain on.
My Skilhunt M150 V2 arrived without (any?) glue. The head screwed off easily. :+1:
The switch is still difficult to find in the dark. I keep pressing the charging port on the opposite side of the switch. A pocket clip might help distinguish between the two.
I ordered a RD TC66 for USB Type C but it didn’t arrive. After 90 days I was able to file a dispute. AliExpress asked me to wait a little longer… so after about 100 days they provided a refund. I’ll order again on 11.11. Hopefully it arrives this time. :weary:
I use the RD UM25C USB Meter to measure the voltage and current used by small chargers (e.g. Xtar ANT MC1 Plus) or devices with built-in charging (mobile phones, flashlights).
It can help with verifying what current can be drawn from a particular USB port. E.g. The USB port on my radio in my car only provides 5V at 0.5A. Charging a mobile phone from that can be slow. However, the USB port in the cigarette socket supports 5V at 2.4A.
Modern USB Meters may also be able to detect whether a device is using QC2, QC3, USB PD etc.
I wanted to use the TC66 to see what my MiniWare TS80 soldering iron is doing. As shown on eevblog:
