Green LEDs are the most efficient by far and will be much more brighter than blue. For my tailcaps, green uses 0.03 milliamps vs blue at 0.21 for the same comparative brightness.
So if you’re having problems seeing light thru the S2+ metal switch, you may want to swap the LEDs to green. Unless you don’t mind lowering the resistance and putting more amps into blue. Any color will eventually work if you lower the resistance enough, but I prefer to get a year or more out of my lighted tailcaps before I need to recharge the battery.
I have a Rev3, I put a 560 ohms resistor, and in my tail cap switch, I changed the resistor to 2.7k ohms, and finally, it works all modes well. The only thing I experienced is when I try to use the 1k ohms has a problem, based on my case, using from 2k ohms above will work fine on the tail cap.
All of the said resistors, I took to my electronic device which is not working at all, ( tv receiver).
Hoping that this experience might give an additional idea to others.
Usually a certain bleeder resistor value is needed for a driver to work and the switch resistors just impact the brightness/current. But strange things can happen with various drivers and firmware.
Did you try a different bleeder resistor when you used the 1K ohms switch resistors? If the brightness is good enough with 2.7K, then no worries.
Using 1K Ohms is a little bit lighter but noticeable. I did not try yet to changed the value of the bleeder. As of now, i am planning to add 0805 Led and a resistor as well on tail switch, to mix colors. That might be the time to changed the value of the resistor if that will not work.
At first, I only wish to work all fine after this modified, but now I am seeking more to make this project more impressive.
I finally have a true yellow tailcap that is efficient! It measures 0.15 mA - so with a 30Q battery, it will last over 2 years. I would consider it a bright (canary) yellow.
I combined warm white and green 0805 LEDs:
Here it is compared to my green and warm white tailcaps:
Can someone please help me to get the tailcaps working right?
I have an orange and a blue one,
and I have 2 Convoy S2s with the same driver
The blue one works on both, but the orange one is messing with modes of both and puts the drivers into the low battery flashing mode when I try switching modes by pressing the switch
I have checked the LED resistors, both are 300ohm
Should I put a lower value resistor for the blue?
[Edit] It shouldn’t be a bleeder resistor problem since the flashlights work with one, right?
Since everything affects everything in this way of making a tailcap light, an orange led instead of a blue led could already make a difference,it is a matter of trying to find a configuration that works, and yes the bleeder resistor is the one to try first: if the user interface is messed up, try lowering the bleeder value.
From what I’ve read in this thread people use up to 47k LED resistors, are 300ohm OK ??
There is currently no bleeder - stock 105C drivers
I’ve also read about a person using a 6.9k bleeder for a 7135 based driver, so I think I’ll start there
I nearly always use a 750 or 840 Ohm resistor for the bleeder, especially in my 105c’s. Start there, as djozz said.
Tailcap resistors in the realm of 47k are for the ring-style tailcap boards, not for when the LEDs are on the switch’s PCB. Since the ring-style boards are right below the switch cover, they don’t need to be as bright in order to appear brighter.
I guess I’ve been missing some stuff lately
Nice and well done! It looks quite nice on the blue/gray version! I guess I’ll have to try one myself
Thanks for sharing! :+1:
Thanks NeutralFan. The metal switch is slightly (very slightly) protruding from the tailcap, but it can still tailstand nicely and gives cool glow effect. I’ll take a photo later.
Yes, mine is rubber button S2+.
Thanks MascaratumB
This is the convertion kit, also available for bigger light like M series and S series Convoy.
It’s connected from Bat+ (Pos) to Bat- (Gnd) on the driver. It provides a path for current to get to the tailcap without going thru all of the driver’s electronics (which could power up the MCU and make mode switching funky).
