Never had a single one failing me
22.1€ 17% OFF|Convoy S12 taschenlampe mit luminus sst20,nichia 219C,...
Smarter Shopping, Better Living! Aliexpress.com
I did. I don't EDC anything but only using as a tool at work and i've seen thick mofo's bent like chewing gum.
Out of work don't like having anything with me LOL
uh,i mean the black metal clip ,
the screw for stainless steel clip is short
uh,i mean the black metal clip , the screw for stainless steel clip is short
Wait, i can stretch black S2+ clip on S21 body? It won't brake?
Simon Mao:uh,i mean the black metal clip , the screw for stainless steel clip is short
Wait, i can stretch black S2+ clip on S21 body? It won’t brake?
You can barely use it, but I don’t recommend it.
Wellp, I can confirm the above report informing that AliExpress had removed the “other payment methods” option altogether (from the application too). But only in the newest versions of the toilet
Downgrading the application is a workaround.
I found a simpler way, chose webmoney (paypal should work too I guess, the aim is to get taken outside of aliexpress), place the order and when you’re out of aliexpress close the tab/cancel. The order will be made but left unpaid.
Barkuti:Wellp, I can confirm the above report informing that AliExpress had removed the “other payment methods” option altogether (from the application too). But only in the newest versions of the toilet
Excellent
I had an old version installed on computer with BlueStacks so that’ll help a lot, thanks
Hello Simon,
Will the KW CSLNM1.TG 6N-ebxD46-15 6000-6500K work fine if driven with your SST40 12group driver ? or should I better stick with the 7135*8 driver instead?
thank you
Hello Simon,
Will the KW CSLNM1.TG 6N-ebxD46-15 6000-6500K work fine if driven with your SST40 12group driver ? or should I better stick with the 7135*8 driver instead?thank you
The 5A SST40 driver will be fine. 5 amps is what most on BLF use to drive these. I measured mine with that driver and got 4.3A
Simon,
Do you plan on releasing multi emiter flashlight? Like M21C-U or M3 body but with 3 or 4 LEDs?
I am very happy with my M21C, it’s a great light, I really enjoy it, quality is great but right now my favourite flshlight for nights at forest is Sofirn IF25A.
It’s great little light with 4 LEDs, great cmbination of flood and throw, but quality of sofirn lights is nowhere near Convoy lights.
I would love to see something like Sofirn if25a or Olight seeker 2 pro but from Convoy.
Ofcourse with usb-c charging built in.
Cheers
Thomas
Simon,
Ofcourse with usb-c charging built in.Cheers
Thomas
Convoy S12 is a triple reflector 21700 light with fully regulated driver. No built in charging though.
https://www.aliexpress.com/item/1005001388842348.html
Won’t the emitter burn at 5A? Is thermal protection enough?
It was damaged in a previous test of Texas_Ace.
“13.61€ 25% OFF|Convoy S2 + mit LH351D ,Ra 90, hohe CRI, DTP kupfer bord, ar beschichtete glas objektiv, 18650 taschenlampe, Taschenlampe|Taschenlampen| - AliExpress”:13.61€ 25% OFF|Convoy S2 + mit LH351D ,Ra 90, hohe CRI, DTP kupfer bord, ar beschichtete glas objektiv, 18650 taschenlampe, Taschenlampe|Taschenlampen| - AliExpress Won’t the emitter burn at 5A? Is thermal protection enough? It was damaged in a previous “test of Texas_Ace”:Samsung LH351D 5000k LED output test by Texas_Ace - Amazing output, low thermal resistance but high Vf.
I'm running my 351D up to 6.2A for several months now. Still working great.
This looks like a great option. Does anyone know what the lumen rating is?
It has to be at least 1300 lumens right? That’s from the FC11 which uses the same emitter. This puts it a bit below the sst40 option. But high CRI
Tartarus:https://www.aliexpress.com/item/1005001388842348.html
I would say closer to 1200-1225 with all losses figured in (@ 5A). The 4000K will be a few percent less still.
I have an A6 with 351 in it, does about 1100Lm at startup
I’m running my 351D up to 6.2A for several months now. Still working great.
Good to know. Thanks!
Hello, friends.
I ask for your hints, help. I ordered 4 sst40 drivers 12 groups 22mm for KW CULPM1 from Mr. Simon, they fit perfectly. My favorite light groups are 2, 5, 6, 10. I got used to it and got used to it so quickly that I change the light groups and memory very quickly, depending on the requirement, I remember them all. Excellent drivers and controls, I am very pleased, there were no glitches or hiccups, everything is ok. But I have a problem with programming one driver. Tried different options many times, but it doesn't enter program or memory mode. It just works on / off, like a toggle switch. Full clicks and half clicks - no reaction. He always works for me in group 12, and my numerous attempts to change the group have failed.
Help with advice on how I can join another group. What else can I do. I would be grateful for your help.
m47mu74nt:Hello Simon,
Cool, thank you
Hello, friends.
I ask for your hints, help. I ordered 4 sst40 drivers 12 groups 22mm for KW CULPM1 from Mr. Simon, they fit perfectly. My favorite light groups are 2, 5, 6, 10. I got used to it and got used to it so quickly that I change the light groups and memory very quickly, depending on the requirement, I remember them all. Excellent drivers and controls, I am very pleased, there were no glitches or hiccups, everything is ok. But I have a problem with programming one driver. Tried different options many times, but it doesn’t enter program or memory mode. It just works on / off, like a toggle switch. Full clicks and half clicks - no reaction. He always works for me in group 12, and my numerous attempts to change the group have failed.
I too had one borked driver in a M2 (7135x8), Simon sent me a replacement driver with my following order so I could repair it by myself
Simon,
Thomas
3X21A (3*21700 and 3*SST40) is in production now ,it has Type-c charging port
