What type of light would you like the next BLF Special Edition to be? As in developed by us over a year or so from scratch.... like it used to be
191 posts / 0 new
dehc111
dehc111's picture
Last seen: 2 months 14 hours ago
this might be a duplicate posting….
id like to see a:
ultra high brightness 50000 lumens, have an oscillating phase shifting variable frequency pulsed output mode.
It must be handheld and waterproof.
This is well within the capabilities of this community.
The question is do you have it in you. The challenge.
Barkuti
Barkuti's picture
Last seen: 1 day 15 hours ago
Just voted for a head torch. Every once in a while I go jogging with a flashlight attached to my head with a head strap. I often use a zoomie, but I find the beam profile of a Convoy S2+, S21A or similar quite useable. Some throw is needed, but nothing excessive. Color rendering is super important, in my opinion.
I would love to see a head torch built with a sunlight spectrum led. Take a look Sunlight spectrum leds @ Guangzhou Juhong Optoelectronics Co., Ltd., for example. I understand these are COB leds with very high Vf and low intensity, but these are minor issues in a head lamp (imho). Wheight doesn't frightens me (my usual setup is nearly 190g already and I find it comfortable), and I think it would be easy to use one of those sunlight spectrum COB leds (maybe with tint to choose from to the consumer's preference), combine it with an efficient boost converter driver with nice software and… voilà! A bestseller head torch.
Optics would need to be carefully chosen for it to deliver the right amount of throw for night jogging or even bicycle riding. Maybe dual emitter with two different reflectors, or daring short focus travel aspheric setup with precollimator.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
mr_magoo
Id like to help design a head lamp. Lumintop made one that was very close to what I want- the HL3A- but it could be better. I am starting to think theyve discontinued it as the links to the light are now broken on both lumintop’s website and Neal’s.
I agree with some of what he said ^^. Dual led- one part has interchangable optics, the other is possibly a mule with a cob led. Both hi CRI or at least very easy on the eyes.
This will be a very compact and lightweight unit for what it is. I have much of the design of the body already worked out, just would ned to wait for the final custom driver dimensions.
Unheard
Unheard's picture
Last seen: 44 sec ago
Barkuti wrote:
Wheight doesn’t frightens me (my usual setup is nearly 190g already and I find it comfortable), and I think it would be easy to use one of those sunlight spectrum COB leds (maybe with tint to choose from to the consumer’s preference), combine it with an efficient boost converter driver with nice software and… voilà! A bestseller head torch.
Every kilogramm of the battery pack helps training! Thumbs Up Evil
I support the idea of HCRI in a headlamp. Hate to step on fire bugs and other insects. But it would take big lumens to work.
Smile, you cannot kill them all.
Tater Tot
Last seen: 1 hour 56 min ago
I also like the sound of a BLF headlamp/right angle light.
Something like 4x E21A with a efficient buck driver and TIR.
If it ran Anduril 2 it would be even better.
RapidLux
Last seen: 12 hours 39 min ago
3 x SST-40 1000 meters thrower, 5000k, 3×18650 and usb-c charger.
ArtieT59
ArtieT59's picture
Last seen: 13 hours 10 min ago
You stole the words right out of my mouth… couldn’t agree more (despite my previous post). This sounds like my HK04, bit with a better/deeper/wider(?) lense! Probably one of my favorite lights!
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
mr_magoo
I really thought anduril 2 was going to be the bees knees, but it kinda took a turn away from my ideal U/I.
I think a blf headlamp should have its own brand new U/I that is not a real similar copy of anduril, and it needs a different name. As a headlamp interface it needs to be simpler to use, and ANYONE including my mom should be able to figure it out. It needs to be easier to lock and unlock.
I dont need the option for strobe or blinkies on my headlamp. I just need instant unlock and up/down. Any options to change stuff are limited and well hidden.
I do have U/I in mind and will post it when I get time.
Efficient driver would be great. I like loneocean’s new super efficient driver. A quad is going in the wrong direction for a headlight I think, because it makes the head get too fat. For when a headlamp is not being worn on the head, pocket carrying a quad is too bulky. Even a triple could be slimmed down by being only 2 emitters with optics side by side. You could theoretically have a light body and head that is barely bigger than the battery itself if you positioned the emitters with the idea of keeping things skinny. Keep in mind this is a clean slate light and we can do whatever we want.
