I bought a small pile of these deep-carry clips at ~1buk each
https://www.fasttech.com/product/4594500-stainless-steel-flashlight-pocket-clip
and they’ll even fit other lights like a Nitefox UT20 and anything that has a narrower groove (so they don’t wiggle around and scratch the ano).
caramba
(caramba)
August 31, 2020, 9:22pm
3051
I fixed the link for you:
universal clip ,suitable for S2 / S2+ / M1 / C8
5 clips for $5.30 is not bad
I think these are great too, and they also have 15% off sitewide tomorrow
caramba
(caramba)
August 31, 2020, 8:36pm
3052
That’s great, so the next Moonless night, a bunch of L21A’s will be lighting up the sky. :disappointed:
[quote=caramba]
I would say to use this one for bigger lights!
https://www.aliexpress.com/item/32966941249.html
I used it in my OL mod earlier this year!
This week arrived another piece for this flashlight!
The clip
[image] [image]
[image] [image]
Things are coming together and the mod is almost done!
The thing that needs to arrive to “close” it is the GITD gasket that I want to put in place before putting the optic on this light!
caramba
(caramba)
September 1, 2020, 5:45pm
3054
Lightbringer:
S21----small 21700 flashlight ,Then sequence character A,B,C,D… I am worried that the model is too complicated to be remembered.
Letter+number names turn into a jumble to me. Maybe animal names? Jaguar, Bear, Skunk, Squid, etc.? Those I could probably remember better. :laughing:
I think they should name a light after you. I am voting for “Lightbringer 911 Turbo”
id30209
(id30209)
August 31, 2020, 6:00pm
3055
Meh...Have originals...
Better use Jetbeam RRT clips, 10pcs for 8$ but they are not Convoy.
I admire your faith in Paperthin clips Mascartum
Never had a single one failing me
id30209
(id30209)
August 31, 2020, 6:57pm
3057
I did. I don't EDC anything but only using as a tool at work and i've seen thick mofo's bent like chewing gum.
Out of work don't like having anything with me LOL
Simon_Mao
(Simon Mao)
September 1, 2020, 10:30am
3058
uh,i mean the black metal clip ,
the screw for stainless steel clip is short
id30209
(id30209)
September 1, 2020, 10:35am
3059
Wait, i can stretch black S2+ clip on S21 body? It won't brake?
Simon_Mao
(Simon Mao)
September 2, 2020, 9:19am
3060
You can barely use it, but I don’t recommend it.
thefreeman
(thefreeman)
September 2, 2020, 10:24pm
3061
Barkuti:
Wellp, I can confirm the above report informing that AliExpress had removed the “other payment methods” option altogether (from the application too). But only in the newest versions of the toilet
Downgrading the application is a workaround.
I found a simpler way, chose webmoney (paypal should work too I guess, the aim is to get taken outside of aliexpress), place the order and when you’re out of aliexpress close the tab/cancel. The order will be made but left unpaid.
thefreeman:
Barkuti:
Excellent
I had an old version installed on computer with BlueStacks so that’ll help a lot, thanks
m47mu74nt
(m47mu74nt)
September 3, 2020, 7:05am
3063
Hello Simon,
Will the KW CSLNM1.TG 6N-ebxD46-15 6000-6500K work fine if driven with your SST40 12group driver ? or should I better stick with the 7135*8 driver instead?
thank you
The 5A SST40 driver will be fine. 5 amps is what most on BLF use to drive these. I measured mine with that driver and got 4.3A
trmgkl
(trmgkl)
September 3, 2020, 11:55am
3065
Simon,
Do you plan on releasing multi emiter flashlight? Like M21C-U or M3 body but with 3 or 4 LEDs?
I am very happy with my M21C, it’s a great light, I really enjoy it, quality is great but right now my favourite flshlight for nights at forest is Sofirn IF25A.
It’s great little light with 4 LEDs, great cmbination of flood and throw, but quality of sofirn lights is nowhere near Convoy lights.
I would love to see something like Sofirn if25a or Olight seeker 2 pro but from Convoy.
Ofcourse with usb-c charging built in.
Cheers
Thomas
Rayoui
(Rayoui)
September 3, 2020, 12:02pm
3066
trmgkl:
Simon,
Cheers
Thomas
Convoy S12 is a triple reflector 21700 light with fully regulated driver. No built in charging though.
Tartarus
(Tartarus)
September 3, 2020, 2:11pm
3067
https://www.aliexpress.com/item/1005001388842348.html
Won’t the emitter burn at 5A? Is thermal protection enough?
It was damaged in a previous test of Texas_Ace .
id30209
(id30209)
September 3, 2020, 2:17pm
3068
Tartarus:
“13.61€ 25% OFF|Convoy S2 + mit LH351D ,Ra 90, hohe CRI, DTP kupfer bord, ar beschichtete glas objektiv, 18650 taschenlampe, Taschenlampe|Taschenlampen| - AliExpress ”:13.61€ 25% OFF|Convoy S2 + mit LH351D ,Ra 90, hohe CRI, DTP kupfer bord, ar beschichtete glas objektiv, 18650 taschenlampe, Taschenlampe|Taschenlampen| - AliExpress Won’t the emitter burn at 5A? Is thermal protection enough? It was damaged in a previous “test of Texas_Ace”:Samsung LH351D 5000k LED output test by Texas_Ace - Amazing output, low thermal resistance but high Vf .
I'm running my 351D up to 6.2A for several months now. Still working great.
Zerosvn
(Zerosvn)
September 3, 2020, 4:12pm
3069
This looks like a great option. Does anyone know what the lumen rating is?
It has to be at least 1300 lumens right? That’s from the FC11 which uses the same emitter. This puts it a bit below the sst40 option. But high CRI
