I cut 2 small pieces of kapton tape and stuffed them in the battery + side to keep those bits in place (removing the foam insulator cause I dont know how it handles heat), honestly gravity MIGHT be enough but better to be safe.
I stuck the whole head minus bezel, minus glow tape on the preheater we both have, set to ~200 I think.
Since the heat transfer is bad with Ti and all these connections even at 200 it really wont reflow yet, which is good. Around 190 on preheater I take hot air set to around 385F/19xC and fan speed all the way low and I apply heat from the top. Distance is maybe 4 inches away and I work my way around the LED sometimes going in a bit closer. Since you are removing the LED you could honestly just hold it there but I dont want other pieces to overheat or move. Keep trying to lightly pick up LED with tweezers till it gives in. (* take a picture before you remove it so you know polarity!!)
To apply new LED it’s similar with one small change to make your life easier:
If solder on board looks good and even and you are using brand new LED then put the smallest dot of solder paste you can with toothpick on all 3 pads of driver. So small you think it wont even do anything (you cant easily squeeze out extra). Optionally you can continue to next step and additionally apply flux paste as well, probably recommended.
If solder on boar looks good and you are using a used LED dont apply any solder paste. Substitute with flux paste. Blob some on a napkin or something then dip your LED in it to cover the bottom. Blot the excess and spread it around with a clean part of the napkin and you should see a nice coating on the underside.
When you go to reflow it the flux paste and/or solder paste sandwiched between the driver and LED will allow the hot air to re-melt the solder even sooner than when you removed it the first time, give it a tap or center it if necessary.
flux and solder paste really make re-flowing easy. kind of have to treat it like any other component. re-flowing on solid copper pcb is nearly foolproof and the extra heat sometimes lets you get away with joining two bits of crusty old solder when you probably shouldn’t. if you clean stuff first and apply flux paste the solder will flow like it’s brand new for several reflows. it’s easier cleaning up the sticky mess it makes after your stuff cools than to try to go without it.
Parts finally came in for a full driver build from scratch using an Attiny1616 running Anduril, which I’ve recently ported over to the new 1-Series chips. I have other flashlights running Anduril on a 1-Series but they’re kinda hacked together with adapter boards.
This is a 20mm FET+1 layout. Installed it in a Sofirn SC31B. Somehow the stars aligned and it compiled first try, and when I flashed it, everything worked. I love it when something goes right for once!
sorry, I hadn’t cleaned flux off yet
There’s nothing revolutionary about the driver itself, but now we’ve got a full test model with the 1-Series.
FW3A with Osram Red Flat and lume1 driver and RGB aux board. Even at the regulated 3A it kind of hurts to look at the beam in a small room. It’s a bit crazy.
It peaks at 625, but avg 620-625nm, which is spot on from datasheet.
The camera picks up even more red than my eyes see.
My impression of red LEDs? I don’t know what to use them for but you better believe the first/last/next time i’m on a submarine i’ll be the talk of the sea. There are probably hogs, coyotes and deer in that tree line but the red light wont help me avoid fire ants on the way. haha
Just finished fixing the MT09 Buffalo led that fried after converting a 6v mcpcb to 12v to match Lexel’s 6A driver.
Burnt one and new parts.
. 8512 lux @ 6.46 meters.
I am very happy with this finished Buffalo, it is the most enjoyable mod I have done. It is very bright
Stock approx - 4100 lumens, 450 meter throw
modded approx - 6500 lumens, 1200 meter throw
I upgraded my 2x D4sV1 lights with D4sv2 drivers and rgb aux boards. While I had them apart, I swapped some sst20 660nm emitters into one of them. My house is about 100 yards away in this picture.