Im not sure that 2800+ lumens are needed, but the option to have some decent throw, along with the option to have a floody beam in the same light appeals to me. Sometimes when I’m riding I need throw, and when working I need flood.
I dont have machine tools at my disposal any more infortunately but can rough out a hand made prototype for testing and collaberating on ideas. Maybe I’ll enter it in the old lumens scratch mad contest. Id need lots of help with sourcing components though so I dunno if that would be smart.
Th558
Th558's picture
Last seen: 11 hours 17 min ago
How about a light the size of an MF01S with 18 SST70s and tint shifting? A 30000lm popcan light would be nice. Currently we only have the X80-GT which is expensive.
Bardo219
Last seen: 4 months 1 week ago
Most high quality flashlight categories are available for somewhat easy purchase.
Except the supreme head torch which only BLF can bring.
stephenk
stephenk's picture
Last seen: 52 min 4 sec ago
RapidLux wrote:
My 2nd choice would be a Sofirn SP36 like flashlight, 3×18650, with 4xXHP 50.2, 10.000lm, usb charger and Anduril.
…with tripod mount (as in the Q8 and ROT66 II), and decent heat sinking (>1,500lm sustained).
Barry0892
Barry0892's picture
Last seen: 1 week 1 day ago
sofirn tried 3*21700 prototype which is too big, much bigger than Q8
But Q8 Pro with 4*XHP50.2(3V), SP36 Pro with 4* SST40 are tested in the lab, both have USBC charging port. I think SP36 Pro will be available soon.
WhatsApp: +8615773183209
My new Facebook account: https://www.facebook.com/barry.dong.9250
stephenk
stephenk's picture
Do they have a tripod mount?
BillyBobJoe
Last seen: 6 hours 26 min ago
Yes, please do a tripod mount. Missing the tripod mount on the SP36 that I currently have.
MoreHiCRILumens
MoreHiCRILumens's picture
Last seen: 13 hours 28 min ago
Uuh Q8 Pro and SP36 Pro sounds like a lot of lumens. I need that you know. Probably getting Q8 Pro then because that could be the flooder I been looking for.
I hope that there is lanyard hole in both and yeah tripod mount would be also good to get better carrying strap.
Sidney Stratton
Sidney Stratton's picture
Last seen: 6 hours 17 min ago
I’d be very interested in a Q8 w/ XHP50.2 – added feature with USB C charging.
Tripod mount – can screw an eye attachment for lanyard.
Dioda
Last seen: 1 month 1 day ago
And finally add the LANYARD HOLE!!!
Unheard
Unheard's picture
Barry0892 wrote:
But Q8 Pro with 4*XHP50.2(3V) […] are tested in the lab […]
Interested.
Barry, it has been quite some time since 3V 5000K XHP50.2 were available. Do you think there’s still a chance to get them?
liquidrazer
liquidrazer's picture
Last seen: 9 months 4 days ago
lukehale wrote:
bmengineer wrote:
Disappointing that none of the options include a balanced, versatile beam. Just pocket rocket or thrower. Really says a lot about how much this forum values actual utility of a light.
Yeah, honestly what I want is basically… Anduril SC64c LE (or SC64w HI). But to wait for the “Anduril 2.0”. I want it to be efficient, Buck/Boost Driver type efficient, with PID for the turbo modes.
Actually, here is what I really want, my “Dream” EDC light…
I want it to be the equivalent of the SC64w HI “CRI” 90+ CRI (like the Bob_McBob custom I have on order), Buck/Boost/PID, with Anduril 2.0.
But ALSO, I want to take the concept of the button AUX lights and repurpose it. I want the Button LEDs to be something like a quad-emitter of the high-cri AUX led on the Nitecore TIKI, to where the side button can be used as a full-flood headlamp. Maybe a quad E17 under the button?. I don’t know if that makes any sense. That way, I always have a full-flood headlamp/90 degree light, AND a throwy high cri EDC.
