Sofirn SC31 PRO, New Anduril Flashlight
Mine doesn’t look like your pic. My USB is centered/aligned with the opening. Hope that helps.
Mine is also off center, but plugs in fine and charged up fine for the first time tonight.
Does the rubber cover fit into the USB C slot?
That’s a very neat light actually
Still a little long for everyday pocket carry. The extra mass is good for actually using it though. It would be more of a grab off the table and stuff into my pocket for a walk outside kind of light.
I’m thinking of using it with the 18350 tube and a deep carry clip. I wish both of them came with the light though.
No, just the larger hole above it
Damn, i thought i checked the 18350 tube when i got it but i guess not, seems the SC31Pro head threads are slightly different than the SC31B,sp40, etc…
:frowning: doesn’t fit
Weird that either tail cap fits either body…
Can we swap the battery tube with Convoy S2+’s tube ? :question:
I have a spare 18350 tube .
Strange. According to Nooner the official Sofirn short tube should fit:
Hmm guess i’m just lucky, lol. Maybe my ano or threads are slightly off.
It will thread but extremely tight. Down to 3.25” with 350 tube and old tailcap :slight_smile:
Good idea but I like the run time a 18650 gives . Life is a compromise though.
I just checked the thread compatability of my SC31Pro with some of my other Sofirn lights.
I’ve discovered that the internal threads of the SC31Pro head are tighter than my other SC models. Very little backlash.
The threadform is the same between the models. The machining tolerance of the 31Pro head is tight. Evidently too tight in your example jp9mm.
Does anyone know of a good pocket clip that works well with the the light in 18350 configuration?
Somebody mentioned Astrolux S1/BLF A6 clip should work so I ordered one to test.
Thank you for the input McCatface.
Yah that definitely could be a candidate. Let us know how it works out.
I KNOW I should post pics or a video but time isn’t on my side these days. However, I have used this light for two nights now and I like it a lot. That said… for another few bucks I still like my IF25a a little better for the larger battery and wider, deeper beam.
Don’t get me wrong here… this SC31 Pro is a keeper. I suspect IF I elected to do the EDC “thing”, that it would be a better fit all around. But for the light jacket/gym shorts pocket light in the larger garden I do prefer the IF25a with a 5000mAh/10A Epoch (50g) battery. It doesn’t cook in the hand using this 50g battery like when using the Molicel P42a (excellent high current, but just not needed for my use in this light- gets hot FAST!).
The SC31 Pro does get hot about as fast as the IF25a using the 50g so it’s probably a bit better in the heat management dept. if I used a higher capacity 16850 in for longer run times (like the 50g in the IF25a).
Two GREAT lights, and I’m looking forward to getting my 5k version of the SC31 Pro for closer-in use where the color should be superb!
Just more random thoughts as I play with this thing :stuck_out_tongue:
Thanks for the report Zappaman, it’s good to hear you’re happy with the lights. How’s the built-in charging function, is it good? Could you compare its performance to external charger in term of charging speed etc?
BLF-L, Charging works fine so far and unlike my IF25a (which only charges to about 4.15V, BUT reports 4.2 using Anduril’s voltage check) this SC31 Pro charges all the way up to 4.2V (and reports it correctly in Anduril).
I’ve only used A-C USB charging so it’s not a speed demon in any case, but I usually charge overnight so no matter to me. I’ve had a 25R in it, topped off- both the last two nights but now that comparisons are done the SC31 Pro will get an LG MJ1 which won’t be quite as bright on turbo, but have another 1000mAh’s of capacity/run-time.
Last note is that the Anduril version is higher than my IF25a’s too. The SC31 Pro reports back what was said to be the March ’20 version when clicked 15 times. My IF25a doesn’t report back with the same 15 clicks.
Sofirn was so kind to send me a sample of their new SC31 Pro (6.500K version) plus an extra magnetic tailcap. Thanks a lot to Sofirn.
