I clicked the link but “Page not found” , is it broken link or my browser is broken?
2.29€ |Universal clip, geeignet für S2 / S2 + / M1 / C8|clips|clip universal ...
Smarter Shopping, Better Living! Aliexpress.com
It is not sturdy or i got bad copy. The one you have on S2+ is awesome
Well, this is actually a very versatile pocket clip! I have it installed in different light, Convoy and non-Convoy. Curiously, the only Convoy “tube light” I have in which it doesn’t fit is the Convou T2 (AA/14500).
Being a “screw-in” clip, it can be easily installed in light that have lanyard holes in the tail, such as these, and many many others.
(Convoy S6, On The Road Z821, Sofirn SF10, Sofirn SF14, On The Road i3)
!https://i.imgur.com/RYMYC50.jpg !:https://i.imgur.com/RYMYC50.jpg
Can you check how thick are your clips?
I've got mine from Fasttech and they are paper thin...
I measured 0.81 mm thick in 3 different clips
Oh great, THX.
As i said Simon please bring clip-on clips for 21700 hosts
I bought a small pile of these deep-carry clips at ~1buk each
https://www.fasttech.com/product/4594500-stainless-steel-flashlight-pocket-clip
and they’ll even fit other lights like a Nitefox UT20 and anything that has a narrower groove (so they don’t wiggle around and scratch the ano).
id30209:
Clip is ok for smaller hosts but bents easily on heavier lights.
This one but bigger would be niceI clicked the link but “Page not found” , is it broken link or my browser is broken?
I fixed the link for you:
universal clip ,suitable for S2 / S2+ / M1 / C8
5 clips for $5.30 is not bad
I think these are great too, and they also have 15% off sitewide tomorrow
I will keep a bottom hole in the holster, and I want the holster to be slung on the back waist instead of the side waist.
That’s great, so the next Moonless night, a bunch of L21A’s will be lighting up the sky. :disappointed:
[quote=caramba]
id30209:
I would say to use this one for bigger lights!
https://www.aliexpress.com/item/32966941249.html
I used it in my OL mod earlier this year!
This week arrived another piece for this flashlight! The clip [image] [image] [image] [image] Things are coming together and the mod is almost done! The thing that needs to arrive to “close” it is the GITD gasket that I want to put in place before putting the optic on this light!
Simon Mao:S21----small 21700 flashlight ,Then sequence character A,B,C,D… I am worried that the model is too complicated to be remembered.
Letter+number names turn into a jumble to me. Maybe animal names? Jaguar, Bear, Skunk, Squid, etc.? Those I could probably remember better. :laughing:
I think they should name a light after you. I am voting for “Lightbringer 911 Turbo”
I would say to use this one for bigger lights! Page Not Found - Aliexpress.com
Meh...Have originals...
Better use Jetbeam RRT clips, 10pcs for 8$ but they are not Convoy.
I admire your faith in Paperthin clips Mascartum
Never had a single one failing me
I did. I don't EDC anything but only using as a tool at work and i've seen thick mofo's bent like chewing gum.
Out of work don't like having anything with me LOL
Simon Mao:My metal clips can be installed on them, but they will leave scratches.
I presume you are talking about screw on clip but i had i mind S2/S2+ clip
uh,i mean the black metal clip ,
the screw for stainless steel clip is short
uh,i mean the black metal clip , the screw for stainless steel clip is short
Wait, i can stretch black S2+ clip on S21 body? It won't brake?
Simon Mao:uh,i mean the black metal clip , the screw for stainless steel clip is short
Wait, i can stretch black S2+ clip on S21 body? It won’t brake?
You can barely use it, but I don’t recommend it.
Wellp, I can confirm the above report informing that AliExpress had removed the “other payment methods” option altogether (from the application too). But only in the newest versions of the toilet
Downgrading the application is a workaround.
I found a simpler way, chose webmoney (paypal should work too I guess, the aim is to get taken outside of aliexpress), place the order and when you’re out of aliexpress close the tab/cancel. The order will be made but left unpaid.
Barkuti:Wellp, I can confirm the above report informing that AliExpress had removed the “other payment methods” option altogether (from the application too). But only in the newest versions of the toilet
Excellent
I had an old version installed on computer with BlueStacks so that’ll help a lot, thanks
Hello Simon,
Will the KW CSLNM1.TG 6N-ebxD46-15 6000-6500K work fine if driven with your SST40 12group driver ? or should I better stick with the 7135*8 driver instead?
thank you
