Well the crew finished up a bit ago and left. The house is cooling off and drying. What a relief. I don’t even miss the $3800 they took with them when they left. Money well spent.
I left a window open too much last night. This morning I ran the split mini in heat mode in the kitchen / dining area for a little. (Solar driven)
What do you have for a solar setup? Is it lead or lithium?
I’ve been slowly collecting laptop batteries for a solar project of my own in the future.
Two pole mount pv panel arrays with trackers plus a ground mount array facing southish. Outback controllers and inverters. GBS prismatic LiFePO4 cells in 48 volt configuration.
Sorry for the tangent. My mind wanddddddddddddddddddd
Mine too
Alright, back at it today. So obviously if I put that MCPCB inside a plastic shell it would overheat and then melt my flashlight. So we need to go metal. Let’s look at those options. This is model is hollow as shown above.
Obviously copper would be best, but at $756 plus shipping that would be a poor choice. Steel for $116 might be acceptable if it were guaranteed my design contained no errors, but there are no such guarantees. Furthermore, all that gets you is a powdery piece of metal. This old SLS printing technology from 1988 has a very rough surface that makes large threads suck, and small threads don’t even print.
So from this pricing I can see the path forward is a hybrid design. With a plastic body, but a metal tip. I may even plan to solder the LED direct to the body on two contacts to avoid the issue of how to attach the MCPCB securely.
What’s that thing AVE on youtube says about the tip?
The Steel price of $23 is pretty good, but I wouldn’t be able to solder to that. The Brass would probably solder fine, it costs $77. Even so, with shipping and one re-order this might cost nearly $200 in the end, and that’s not counting other parts and time. That’s not a good price either.
Welcome to the RED Zone, mid south is Hot too, maybe worse with little air flow.
Nice drawing and planning
The nice thing about doing most of the work at the computer is I can be in the house rather than out in the garage. When I saw my wife hydro-dipping out on the deck I decided to try my hand at it. My hand got covered in paint. But check out my YT play button in red/white/blue It has issues, but it’s my first attempt ever.
Then we went in the pool.
OMG
Looks like your fingers have been shredded in a blender. Sure that’s not blood ?
Whatever you do, don't turn on the garbage disposal...
Ahhh!!!
Ha, it does look gruesome, but it’s just red/blue paint and water. I might do this again for Halloween on purpose
Thanks God.
Thats scary.
My wife agrees, this looks good (from a makeup-gore perspective). I thought I was about to read a post about you dropping out due to some accident. I am glad that is not the gore it appeared to be.
I’ve definitely had my share of nicks and cuts on my hands, but luckily nothing that ever amounted to more than a modest scar.
Oh that’s a nasty pic. A workmate crushed his fingers the other day and it looked pretty similar
This was your inspiration for the design…?? What exactly are you intending on lighting up?? :laughing: :laughing: … :person_facepalming:
I always say, the place a flashlight is needed most is “where the sun don’t shine”!
