Barry wrote about a Q8 Pro prototype using 3V XHP50.2:
For the first (and probably last) batch of “5050 MCPCBs”: They are maybe reworked from ordinary Q8 MCPCBs, don’t know for sure. What I know is that 6 users having interest is surprisingly few :weary: . I’ll personally try to catch one of the LED4Power boards when the shop reopens next year. Will be a clearance sale, hope we all will get one.
It should be noted that this thread may be not be heard at Sofirn. After some exchanges with Lan, the MCPCB that was made with XHP50.2s would have been modified 3535 footprints. Too time-consuming and effort.
As noted above, Barry mentions of some prototypes of the Q8 and SP36 with higher output LEDs. Best we second the initiative and voice our interest in the “What type of light would you like the next BLF Special Edition to be?” thread. link
Not really an update, but that’s the current state of affairs: Neither me nor (I think, haven’t heard from him since quite some time) Sydney are in contact with Sofirn in this matter. There was a clear ‘no’ to XHP50.2 MCPCBs (former ones were reworked original boards), and so we can only hope for the Q8 Pro project and that the geometry will stay the same. I concur it would make sense to sell gaskets along with the boards. In case the lights are similar enough, I’d even ask Sofirn for complete sets (board, reflektor, gaskets).
I would hope that Sofirn is still in development. From some exchanges, they may offer a complete Q8.
My queries and feedbacks:
As I had ordered the MCPCBs with XHP50.2 (there was a window of opportunity on Sofirn’s WebStore) and later was cancelled. Pressing the matter, from Lan Lee (August 27th):
However, I took it up with Barry that the Q8 was successfully fitted with the XHP50.2s and there are no known issues with the light. Also, that Sofirn should offer some upgrades on “power lights”, to which he replied (Sept 3rd):
I’d buy the MCPCB with or without leds on it. But a host “kit” with the correctly milled reflector, MCPCB w/leds, correct centering rings, and BETTER driver would be worth a lot more to me.
Did I see something called a “Q8 Pro” listed in a comment up there somewhere?
- has a nice ring to it! (kinda like the “SC31 Pro”…)
What would you consider a better driver than the Q8? It has high power capabilities, and Anduril.
And what are you insinuating about correctly milled reflector? And correct centering rings?
Better components for better current levels is what I meant. If you read a couple of threads on this topic, several mods have been done to the current driver to get better current output.
These threads also explain how the XHP50.2 is larger in diameter and the reflector has to be reemed wider to allow a fit. The centering rings would be taller to (effectively) meet the now reemed (deeper fit up into the…) reflector (and center around the led of course). This way the light bezel screws down firmly onto the centering rings for a correct fit.
Tom E suggested a more efficient FET (Vishay SIRA20DP) but no one has done any driver mods. The lower profile centering gaskets can be compensated with a thicker bezel “o” ring, Sofirn would probably include the correct centering rings.
Unheard and I are pushing for this Q8 Pro. Not easy to convince someone of different culture and acting as a middleman (Sofirn/Barry), so the numbers have to speak.
There are some that throw in a wrench and then other would-be members are less inclined to participate. As the existing FET can handle the current, maybe limit it somewhat. Hcanning and KawBoy both are getting some 16,800 lumens. I estimate some 48 Amps!