I may not be explaining this very clearly, but this would be, my ideal EDC. If I this could be had in different materials, such as clear-anodized aluminum, copper, brass, titanium, “natural” hard-anodized like Zebralight does (this would be my choice), etc. Then that would be awesome.
I know… dream big, right?
Edit: Actually, I would take this a step further, and also figure out how to do a boost-driver AAA size version of this, a “mini” perfect EDC, to use as my keychain light.
^ I am all for this! Anduril SC64c LE
christoph
Last seen: 21 hours 8 min ago
varbos wrote:
I would like to see a “re-invention” of the human powered flashlight.
Most things I see on the market are low quality, with plastic gears, plastic case, fake emitters etc.
I am wondering what would be possible with modern bearings, brushless dnyamos, good optics efficient LEDs, super-capacitors etc.
How many watts can a human produce with his hand? I don’t know.
https://www.youtube.com/watch?v=W6GsRQdy6xQ
I would like to see something like this as well.
Chris
Chris
richbuff said “Sometimes, I feel depressed about my spirit having been cast down to the hostile surface of this one-star planet, without my asking God first, and without God asking me first. I have found that a brief burst of maximum light from what is currently the smallest size flashlight per power makes it all ok/fine for a while, until the next time I feel the need to repeat.”
Majoroverkill
Majoroverkill's picture
Last seen: 1 week 6 days ago
OK, Here it is, lol. What about a torch that can sustain its highest setting for hours and not just minutes at best. A max of 600 to 800lm with enough mass for cooling and powered by three 21700 cells. Use the Anduril UI and maybe a TIR for both flood and decent throw. instead of overdriving an emitter maximize it for longevity, 600 to 800lm in the right body should be able to run without overheating for hours or until LVP kicks in. I think we have enough super duper I can blind you from a mile away and light up an entire county at the same time flashlights lol. It’s not always about power, I guess what I am trying to say is more battery and less lumens. I want a long hauler Big Smile Low horsepower lots of torque and tons of fuel Big Smile
Doug S.
stephenk
stephenk's picture
Personally I think pop can lights should be able to sustain at least 1500lm. It’s a shame that quite a few don’t – such as the ROT66 GenII.
Majoroverkill
Thumbs Up
Doug S.
Hugh Johnson
Hugh Johnson's picture
Last seen: 2 weeks 3 days ago
I love this about the Q8. I run it well above half way for extended periods. It’s a comfortable hand warmer on cold nights.
Unloco
Unloco's picture
Last seen: 1 hour 29 sec ago
Barry0892 wrote:
… Q8 Pro with 4*XHP50.2(3V)…
WOW!!!
I am interested!!!
I am also interested in spare Q8 MCPCB with 5050 footprint.
stephenk
stephenk's picture
The original BLF Q8 was a fantastic light – tripod mount, good heat handling, good neutral tint,compatible diffuser, and Narsil UI allowing ramping or choice of 12 stepped modes.
Everything since has been a step backwards.
Lightbringer
Lightbringer's picture
Last seen: 3 hours 27 min ago
stephenk wrote:
The original BLF Q8 was a fantastic light – tripod mount, good heat handling, good neutral tint, and Narsil UI allowing ramping or choice of 12 stepped modes.
Yeh. All it needed was charging and it would’ve been ideal. Needing to break out a 4-bay charger each time, then having to screw with the dinky O-ring that did what it could to try to escape every time it needed to be opened’n‘closed, was the biggest pain in the ass.
That inconvenience is why I switched to a DC7 as my go-to big donk. Cooler and throwier vs warmer and floodier as I like, and a dumbed-down UI vs Narsim, yet being able to charge all 4 cells in situ is what wins out.
And I get the feeling any “Q8 Pro” will still have the cooler/throwier setup vs the original, and probably an overloaded UI.
kadete26
I would love something like that.
trigger619
Powerful right angle headlamp like the size of the fw3a
I’m in for 5
stephenk
stephenk's picture
I prefer to monitor my batteries, so 4-bay chargers all the way, but no issues with lights with USB charging even if I don’t use it.
The Convoy 4×18 has a nice simple UI, good heat handling, and USB charging, but sadly lacks a tripod thread.
