flux and solder paste really make re-flowing easy. kind of have to treat it like any other component. re-flowing on solid copper pcb is nearly foolproof and the extra heat sometimes lets you get away with joining two bits of crusty old solder when you probably shouldn’t. if you clean stuff first and apply flux paste the solder will flow like it’s brand new for several reflows. it’s easier cleaning up the sticky mess it makes after your stuff cools than to try to go without it.
Parts finally came in for a full driver build from scratch using an Attiny1616 running Anduril, which I’ve recently ported over to the new 1-Series chips. I have other flashlights running Anduril on a 1-Series but they’re kinda hacked together with adapter boards.
This is a 20mm FET+1 layout. Installed it in a Sofirn SC31B. Somehow the stars aligned and it compiled first try, and when I flashed it, everything worked. I love it when something goes right for once!
sorry, I hadn’t cleaned flux off yet
There’s nothing revolutionary about the driver itself, but now we’ve got a full test model with the 1-Series.
FW3A with Osram Red Flat and lume1 driver and RGB aux board. Even at the regulated 3A it kind of hurts to look at the beam in a small room. It’s a bit crazy.
It peaks at 625, but avg 620-625nm, which is spot on from datasheet.
The camera picks up even more red than my eyes see.
My impression of red LEDs? I don’t know what to use them for but you better believe the first/last/next time i’m on a submarine i’ll be the talk of the sea. There are probably hogs, coyotes and deer in that tree line but the red light wont help me avoid fire ants on the way. haha
Just finished fixing the MT09 Buffalo led that fried after converting a 6v mcpcb to 12v to match Lexel’s 6A driver.
Burnt one and new parts.
. 8512 lux @ 6.46 meters.
I am very happy with this finished Buffalo, it is the most enjoyable mod I have done. It is very bright
Stock approx - 4100 lumens, 450 meter throw
modded approx - 6500 lumens, 1200 meter throw
I upgraded my 2x D4sV1 lights with D4sv2 drivers and rgb aux boards. While I had them apart, I swapped some sst20 660nm emitters into one of them. My house is about 100 yards away in this picture.
