Hello Fin, Could I get a coupon for the Amutorch E3S 3xSST20 please. Thanks
Hi, I would like the AMUTORCH E3S code as well. Thanks
Thank you very much Fin, ordered one
Hello Fin, Could I get a coupon for the Amutorch E3S, please. Thanks!.
Thank you very much Fin.
can i also get the code for AMUTORCH E3S please?
Would the same be possible please?
I wonder how the Wuben LT35-Pro differs from the Wuben L60/LT35 (I’ve tried the L60 and LT35, and they look exactly the same, and basically are the same performance, with only 1 UI change that I noticed: LT35 has 4 brightness levels + SOS, which is part of the regular brightness cycle, and will be memorized), whereas the L60 has SOS mode accessed via double-press, and doesn’t appear to be a memorized mode.
The LT35-Pro’s head design looks different, but the specs still look quite similar to the L60/LT35… I wonder if the zooming distance (widest & most focused) has changed or not (the L60 and LT35 have exactly same focus from widest to narrowest).
Can i also get the code for AMUTORCH E3S please?
Thanks ,last minute order.
thank you fin!
AMUTORCH E3S code please. Thank you.
Code for the AMUTORCH E3S please
Thanks!
(Is battery included? it is a pain to find to find this format)
Fin17, Do you have a code for the PL47 for Banggood?
Thanx for the code!
Do you also sell 20350 li-ion batteries or is it included?
(E3S)
