I can see Astrolux FT03S has got some bad reviews. Has Astrolux improved their build quality with the FT03 mini?
Bad review FT03S SBT90.2 hype train. Is the Astrolux FT03S worth triple price than FT03? - YouTube
Sorry, I ain't got time for a 32 min vid to get a simple answer... Yikes!
I think he means cslnm1.tg - white flat 1.
Interested, SST-40 (5000K) or NM.1(?), depending on which one has the best throw and tint (5700K to 4000K).
Any more?
NM.1 vs SST-40 Wainlight C8+ (Osram NM1) vs Convoy C8+ (SST40 5000k ramp driver) - YouTube
Edit: If the Osram orange colour is as bright, it would be exciting to test how it works in fog and rain.
A code for the FT03 Mini XHP50.2 would be greatly appreciated as no codes appear to work from page 1 ?
Thanks
I too would love a code for the FT03 Mini XHP50.2
The NM.1 has popped up on BG. Not available yet.
Full copper still happening? Interested!
Ok, NM1 = W1. Put me down for 1 as interested!
Note the more simple driver. Not a problem, just mentioning.
That was my thought exactly!
Interested
Interested. Could I get the coupon?
Interested. Are there any other lights with the nm1 I could look at to get an idea of what its about?
There is the Wainlight C8+ with Osram NM1 LED, this is very similar to other C8 flashlights, but produces a more focused (more throwy) beam, but less total light output.
left:Convoy C8+ with XPL-Hi LED
right: Wainlight C8+ with Osram NM1 LED
Osram NM1 LED has a very tiny light emitting portion (the yellow square)
left: Convoy C8+ with XPL-Hi
Osram NM1 lights up a smaller area but more intense (throws farther).
I suspect the FT03-Mini with Osram NM1 will have similar throw (or a bit better) as the Wainlight C8+ with Osram NM1, but with better user interface.
Also the Osram NM1 LED on the Wainlight C8+ only uses up to 2.8 Amps max power, not yet maximizing the Osram's potential. Hopefully the FT03-Mini will better optimize the power (maybe like 4.5 Amps of power applied to the Osram LED), and also have a well-focused reflector.
def interested in a nm.1
interested blue one