I was not able to do any beamshots yet but I like to share my first impressions with you. Here is my verdict so far, comparing it with it's "in-house competitor" Wurkkos FC11 (prototype sample shown here):
Packaging & Content:
The light arrived in impeccable condition in Sofirn's new cardboard box design which looks more appealing than their former design. The extra tailcap was put into one these small boxes they use for small AAA lights like C01S/C01R. To my surprise the manual is now offered as a booklet in much more languages and with a better readability with a bigger font. The manual's layout however could still deserve a bit finetuning. Sofirn also found a nice way to highlight the necessity of removing the insulation paper from the battery. Once you take out the light from the box you will notice a small "badge" tied to the tailcap, informing you to remove the insulation before first use. Well done! The accessories are a 3.000mAh 18650 battery, a lanyard, a USB-C (type A-C) charging cable and the manual. The battery had an initial resting voltage of 3.95V.
Appearance:
Anyone who bought SC31B (the predecessor) or Wurkkos's FC11 will recognize a quite similar shape and design. Size-wise SC31 Pro is about the same compared to Wurkkos FC11. Both lights share the same threadings, so feel free to play LEGO with the parts. Even Sofirn's SP40 18350 tube will fit nicely to SC31 Pro, see below. I did not spot any significant imperfections. Everything is well made and assembled. The heat fins are not as sharp-edged as reported before on some other lights like SD05. They even took care of placing the laser engravings and tailcap lanyard hole in parallel to the side switch button. Being a nitpicking as usual I could mention a very small nick in the black-anodized clip and a very slight haze on the inner side of the glas lens - but this is nothing to worry about and therefore ony a sidenote. The LED is to my opinion well-focused in the reflector. Bottom line: Good job, Sofirn!
UI:
The flashlight comes with Andúril (revision is stated as 2020-03-18). The default UI of my sample uses stepped ramping and not smooth ramping as indicated in the manual. According to the manual the light will start at a regulated level of 125lm (1x 7135) after replacing the battery. The temperature check indicated 37°C at ambient conditions of 22°C, i.e. the flashlight is not calibrated from factory. Therefore, I recommend everyone to first do the thermal calibration (triple click from off, then three times doubleclick to enter temperature check, then another 4 clicks to enter thermal configuration, see manual). Once properly calibrated, there will be no early or late stepdowns. According to the manual the firmware is programmed to stepdown at 45°C already. I did not test this yet but it is a safe value for beginners and sensitive hands. If you want to unleash the full potential you may change the threshold to way more than 45°C.
Beam:
As mentioned before, I did not have a chance to make beamshots yet. Still, the SST40 emitter fits very well to this light, providing a very allround-like beam profile with a distinct hotspot and a good proportion of spill around it. To my surprise the tint is absolutely not as coldwhite as expected. Those 6.500K look much more like 5.700K to my eyes which is great because many people on BLF and TLF seem to prefer tints below 6.500K. Maybe I get the chance to compare the 5.000K version with the 6.500K version to see the actual difference. TL;DR, those who are afraid of an AngryBlue™ don't have to be worried here.
Final words so far...
Sofirn's SC31 Pro is much more than just an evolution of the SC31B. It is also a great competitor or addition to Wurkkos's FC11. Those who prefer bare output as well as Andúril's flexibility over HighCRI and a simplified UI will be absolutely happy with this light. I am confident that both SC31 Pro and FC11 will be good recommendations for anyone who wants to buy an affordable but also powerful and versatile flashlight. These lights will also work greatly as gifts or for beginners who have just started to become flashomaniacs. For a bargain price between $ 15 (according to last week's promotion on AliExpress) and $ 30 you get a lot of flashlight in return.
Nice review, I wonder what warmer led around 4k would be easiest to make another version?
The other 2 things i was not as lucky. My sp40 350 tube very tight, only will go 1 end and i even wrote a note to include magnet tail but did not get one.
They make a nicer deep carry clip it would be perfect
